exar333
- Feb 7, 2004
- 8,518
- 8
- 91
This needs to be stickied on our forum.
TDP does not necessarily equate to real world power consumption. In some cases it may as a pure coincidence. In others, real world power usage may be higher or lower.
GTX480 has a 250W TDP but peaked at 272W in Crysis 2.
vs.
GTX780 has a 250W TDP but peaked at 222W in Crysis 2.
That's an incomplete example, at best. TDP is VERY important, especially with all the fuss here on AT people put on compute performance. On higher-end cards like Titan or 7970 that tout good compute performance, you should actual power consumption during high-loads like compute at or around the TDP. The reason it is important is that some AIBs build their cards poorly, and they cool the card just fine for general gaming, but can't keep the card from throttling under true 100% loads.
This article seems to suggest a TDP of 270w, but I would like to get formal numbers and obviously a real-world test of both 'standard' power consumption, like gaming, and all-out 100% load using all silicon areas.
http://wccftech.com/amd-radeon-r9-290x-hawaii-gpu-final-model-pictured-hot-cooler-design/
