So, does the 7950GX2 count as a single card solution?
Page 28 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Rangoric
530
Originally posted by: beggerking
Your hardware must allow OC for it to be OCed. Your software sends out a signal to bios to adjust OC speed, but it is your bios that actually sets the OC. It is not related to your overclocking software.
The Bios is software. And it is the software I am talking about.
btw, "A virus works by using a design flaw in the software." is wrong. I think you are referring to a "hack"...
I think you are restricting the kind of virus we are talking about. Many Virus that use AIM or Outlook utilize a flaw in the design of said applications to do what they want.
a virus works by attaching its code to the front or the end of an executable.
And this proves it. A virus can also be a self contained executable with no need to attach its code to anything else.
josh6079
3,261
Originally posted by: downlow
If you could somehow come up with a definition of "single-card solution" that everyone agreed on (obviously this will never happen), then there would be absolutely no question of whether the 7950GX2 is a single card or not.
How about this:
A video card is only completely a single graphics solution (anyway you spin it) if it appears so through a hardware standpoint AND a software standpoint. Once a company adds "dual" anything, whether it be pcb, GPU, etc. It loses a part of its "single" attribute and thereby cannot be classified as purely a single graphics solution "anyway you spin it".
However, that does not mean that one cannot compare the difference between it and other traditional "single" cards. (When SLI first hit the motherboards, they had to compare it to something didnt' they? Now that SLI has hit the single PCI-E lanes, they have to have something to compare it to, right?)
whatever Josh, I see you just can't get the correct technical definition of a hardware to stick in your head.
I see computer hardware as a computer component that you can physically touch and somthing that stores or allows software traffic to run throughout its design. Since you are arguing so extensively on how the two relate and differ, how do you see hardware? Do you disagree with my definition? How long are you going to go on with this tangent before you come back to the relative material?
if a monitor was made to function to acquire and display ALL resolution/refresh rates and breaks when it does that (aka monitor resolution example), then its a hardware flaw.
Yes, IF a monitor was made that could do any resolution and any refresh rate (that would be a nice monitor) then a failure in displaying those resolutions/refresh rates would be a hardware flaw. Do you know of a monitor that can do that? downlow was talking about "real" moniotrs, meaning those in use today and yesterday. With a real monitor you can cause damage to it if forced to a unsupported resolution/refresh rate through the software simply because any monitor in existence has a limit. But it was a nice attempt for you to get everyone concentrating on unrealistic theories that involved imaginary monitors.
have you seen any hardware literally break w/o drivers or softwares?
That's like asking if hydrogen "broke" without oxygen. No, I've never seen hardware "break" without a driver or software, but I've seen hardware break with software and due to it (overclocking)--implying that there is indeed a relation between them when you think there is not.
If you can't understand abstract technical details, you are only ignorant to be arguing against it.
Ignorant? If you can't adhere to realism and understand the functionality of hardware without software who is being ignorant?
If you don't have an ATI card installed yet you installed a ATI driver, most likely a message box will pop up notifying that you don't have the correct hardware. That message box, is the prove that the software is correctly "working".
If that is true, then why is a pop up presenting itself and notifying one that they "don't have the correct hardware"? If hardware works correctly regardless of the software, and improper software installed is still "correctly working" then why is there any need for a pop up? Why does the computer tell you that something is wrong?
(Because something IS wrong. Software does have somthing to do with hardware. So much to the point that you have to have just the right type of software before hardware can function correctly).
I'm not playing with semantics
??? :roll: I'm sure if we made another thread with a pole asking that question that it wouldn't be as close as the pole to the question in this thread.
Answer these questions:
1) How do I flash a GPU with a NIC BIOS? ("hardware has nothing to do with software").
2) Why the XP installer needs drivers to access SATA drives? ("OS fetches data from the HD").
3) Why I can force AA and AF in OpenGL games that know nothing about said features? ("the OS does it through DirectX").
4) Why Quad SLI isn't working even though the hardware is already present to support it?
5) How to get HT working on an Athlon 64? ("hardware has nothing to do with software").
(Actually answer that one instead of telling me how to go about finding out how to answer it.)
6) What are you still doing here since the 7950GX2 is already compared to the X1900XTX on multiple sites?
7) How this:
Its not like software won't run correctly without hardware.
is even possible? (Give me an example of software doing anything without hardware, existing on anything if not hardware)
Answer those instead of making up imaginary pieces of hardware that actually are independent from software because they're imaginary. Answer them instead of telling us how to go about finding out an answer. Answer them directly rather than replying to one and asking one of your questions. Answer the questions without having to look in Bush's press conferance strategy guide before you supply another semantic. And answer them without having a mod interupt and distract from the discussion for crimes reported by you when they have also been committed by you.
Rangoric
530
Originally posted by: josh6079
then give me an example of software doing something without any hardware involved. Can you hold software in your hand? Can you do anything with it without a keyboard, mouse, monitor, computer, etc? What can you do with software that does not in some way involve hardware? Just how can it "run" at all without hardware beggerking?
You can run it by hand using pen and paper, theoretically.
Or (since those are hardware), just in your head.
The thought makes my head hurt :)
beggerking
1,703
Incorrect. your ATI CCC will still pop up a message if it doesn't receive a response back from your ATI hardware.
And what does it pop up a message on? A monitor. What is a monitor? Hardware. (I find myself answering my own questions because you don't have the answers for them or ignore them completely)
as always, please READ before you reply.
