And, I'm guessing we're calling each of the (highlighted in blue) formations one EU?
http://img580.imageshack.us/i/2csandybridgediemap.jpg/
So...opinions....is this actually a Tock from what you guys can tell?
At first I didn't think so, I thought maybe it was just Nehalem + integrated GPU. But now after seeing some of the more recent performance/layout rumours...
That was kind've my point. If we're calling that a 12 EU part, that'd have to be a single EU. Im sure its possible that the die shot is only a 6EU part, but I don't know where another 6 EUs would be shoved into the die at, so it seems likely its a full 12 EU. I just wanted to confirm my thinking.
Na thats a 12 EU part . The black areas are eu. The wide ones you see in the center are 2 wide for total of six. Both sides have 3 each. You can see there half the size. So ya its 12 core.
I beleave its time to wake some people up . Intel said along time ago or rumors say . that Intel will have 2 IGP cores. I believe all IGP core have 12 eu. and we can expect 2 or more cores in SB . As intel repeatedly said at IDF . That the ring bus allows use of many differant cores in their New SB SOC. Read it for yourselves. If I was intel I would only show the 1 core unit. It will be interesting to see how AMD handles the bandwidth of and ondie gpu . I await this miracle of hype.
wut?
There won't be any s1155 130W chips. AFAIK it doesn't have the pins to support that much power. Nor will s2011 have GPUs on-die, again AFAIK. Ivy may integrate a second group of EUs; its very likely the number of EUs will go up, but actual dual-GPU is unlikely.The unit anandtech tested had 6mb L3 cache, the "2400". The "2600K" has 8mb of cache. It would be shameful for Intel not to add a second IGP in the 130 watt range. 6 cores no IGP, 4 core 2 igp. Of course, the added IGP core would remove redundant portions of the GPU.
graphics comparison
Geforce 310M die size 57mm2 260m transistors
ATI 5450 die size 59mm2 292m transistors
XBOX 360 GPU (ATI) 232m transistors (+ EDRAM)
PS3 GPU (nvidia) ~300m transistors (+ CELL)
SB Graphics die size 41mm2 ~300m transistors (xtor increase over Lynnfield ~346m)
prorata the Geforce 310/ATI 5450 and they would be 38mm2 in 32nm process
each SB EU is about 1 mm2
At the best of times you can be hard to understand, but both of those posts are worse than normal. 🙁
The Tech Report says the prospect of having the encoding circuitry on the H2 2011 parts aren't unlikely either.
