AtenRa
- Feb 2, 2009
- 14,003
- 3,361
- 136
There has been a lot of arguments about FinFETs. The general consensus is you don't go FinFETs.
Samsung/GlobalFoundries(Fab 8) are supporting; 28-nm FDSOI and 14-nm FDSOI, and have said they run faster, and are cheaper to make.Rubbish. Samsung, GlobalFoundries, TSMC and UMC are all going to FinFET. If that's not consensus then I don't know what is.
Because ???
28-nm non-depleted channel Bulk planar regardless of foundry is vastly superior to 22-nm Intel FinFETs. 20-nm non-depleted channel Bulk planar regardless of foundry is vastly superior to 16/14-nm FinFETs regardless of foundry.
The only reason to go FinFETs are for marketing terms 3D. While, ignoring the inherit incompetence of body biasing issues FinFETs suffer from. Yes, you can design around these issues, but how much R&D are you willing to sacrifice. How much density loss and margin loss can you handle with profit that is so little.
Planar or go home, is what the cheap guys say. These guys pretty much point to three solutions; Depleted channel Bulk planar, FDSOI planar, Graphene channel Bulk/SOI planar.
Following Intel into FinFETs, CNTs, and Tunnels are fruitless.
You havent answered the question, why 20nm is vastly inferior to 22FF ????
14nm is a logic node, so no memory.For some reason when I saw AMD mentioned in this my first thought wasn't their APU/GPU products, but their AMD branded memory and SSDs.
Does anyone else think this could be what might get made for them by samsung ?
They have their pros and cons. 20nm should be much cheaper, while 22nm should be much higher performing.Seriously?
Yeah, I had forgotten. Of course, raghu78 will come here with a precompiled pile of garbage and set us all straight on the matterHow do you know? Already forgot the numerous claims from a variety of companies that 20nm would not be cheaper then 28nm
It is inferior to 22nm, at least from a CPU and SoC POV, because its performance and power consumption are simply worse than 22nm. That's what happens without FF at those nodes. 20nm is claimed to be a measly 20% less power hungry, compared to Intel's 50% claim for 22nm and another 50% for 14nm.
Seriously?
It's not necessary to provide sources for common knowledge.Yea seriously, do you got any numbers to compare the two ??? because in Metal Pitch, TSMC 20nm (64nm) is much better than Intels 22nm FF (90nm)
If anyone else got electrical numbers please post them to see why witeken considers 22nm FF vastly superior to 20nm.![]()
Yeah, I had forgotten. Of course, raghu78 will come here with a precompiled pile of garbage and set us all straight on the matter![]()
Also don't forget the fabless + foundry model's cost vs IDM.
I'm still quite baffled that there is no decrease although the shrink is in line with Moore's law.
Intel did not use double patterning on 22nm's metal layers. When there's talk about double patterning, it revolves around the lower level metal layers -- confusing as hell, I know.Intel's spending more than makes up for it though. IIRC, TSMC's 28 nm is way cheaper than Intel's 22 nm.
In cost? Because they went to double patterning, that's why. IIRC Intel is also using double at 22 nm, and is rumored to be using quad patterning at 10 nm... which is why I am skeptical about Intel really doing it without EUV. But we will see.
Doesn't this show that for low power and density TSMC was better than Intel in 2009? Sorry I'm no process specialist :$But here, I'll help us both out:
http://www.realworldtech.com/includes/images/articles/iedm10-10.png?71da3d
On every comparison point that exists, TSMC et al. lose out considerably.
Anyway in the end no matter how better your process is, if your product isn't good enough, you lose, and that's what Intel has been experiencing in the mobile market for years, though they are obviously now getting better.
And when they do go FinFET it'll be with Globalfoundries, not Samsung.28-nanometer node is going to be the dominant volume of node for the next three, four years....
Now, will we move down to Fins? Yes, absolutely, and our next generation products go there and as we introduce them in 16. But we want to do that as you’re catching the cost curve and the yield curve at the right place so that it makes sense for us.