I said, using a NV card connected to the monitor. your ATI card is not present.
If what you say is true:
I never said software won't run without any hardware. its not like your CCCsoftware won't run correctly without ATI hardware. Example given above. a messsage box pops up indicates your software is "running".
Rangoric
530
But the BIOS is software.
NOT the software OCer Rangoric was talking about.
I was differentiating my Motherboard from the Volt Mod for the 7900GT or other motherboards which might have a jumper to enable certain settings.
I never ment to exclude the Bios. If it seemed that way, ops.
beggerking
1,703
you said "my Mobo is a software OCer". its a software on your mb( hardware), not a part of OS. Therefore, your hardware manufacturer is still responsible for it, hence its still a flaw in hardware.
then its a hack.
It is possible to attach itself to an empty file.
Rangoric
530
you said "my Mobo is a software OCer". its a software on your mb, not a part of OS.
And? :roll:
Since software cannot hurt hardware ever, no exceptions, then I can overclock as much as I want. There will be no loss of life in any component.
Instead I will contend, that considering your position. Software is Hardware.
Show me software that is not a set of manipulated locations on a hard drive or in memory. Then show me how to run said software.
josh6079
3,261
Please think before posting, reading is too much for me to ask in return from you.
Whether it is an NV card or an ATI card doesn't matter since they are still both pecies of hardware, something you stated software can run correctly without.
Yes you did. You said this:
You did not say, "any" in that nor give any other adjective signifying specifics.
Trying to work with the wrong component is still "working correctly" in your eyes? It isn't working because it isn't being utilized correctly. There are errors all over that--trying to use ATI drivers on NV hardware. Wrong software + Wrong hardware = Wroking just fine in beggerking land.
7) How this:
EDIT:
So now you're deciding what kind of a flaw it is based upon which manufacturer supplied it?
beggerking
1,703
And? :roll:
you said "my Mobo is a software OCer". its a software on your mb( hardware), not a part of OS. Therefore, your hardware manufacturer is still responsible for it, hence its still a [/b]flaw in hardware[/b].
beggerking
1,703
It is true. If you are not sure if that is true or not, then you basically don't know anything about software...please stop arguing.
it "doesn't have the correct hardware" to run other parts of the program, but the software itself is still working "correctly" as designed.
Rangoric
530
Say what? According to this logic, Drivers are hardware, as is the Bios.
Please, write up your definition of software and hardware, cause I don't think those words mean what you think they do.
Edit:
Heck, if there is a flaw in NVidia's control panel its now a hardware flaw, not a software flaw.
beggerking
1,703
so are you saying your driver can run without OS?
josh6079
3,261
Isn't your "agenda" taken care of already? Why are you still arguing if what you wanted has already happened and will continue to happen? Also, find someone else here who understands what you are saying. Look around. You are the only one who can't understand the simple relationship between hardware and software. Are you really going to hide behind that child-like logic that everyone else is wrong and you are right? You don't even address the questions that would prove your theories true like an adult would. Instead you avoid them and persist on arguing with anyone and everyone you can in an attempt to cludder the thread up with nothing but your semantics. Stop trolling.
So basically it is like a human without control of their left side? Being unable to utilize its entire function is still working correctly to you?
beggerking
1,703
please distinguish a software flaw vs a hardware flaw.
hardware flaw = ______________?
software flaw = _______________?
my def:
hardware flaw = Pentium CPU bug
software flaw = if (x=1) then {do something}
beggerking
1,703
Actually, that is a controlled branching, the software was designed to Not run part of the code in case the hardware is not present. Obviously you don't know enough about coding to figure that out.
josh6079
3,261
my def:
hardware flaw = What the 7900's were having with artifacting at stock speeds and proper drivers and normal temps. Gradient banding with the Dell 2007's.
software flaw = ATI drivers on Nvida hardware. Two different mods in Oblivion that result in pink ground (I know that one personally).
josh6079
3,261
Oh, but you could sure "fool" it to right?
josh6079
3,261
Judging from the pole it looks like 120 say no and 113 say yes. Technically, since some of us want to deal with "abstract technical details" (which is the biggest oxymoron I've heard next to "Holy War") the answer is no, it isn't a single card solution. If you ask me though 113 to 120 isn't that big of a gap and I think that it is basically "whatever you want it to be". Some seem to be very bent on making sure it is classified correctly though....
beggerking
1,703
my def:
how does ATI drivers on Nvidia hardware a software flaw?
the person who developed CCC should also support NV cards?
CP5670
5,684
783
Who knows, maybe this thread will eventually surpass that Rollo AEG one in the number of posts. :D
josh6079
3,261
beggerking, is your idea of a driver working correctly for it to pop up an error message to you?
You have said that as long as hardware is inputing and outputing, it is working correctly.
You have also said that that can happen without a driver.
Then you say that a driver is still working correctly when being used on improper hardware.
If the driver isn't hardware specific, why do you get an error message?
If everything above is working correctly, why is there an error pop-up?
Do you simply disregard this error, since you know it IS working in your eyes?
Rangoric
530
WTF? Drivers are supplied by the manufacturer of the hardware. By your Bios statement, this makes a bug in a driver a hardware issue, since the Manufacturer of the hardware supplied it.
Its not my arguement. Its YOURS.
