moonman616
So i built a new ryzen based PC with specs as follows.
Ryzen 1200
Asrock b350 pro4
Zotac GTX 1060 3GB AMP
Zion 8GB DDR4 Ram
Seagate 2TB HDD
Corsair VS550
It boots up and works fine unitl i oc the cpu. I tried various combinations like 3.8ghz 1.32v and 1.33v, 3.7ghz 1.3v but the pc won't start after any oc. I clear cmos and then it starts.
Then i tried using ryzen master, oc'd to 3.8 ghz at 1.32v, ran 20 intel burn test. Also used cinebench r15 and prime95, system never restarted and temps never exceeded 66 degrees. So i thought all was fine and started playing some overwatch and it restarted after an hour.
The lights were on all fans spinning but no display on monitor. Then i pulled out the power cable inserted it again and turned it on but the display still won't show anything until ipress the restart button.
Can anybody help me troubleshoot this issue?
Ryzen 1200
Asrock b350 pro4
Zion 8GB DDR4 Ram
Seagate 2TB HDD
Corsair VS550
