Originally posted by: beggerking
my agenda is for comparison sake, not to claim "victory". 7950 being faster than 1900 was well-known and proved by ALL REVIEW SITES, while 1900 does have better IQ. It'd be pointless to try to prove it again or claim victory on it.
it is the Operating System that can be impacted in a negative way. hardware still works as is. Please make a distinction between hardware and software..
This is why I said you were hopeless. You STILL think that a driverless 7950GX2 is really cool and doing just fine. Without a driver, I can NOT play a game. Period. If Windows XP does not have a video card driver, it can still function properly. You can still open programs, browse the internet (although it will be kind of choppy), still control where your files go, etc. A 7950GX2 cannot play a modern 3D game without a driver and is therefore, useless for its intended purpose without the software.
It's a shame that the 7950GX2 uses two PCI-E slots then, isn't it.Originally posted by: beggerking
actually, I tend to see hardware seperately from software. If a hardware uses 1 pci-e slot, its 1 hardware peripheral.
7950GX2 is a video card, its purpose is to decode and display.
It is the operating system that allows you to play games by sending out the correct information to video card.
Uninstall your video card drivers and attempt playing some games.
Go try it now otherwise you probably wont believe me.
Now what happens is with D3D you are dumped to the REF rasterizer and with OGL you are dumped to Microsoft's software renderer. If the games even start up (OGL ones might not if they are expecting extensions, not sure about D3D ones either).
See this is where the driver comes in handy. The driver directly communicates with the hardware, what the OS can do is extremely limited.
Maybe you should go buy a beginners book to Computers/Hardware/Software/Windows, might help you.
Originally posted by: eastvillager
dual-core cpu = single socket
dual-gpu graphics adapter = single slot
Except its not that simple. The GX2 takes up more than just one slot, the one its plugged into, and another.
1. That depends on the motherboard. It doesn't use the slot, though it may block the slot.
2. CPU heatsinks can block ram slots, do you say that they take up a ram slot? No, you don't.
3. Artic Silencers block a slot too, but they don't make your card a two-card solution.
4. Funny thing about this argument is it is pointless. Most of the 2-slot arguers are fanATIcs and most of the single slot arguers are nvidiats.
5. All because the ATI people want to believe the x1900xtx is still the fastest 'part' when it quite obviously isn't.
6. Even funnier is that, based upon your argument, that the card blocks the second slot, the x1900xtx is a 2 slot card as well.
The GX2 has two seperate PCB's, two seperate GPU's, two seperate fans, two seperate amounts of ram. The dual core CPU is nothing like it in that regard. The only thing they have in common, is that they both plug into one "slot". Looking at the outside of a dual core CPU, and a single core, you cannot tell the difference. You can with a GX2 and a single 7900 card very easily.
numbered by me to make it easier
1. Care to take a guess at what percentage it is where a GX2 doesnt block the second slot?
2. Why would I? Its not even the same thing.
3. I never said it did.
4. Its one point out of several, that you and begger seem to hinge your whole arguement on.
5. I dont care which has the faster card. Its "obviously isnt"? According to the poll, most think the GX2 is two cards slapped together.
6. Once again, you hinge your whole post, and argument on one point out of several in my post. Ill post it again, since you dont seem to want to respond to the whole post.
Once again, stop trying to use only one point of my post, and try thinking about the rest of it. Calling the GX2 the same as a dual core CPU is pretty silly to me. But hey, everyone has their own opinion.
Maybe you should repeat that to beggerking because he seems to think it's one card.A "card" is a PCB according to just about every computer scientist and electronic engineer I've ever spoken to, so a 7950 has 2 cards.
This is nothing more than semantics. The point is the replication level at both cores is such that it makes them individual CPUs.Actually it has two cores on the package.
The device ID at the very least would stop you and then there's the fact that Windows couldn't even execute the code given it couldn't even initialize the device properly.I could use a NIC driver for a GPU if I wanted, nothing would stop me.
But you would not be operating the device within its standard operating parameters just like you don't operate the 7950 properly when you disable SLI or when you run it under VGA mode.It would send completely the wrong signals to the GPU, which would send some interesting garbage to the display and then crash, but nothing would stop it happening.
