NOTICE - PC builders, when asking for input on YOUR projects Please Tell us...
Roguestar
6,045
It should not be allowed to post a thread in GH in which the answer to sticky question number six is "no lol halp plz :D". We're seeing way too much of that. It's not like it's so hard to flick through a couple of the front page buyer's guide articles, or to be honest 80% of the rest of General Hardware, which will have nigh-identical builds. :|
Blain
It's much easier to simply post a thread and have people come to you, than to do all that searchin' and readin'
rahilk
11
This is my first post, so I am sorry if this is not in the correct section. Any help would be appreciated.
I plan on building a computer myself. I am new to this but do have decent computer knowledge.
I have bought the following parts, and want to check if they are all compatible.
Processor - Intel Q6600
Motherboard - GIGABYTE GA-EP35-DS3R
RAM - OCZ Reaper HPC 4GB (2X2GB) 800MHz
HDD - Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
Cabinet - Antec P180
Power Supply - Thermaltake Purepower W0100RU 500W ATX 12V 2.0 Power Supply 115/ 230 V UL, CUL, TUV, FCC, and CB certification
CaesarPua1
10
I'm new to this and someone told me i should post over here.
so far this is exactly wat i got, if u guys think i should get something else instead please say so.
1. Intel Core 2 Duo Processor E8200 2.66GHz (45nm) OR E8400 3.0ghz. (Thinking of getting)
2. Sapphire HD 4850 512MB PCI-Express Video Card (Bought it already read good reviews on it)
3. G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) (Thinking of getting)
4. Antec TruePower Trio 550 550W Power Supply (Bought it already good reviews on it)
5. Antec 900 case or something else maybe u guys could help.
6.Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive ( good reviews bought it)
7. okay now here is the hard part.....were u guys come in. I'm having EXTREME difficulty choosing a mother board from a p45 mother board chip set. I'm looking into these companies asus, msi, or gigabyte with a FSB 1333mhz.
Please post which motherboard wouldn't fry up during OVER CLOCKING, and wat other ram they would recommend. Also post motherboards and DDR2 RAM which people had success overclocking. THANK YOU ALL
Roguestar
6,045
People, when you post telling us you'll be "multitasking a lot" like "listening to music while downloading and browsing the internet", please adjust your sentence into "normal usage". Stuff like ripping a DVD while playing HD video while doing all of the above counts as multitasking. You don't need a quad core because you have office, internet explorer and winamp open at the same time. Even if you have idon'tcarehowmany tabs open in your browser. Modern operating systems are built with the idea you might try and do a few things at once in mind, it's just when you decide you'll need to play some Crysis while transcoding your DVD rip, on a daily basis, that it becomes something to seriously consider when buying hardware.
wangprefix
22
Originally posted by: Blain
PLEASE when POST threads asking for input on system builds tell us...
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
3. What country YOU will be buying YOUR parts from.
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
6. IF YOU have searched and/or read similar threads.
7. IF YOU plan on overclocking or run the system at default speeds.
8. WHEN do you plan to build it?
The above information IS NEEDED, in order that WE can help YOU make wise judgments on YOUR purchases :laugh:
wangprefix
22
my pc will be used primarily for high end animation and secondly gaming, i will be procuring either a 17" monitor or 19". my budget is within the range of 40,000 Rs to Rs 45,000/- (Indian). either MSi board of Asus, crossfire or SLi (one of the better), yes i have read but couldn't find a topic relevant to me. i have no knowledge of overclocking but will do it if it improves my CPU performance withing a week... plz urgent. thanks. also which graphic card would be best in the SLI and CRossfire series ( i mean NVidia and ATI). smps, chipset..etc
wangprefix
22
plz want a solution now, would apreciate it.. in animation i will be using Fusion, Z brush, particles and Liquid.. so plz i want appropriate comp..
wangprefix
22
wangprefix
22
my pc will be used primarily for high end animation and secondly gaming, i will be procuring either a 17" monitor or 19". my budget is within the range of 40,000 Rs to Rs 45,000/- (Indian). either MSi board of Asus, crossfire or SLi (one of the better), yes i have read but couldn't find a topic relevant to me. i have no knowledge of overclocking but will do it if it improves my CPU performance withing a week... plz urgent. thanks. also which graphic card would be best in the SLI and CRossfire series ( i mean NVidia and ATI). smps, chipset..etc plz want a solution now, would apreciate it.. in animation i will be using Fusion, Z brush, particles and Liquid.. so plz i want appropriate comp..:D
muraliveera
hi guys, am really scared where to post this.
I wanna build a system.
I am a Supervisor in a leading animation company in Mumbai(India).
This system is for personal use.
I will be using softwares like Maya, Realflow and compositing softwares.
I will be requiring a good processor as am involved mostly with simulations(cloth,fur,fx).
i dont need a very high end model.
i wanna go for Quad core . q6600 will do
All i wanna know which motherboard/graphic card/Ram will suit this.
i wanna 256/512 mb Graphic card.
abt overclocking i dono much. i will do if it improves the performance.
am planning to build it asap.
thank u guys for ur time
-Murali
joseps75
20
Hello:)
I have $880 save for building my new home pc It will be my personal pc for all around use: Editing photos, Distributed computing for R@H and WCG, internet use, etc. It's my No.1 toy. Please give me some expert comment/advice. This is what I come up with after reading, browsing computer forums. By February 2, I 'll buy all components, dismantle my 2.5 year old dual core box and start my build reusing my old case and hdds, writemaster dvd-rw and all case fans.
CPU = INTEL CORE i7-860 LYNNFIELD 2.8GHZ LGA 1156 95W QUAD CORE PROCESSOR
MSI P55-GD65 Intel 1156 i5 i7 P55 Motherboard, with the new Intel® P55 Express Chipset, supporting the Intel® Core i7
Kingston 4GB DDR3 (2 X 2GB) 1600MHz Desktop Memory, 240 PIN DIMM, HYPERX
Zalman CNPS10X Quiet CPU Cooler
Raidmax RX-630Z Smart Modular ATX Power Supply 630w
Top of Form
MSI R4550-MD1GH Radeon HD 4550 1GB 64-bit GDDR3 PCI Express 2.0 x16 HDCP
Bottom of Form
Thank you very much for you advice /comment.
joseps75
Nov 26, 2005
15,194
403
PLEASE when you POST threads asking for input on system builds tell us...
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
8. What resolution YOU plan on gaming with.
9. WHEN do you plan to build it?
10. Do you have a MicroCenter nearby?
IndianWarbones
I was told I should post here, so I'll just copy what I put in my thread. I'm interested in buying a computer, but I don't have any idea what to look for and where to buy it from or how much it would cost. I'd be using it mostly for gaming. I want to run games like Fallout: New Vegas, Crysis 2, and Medal of Honor on their best settings. If anyone could point me in the right direction, it would be appreciated.
betasub
2,677
IndianWarBones: you were asked to answer the questions from the first post in this sticky thread. Please post your answers back in your original thread. IFAIK, this sticky thread is not the place for personal build requests, merely a template.
