SetiQ Newbie Help!
Ok . I had to reinstall everything again just ro get my comps running right. so i am going to forget about SetiQ.
I'll try to dump the pc's at work early in the morning, maybe 2 a day.
This is not supposed to be this frustrating, I have had a lot of fun since joining the TeAm 🙂
Except hese 2 last days have been very madening. So I will go back to just enjoying the forum and the TeAm!!!!!😀
I would like to THank all the guys that helped out. Thanks again for you patience and support. 😎
Paf,
Point your work machines to my queue. I will make sure they get uploaded 🙂 I don't have alot of traffic on mine so the results usually don't build up.
Sorry we couldn't get it to work, however you are correct this is supposed to be fun and we don't want you to stop having fun!!! 🙂
As for the help, what kind of TeAm members would I be if I didn't give it a try. Besides we are both E^5 members too 😀
Thanks I might just do that!🙂
I'l PM you before. I have around 20 Wu's per pc already to go.
I will try and set it up tomorrow and see how everything goes
If it gets clogged up I will use you Q.
By the way check you mail.
hmm, i just remembered when i was seting mine up i had to change the IP for this computer to 192.168.1.8 you might want to try changing your IP from .101 to .6 or something like that. i dont know if it would do anything but it is easy to do and worth a try.
