OK, I'll play...
I have no problem with that. JSF is already developed and should the need arise, we can just build more. Cut the 2 older carriers and dock them somewhere. Maybe if needed we can recommission them. Weren't we building another carrier even after the USS Ronald Reagan? Maybe sell some old ones to some friends (Australia, for instance).
This is my field. Has been for about two decades. Let me start by asking two questions:
If you park your car in your garage for a full year, what will be required to make it dependable when you return to it after that time? Even if you have the foresight to "winterize" it prior.
How much more complex a carrier than your car, eh?
You also might consider that out of the carrier groups we have, there's typically five tied to a pier at any given time (crew rest/refit, drydock overhaul, etc). That's quite a bit of ocean to cover with six ships...
Next, regarding JSF, it is NOT developed (only three aircraft currently flying with about five YEARS worth of development ahead of it.) With some SIGNIFICANT technical challenges to overcome, I might add.
The F-22 is fully developed, but that line is shutting down right now. To restart the Raptor would require three years' work before the next one rolled off the assembly line. And that would assume that you could keep the same quality team together that exists today. Aerospace personnel do not pop out of bushes just because you post a job opening.
Incidentally, GAO latest predicts $90mil / tail for the JSF/F-35. For what it's worth, the last buy of Raptors was down to $110mil / tail. (As opposed to that $140mil number you keep hearing about...) Pretty signficant capability difference there, too. Chew on that when you hear Gates/co talking about "saving costs"...
sounds more like Gates' plan to make the pentagon responsible to soldiers in the field, rather than the disconnect that has developed between the two. what real use is large numbers of manned fighters when drones are doing most of the fighting?
Um, no.
Don't compare some Afgan hillbilly hajii to a 2nd rate military (Iran, Pakistan). Or a 1st rate one (India, China, Israel).
We definitely should support the infantryman with everything we have. And we do. Just look at the total % of the budget that goes to the Army/Marines.
But that's not really Gates' doing. No one in the defense industry can really make sense out of Gates. Whatever agenda he has, it's not obvious, and not just about best bang-for-buck.
Next, drones are not air-air weapons. They make great recon and even a decent bomb truck, but that's about it for now. What makes you think we can develop a capable air-air software package when we can't even get a decent spell/grammar check code? Do you really think the ASE types are going to have better code than Microsoft? A drone's coding is only as good as anticipated scenarios. So even the best drones have a man-in-the-loop, for when the programming cant handle the sitrep. To defeat, cut the RF link and then hit it with a situation it's not programmed for. Drones = aluminum showers without wetware. And RF links are so terribly easy to jam. Especially at the source. To quote: "Man is the best computer we can put aboard a spacecraft... and the only one that can be mass produced with unskilled labor. ~Werner von Braun
In short, we are the best. Any reasonable person/head of government realizes this. A logical person will not punch you if they know you will hit back twice as hard.
Didn't stop Bin Laden, now did it?
Oh, and there's an idiot in SW Asia right now that think's it's his Mission From God to bring about the Apocalypse. Dropping an retaliatory ICBM on his head in Tehran would be Right. Down. His. Alley.
Deterence doesn't work when the other guy WANTS to be a martyr...
