Right turn on a red on a dedicated right turn lane
yhelothar
18,409
39
Do you need to stop at all at these special kinds of dedicated right turn lanes(NOT YOUR AVERAGE RIGHT TURN ONLY LANE).
http://maps.google.com/maps?f=q&sou...026963,-117.835576&spn=0.000506,0.000862&z=20
I could see the argument that you need to stop in case of pedestrians since there is a crosswalk. However, I have witnessed a cop drive right through quite quickly on a red. But then again, it doesn't seem safe to assume that cops are always abiding by the law.
zerocool84
36,041
472
Of course you need to stop if there's a crosswalk there and it looks like there is.. It's a red light unless it says yield.
35,139
In every state in which I have lived, you have to stop before proceeding unless specifically marked or sporting a right hand turn lane with Yield sign.
mugs
48,920
46
Yes you have to stop. If your light is red, someone else's light is green. You must yield to them. Fucking moron.
Proprioceptive
1,630
10
This. It's a right turn, you yield to ANY oncoming traffic. Geez, I wish some of you people had your licenses taken away from you. :rolleyes:
HamburgerBoy
27,111
318
astroidea drives a yellow Mitsubishi riceburner with tinted brake lights. And he's Asian. His ignorance should come as no surprise.
yhelothar
18,409
39
lolol did you even see the google maps link? There's no one to yield to except possible pedestrians.
Logic dictates that you should need to stop, but no one stops there for a red, not even cops, hence this thread.
SO FUCK OFF YOU GAPPED TEETH CUM GUZZLING COUSIN FUCKER.
schneiderguy
10,801
OP is correct, the rest of you are wrong.
http://www.fhwa.dot.gov/environment/sidewalk2/sidewalks208.htm
The right turn lane is often called a right slip lane because motorists are not expected to come to a complete stop at the intersection. Right slip lanes are designed to improve traffic flow by minimizing the drivers need to stop at an intersection; therefore, driver speeds through the crosswalk tend to increase.
"Fucking moron" :rolleyes:
HamburgerBoy
27,111
318
Just because it opens a new right lane that immediately-entering traffic wouldn't be in doesn't change anything. The following right lane isn't a center lane where you can just stop and yield from, and the Google Maps link clearly shows it merging a few hundred feet ahead.
Just look at the fucking diagram you posted you fucking moron. There may be no pedestrian worries, but clearly if you just drive into the perpendicular street on a red light without checking traffic, you have a decent chance of getting into an accident.
EDIT: Ok, I take it back, I'm the fucking moron. I somehow interpreted astroidea's "stop" as "yield".
35,139
Everybody is too hostile tonight. We all need to chill out and reflect on life's beauty. I'm reposting this so we can learn to appreciate the gifts we have.
schneiderguy
10,801
Is the intersection marked with a Yield sign or other indication that a full stop is not required on red when making a right turn?
If theres an island separating the right turn lane from the rest of the lanes it is automatically yield only for right turns.
35,139
Not in any place I've lived. Under those circumstances there has been either a yield sign or a separate stop sign/light to the right of the right turn lane providing direction.
schneiderguy
10,801
*shrug* AFAIK thats the law in California and if you believe the link I posted for the rest of the USA also.
Aikouka
30,383
912
I don't think I've ever met a person that actually stops on those. They may yield (which could require stopping), but certainly not stop outright regardless of oncoming traffic.
LTC8K6
28,520
1,576
OP is correct, imo. There doesn't even appear to be a traffic light for that right turn lane. You aren't making a right on red.
yhelothar
18,409
39
BTW, I'm not even correct on anything because I never even made a fucking claim to begin with before all of you guys jumped on me. I just merely asked a question because I wasn't sure.
LTC8K6
28,520
1,576
Your thoughts about the turn are correct. :D
35,139
In the OP's case there is a merge lane on the street being entered. This is different than the general situation described in the OP. Also note the pedestrian crossing. Regardless of any traffic signal, drivers would be required to yield to pedestrians in the cross walk.
BlackTigers
4,491
Most turns like that, here have a "Continuous right turn with caution" sign, followed by a yield sign.
Simple enough to understand.
LTC8K6
28,520
1,576
That's what I said. You would only stop to yield. Normally, you would not need to stop. This is not a right on red.
