SetiQ Newbie Help!
BFC, i changed it in dns2go and it said that to reach my server we have to redirect to "www.paf07.dns2go.com"
Crazee, I put it back to 14., but i think you'll have to try www to connect.
waiting for test!!!!!
Crazee you probally wouldnt be able to hit it by typing in his ip 66.130.59.102, since that is the IP of his service before it reaches his router.
That is the ip of the external port on his router. I have a linksys router if you put in http://208.179.191.155:5517 you will hit my Setiqueue. All DNS2GO does it track a non static ip address and give it a static domain name. If you know the current ip address of the external port you will hit it.
The problem is definitely not in DNS2GO. Paf change back anything you changed in DNS2GO.
<< That is the ip of the external port on his router. I have a linksys router if you put in http://208.179.191.155:5517 you will hit my Setiqueue. All DNS2GO does it track a non static ip address and give it a static domain name. If you know the current ip address of the external port you will hit it.
i typed in http://208.179.191.155:5517 and it said page cannot be displayed.
Paf its still not working..
Now I can't even connect from my own box, when i click on transmit in SetiDriver, it flashes once grennand goes back yellow immediately.
I restarted Seti Driver but it's the same. This is getting really annoying!!!!!!!
Recheck your ip addresses and see if any of them changed when you restarted the router. Make sure everything is still at 192.168.1.101
I'll give it a shot. 🙂
login to your router goto advanced, then DMZ Host, set DMZ to your internal address. (192.168.1.101 or whatever it is) click apply then you should be good to go.
make sure you have a software firewall running, ZoneAlarm, Sygate etc.. ( I use Sygate and still in stealth mode with a webserver and proxy server running).
Force
edited: to correct the IP addy lol DOH
Also put everything in dsn2go back to original settings. I guarantee you that is not the problem. Until we can hit it with the ip address there is something wrong with either SetiQ or the router.
Gundog's suggestion should rule out whether it is the router or not. (Good thinking) 🙂 If it doesn't work after that then the problem lies somewhere in SetiQ
I am not hitting it with either that or the ip address 🙁 I think the problem has to be somewhere in SetiQ
The problem isn't DNS2GO because I try the ip address and it doesn't work either. At this point it might not be a bad idea to uninstall SetiQ and reinstall it.
You can't hit it by ip on the machine you are running it on but yes it works for me. If you look in your log you will see my ip address as having viewed the front page.
<..Click on the Service Settings tab in DNS2go and tell me what is says>
It says ONLINE
"Point my domain to my current IP address" is checked. Nothing else.
