Network & NAS Headache
Mr.Entenmann
I'm going to take a step back, this is the command I just ran; net use [name of nas] /delete, that was correct, if so then I'm stuck on your most recent question ? :)
Elixer
10,371
762
Doing 'net share' shows the shares on the win8.1 machine
Doing 'net view' shows the machines
Anyway, remake the share, and put in username & password to the NAS, and it should work. (Post #17)
Mr.Entenmann
Net Share shows all my drives, including a Remote IPC.
Net View Shows, I assume, the current computer and the NAS.
Elixer
10,371
762
I said...
So, next step is remake the share.
Mr.Entenmann
I'm a little lost, none of the commands you told me to do recently (post #46) worked, why would this just work, don't take me the wrong way, I hope you can understand what I've been though to get this working ? :)
Elixer
10,371
762
You said...
So, you delete the share here...
and I said...
and you said...
So, what is the problem now?
Recreate the share.
Mr.Entenmann
No, no, no. No share was ever deleted, no the NAS share, nothing. I mentioned the error previously; The network connection could not be found.
Elixer
10,371
762
...just wait until you receive my bill for this. :p
Post what net view shows you.
Mr.Entenmann
HaHa :)
Net view is showing, the current PC (Windows 8.1), the PC I'm trying to access the NAS and the NAS, that's all. :)
Elixer
10,371
762
Post what it shows... this isn't secret info you know.
For example:
C:\Windows\system32>net view
Server Name Remark
\\MANGO Darn Fruit
\\ZETA
The command completed successfully.
Elixer
10,371
762
Now do: (simple version)
net use x: \\nasdrive\sharename
(obviously, pick a letter that isn't in use...) and sharename is whatever you are sharing on the NAS.
Then, you should be able to browse x: in file explorer or anything else.
Mr.Entenmann
This is what I did;
L:\\\nasdrivename\[folder_I_want_to_share] (the emotion icon is suppose to be a colon)
System Error 67 has occurred.
The network name cannot be found
Elixer
10,371
762
It would be so much easier if you just copy and paste from the command window, I can't tell what you actually did. (right click on the window, select mark highlight what you need to, then right click again, and paste it here via ctrl-v)
net use l: \\nasdrive\share_name
Where \\nasdrive is what was shown in net view.
Mr.Entenmann
Ok :) I duplicated it exactly as seen in the command window, but if you don't find my typing sufficient :( :)
\\PC-ONE
\\CREX2CLOUD Cloud EX2 Drive
C:\WINDOWS\system32>cd..
C:\Windows>net use L:\\crex2cloud\File_Collection
System error 67 has occurred.
The network name cannot be found.
Elixer
10,371
762
\\pc-one
\\nasdrive Cloud EX2 Drive
Same as I mentioned :)
Argh!
\\PC-ONE
CWINDOWS\system32>cd..
CWindows>net use L\crex2cloud\File_Collection
:mad:
Why are you posting different things than is actually on your system?
Last time, do:
net use L: \\CREX2CLOUD\File_Collection
Mr.Entenmann
I only posted things a little different, none the less same error as I posted in post #68, when entering this;
Elixer
10,371
762
You posted
\\PC-ONE
That isn't the same as I wrote, hence why I said you need to copy & paste, since I have no idea what you are typing.
