SetiQ Newbie Help!
Yes it is checked! and I can connect from here!
Would you try again, because I won't have time to fool arounfd with this at Work. it has to work!
DNS2GO is running on the same machine you have the queue on? Are you sure you put the right ip address for the prot forwarding?
I know these are questions that you have checked, but I am running out of ideas
<DNS2GO is running on the same machine you have the queue on? >
Yes!
<Are you sure you put the right ip address for the prot forwarding?>
I put in my main pc's address that is assigned in the router. 192.168.1.101. Is this correct?
On the machine that is running SetiQ go to the command prompt and put in ipconfig /all.
What IP address does it show?
This is what I get:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\paf>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : T-BIRD-XP
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Network Bridge (Network Bridge) 4:
Connection-specific DNS Suffix . : videotron.ca.
Description . . . . . . . . . . . : MAC Bridge Miniport
Physical Address. . . . . . . . . : 22-45-A3-A3-DA-17
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.101
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 24.200.243.242
24.201.245.114
24.200.243.250
Lease Obtained. . . . . . . . . . : Saturday, February 16, 2002 8:30:49
PM
Lease Expires . . . . . . . . . . : Sunday, February 17, 2002 8:30:49 PM
And when i check the clients page in SetiQ, it lists it as 192.168.1.1
Check your DNS2GO software and tell me what IP address it says it is currently pointing to. Also check to see what domain name it says you are using.
It won't hit it even if I put the ip address in. So the problem is not in the configuration of DSN2G0.
Double check the port forwarding and be sure it is set and then restart your router. Maybe it just needs that. Mine was acting a little squirrely until I restarted it.
Ok, I'll recheck and reset. Wait a minute, if I restet it it goes back to default!
In port forwarding it is set to 192.168.1.101 and ports 5517to5517
If this doesn't work, go to your settings page in SetiQ and copy and paste it here. I will compare it to mine and see if we can figure it out.
Here is the settings page:
General SetiQueue settings
Current time Sun 2002 Feb 17 2:54:43am
Installed On Fri 2002 Feb 15 11:16:50pm (1 day 3 hr 38 min ago)
Started On Sun 2002 Feb 17 2:42:45am (11 min 58 sec ago)
SetiQueue Name paf077
Remote URL for SetiQueue
Min Queue Depth 5 days
Max Queue Depth 20 days
Obsolete clients after 10 days
Keep logs for 5 days
Debug logging disabled
Shc debug logging disabled
Socket debug logging disabled
IP & Subnet Mask 0.0.0.0, 0.0.0.0
Port Number 5517
Connect Type WinINetDefault
Queue processing settings
Processing Priority Default
Processing Times 1:00am - 9:00am
Inter-WU download gap 1 minutes
Inter-WU VLAR gap 1 minutes
Look for sweet WUs enabled
Max delay between retries 10 minutes
Override for pass-through operations enabled
Override for empty queues enabled
Upload pending results enabled
Download new WUs enabled
Report stats to SetiQueue server enabled
Save a copy of all results disabled
Http Server settings
Allow any IP address enabled
Extra Footer URL
Text for footer URL
The only difference I see between yours and mine is that you don't have the remote url for Setiqueue filled in. I don't know if that makes a difference, but mine has it set and yours doesn't so you might want to try putting in http://paf077.dns2go.com:5517 in that field and see if it works.
mine is
IP & Subnet Mask 192.168.1.8, 255.255.255.0
192.168.1.8 is the IP of this computer that the Queue is installed on..
make sure you do this in DNS2go
click Service Settings->redirect web requests (with a www prefix)
then click to my current IP address on port 5517.
Wait I think I remember someone saying that if you set your maximum queue depth over 14 days the http wouldn't work. Try taking that down to 14 days
Don't change anything in DNS2GO that isn't the problem since I couldn't hit it by typing in the ip address. The problem is either in the router or in SetiQ I think the last post I made though might be the solution.
