Post your AMD FX-8350 Overclock
Greenlepricon
468
I ordered my 8320 but I'm waiting on my thermal paste to get here (gave my last tube to a friend) . It should be here by next week and I'll mess with this chip a little by then.
Greenlepricon
468
The paste is MX-4 and the cooler is a Antec Kuhler H2O 620 with an extra fan for push/pull. I'm looking to find better fans though as I only had spare case fans lying around and they were pretty cheap.
Greenlepricon
468
well 5GHz isn't hard to hit with the Vishera chips it really depends on your motherboard
Oh I'm not too familiar with what these chips can do yet. I haven't done too much research but either way I'll see what I can do with mine and post the results.
guskline
5,338
476
I fooled around with IBT, AMD OD stability test and OCCT and decided I wanted my rig to pass all three as follows: IBT at least 20 runs and AMD OD stability test the recommended 1 hr with all components tested and OCCT for the recommended 1 hr with no errors. Rig three below at stock voltage at 4.334 Ghz (20 x 217) passes all three. When I start to raise the multiplier above the 20 I have to increase voltages and thus power and heat to get more stability. I'm going to do some fine tuning to get my rig to 4.5 ghz. I'd rather have a bit slower and cool than try the 4.8Ghz gig with high heats and questionable stability.
Durvelle27
4,102
Have you run IntelBurnTest, AMD OC stability test of OCCT to check stability? BTW those are very high clocks for air.
Nawl used Prime95 for 3hrs and yes ik there high clocks but 4.8 is just fine as volts aren't that high so not as bad as 5GHz
Idontcare
21,110
64
1) What is a good mobo for OC'ing 8350's?
2) Can the lid be removed?
I suddenly find myself in need of a cpu :hmm:
BD231
10,568
138
Poor vrms, I wonder how long a motherboard could withstand that kind of draw.
Idontcare
21,110
64
Asus Crosshair V Formula/Formula-Z :biggrin:
All right! You twisted my arm and convinced me to give it shot.
Time for IDC to get him some AMD :D :p
Ordered.
PS - expect me to be hitting you up for OC'ing pointers ;)
Shamrock
1,441
567
Greenlepricon
468
Ordered.
Looking forward to this! That way I'll actually know what I'm doing when I overclock ;)
jvroig
2,394
Hopefully u get reimbursed for that garbage.
There was absolutely no need for that. Please avoid inflammatory postings like that, as it serves no purpose other than trolling or inciting flame wars.
Let this thread remain what it is - a place for 8350 owners to post their overclocks and discussions around it.
hokies83
837
Well the 5ghz mark...
It seems ppl are pushing limits of these chips heat and Vcore wise to it's limits We just have to see if Vishera chips can handle the Abuse for any extended period of time.
Yes i know i have my IB at a high Vcore.. but im also 25 c from TJ Max..
Soulkeeper
6,740
156
Have there been any reviews showing total system power usage when underclocked/undervolted ?
google and searching the forum is showing nothing for this, which seems odd to me
