Once the pole melts and 1/3 to 2/5 of the population is gone, global warming will be instantly corrected. The Earth knows how to balance itself buddy.
So my property in Denver will increase in value?
Nasa Global Temperature Difference Map 2008-2012
Do you think the oxygenation of the air there will go up once the sea level is higher? Lots of people with that sickle cell trait can't live in Denver.
If I had to guess, your map OP, would be the average of 2008 through 2012 compared to the 1960-1990 climatology. It still doesn't make sense with a 132 year difference of only 0.7C, but that's the best I can summarize for how such a propaganda map was crafted.
Frankly it doesn't make sense at all.
I think it is pretty conclusive evidence that global warming is Obama's fault.the range of 2008-2012 is nothing, its like analyzing where the some decades old stock is going based on 5 seconds of trade data![]()
Without context...this graph is meaningless. Link please.
Does this mean that the statute of limitations has finally run out for blaming Bush for everything wrong with America and the world?Everything that ever was and ever will be wrong with America and the world is Obama's fault.
You and dank69 apparently have a lot in common it seems.Yes, but you'd be just as stupid for blaming everything on Obama as they were for blaming everything on Bush.
Do you understand the concept of "cherry picking"? Do you understand that temperature fluctuation over a 5 year interval is meaningless?The "propaganda" map...
Image Credit: NASA Goddard Institute for Space Studies.