So you admit we need to change the software the moment we go from a single card to a 7950?because in order for each GPU need to process different instructions,
The OS doesn't "send" anything, it simply provides the API interface to interact with the driver which directly interacts with the hardware.os needs to send "different" data to each GPU.
No, the driver does. The OS has nothing to do with SLI, it's all the driver doing the load distribution and programming the hardware.OS controls what is being send, not hardware.
Yet by your own admission ("os needs to send "different" data to each GPU") we have to change the software when the 7950 is installed compared to a real single card, proving hardware has very much to do with software (and vice versa).all hardware does is input, process, and output regardless of software states.
Originally posted by: BFG10K
The device ID at the very least would stop youI could use a NIC driver for a GPU if I wanted, nothing would stop me.
Then if you somehow forced it Windows would probably hang on startup or it would disable the device in the Device Manager stating it's not working properly.
Originally posted by: keysplayr2003
I believe he can use any point he wishes to. Or will you just try to force him to do what you want him to do?.... You posted the point(s), now they are each and every one of them, open for debate, and not all necessarily at the same time. Agreed?
That's the whole point though. What use is a driver if it doesn't work?I never said it would work,
He's using the comment because he's playing semantic games in his posts.Perhaps this is what was meant by the "hardware has nothing to do with software" comment?
Can it even be called a driver if it can't operate the device at all?
Originally posted by: jim1976
To the Nvidiots : Wake up you boneheads two cards in one. No matter how you'll try to manipulate the situation the fact remains that we are talking about "two cards"
To the fanATIcs: Who gives a fook if it is a single card solution? If you blame Nvidiots being unreasonable and out of reality because they want to count it as a single card solution so that Nvidia can have the high end lead, then you're equally retarded for answering to such a claim... PPL DO have judgement you know..
I am an idiot for posting to this vicious circle of stupidity.. lol
Reagardless of all these nonsense 7950GX2 is a high performance "card/s" at a very good price. If I didn't care for the I.Q (but unfortunately I do when I pay big bucks and that's why I went ATI this time) and I was to buy a gpu now I'd probably have taken it.. But others find the IQ differences too unimportant so they find this card a great offer. Who the fook honestly cares if it should be considered a single or a dual card? Mercy!!
how softwares sees doesn't change the fact thatOriginally posted by: thilan29
I think the best explanation still was given by BFG10K:
"In terms of hardware it's 1 card but software sees it as 2 cards." (basically like an SLI setup in terms of software.)
1. 7950gx2 is a hardware.
2. 7950gx2 is physically a single PCI-e card with 2 GPUs.
well, for the same reason I consider a dualcore CPU as a single CPU, I consider 7950GX2 as a single card solution.
Bulldog, do you consider dualcore CPU as a single CPU or not?
By using one of its drivers.
It has a default VGA driver that it uses when it can't find any other driver that works.
If windows had no display driver, it couldn't do anything.
At worst it has the "Dos mode" driver.
we did the same when we went from single core to dualcore. I consider dualcore a single CPU.Originally posted by: BFG10K
software doesn't "need" to change for the hardware to work. hardware works as it is. software, on the other hand, changes to improve performance.In otherwords the software needs to change because we are now running a 7950 (aka SLI) so by your own admission your "hardware has nothing to do with the software" comment is complete nonsense.
data are send to driver by OS.
it is the OS that sends out data, driver is only a encoder that encodes data so hardware can understand.
"The driver object is a portion of memory allocated by Windows, which describes where the actual driver is loaded into memory plus contains information readable by Windows about the driver"
"When you decide to print a document or connect to the Internet, Windows will examine the Function Dispatch Table to see which major function code will be able to fulfil the request. "
Text[
Originally posted: here
In a nutshell, device drivers are the pipeline through which the software communicates with the hardware....Every piece of hardware connected to your PC requires a driver of its own, or it simply won't work.
Sure he can. Its just silly to ignore all the other points, and focus only on one. The only one the each of them have tried to refute, was the two slot point. Nothing on the fact that a dual core CPU looks the same as a single core CPU from the outside, nothing about the GX2 having two PCB's, GPU's, fans, sets of ram, etc. If they're going to try and say a dual core CPU is the same as a GX2, then they need to look at more than they both just use one "slot". Its really pretty easy.
