Finally, a water cooler still relies on air to cool things. The radiator (where the warm water is cooled) still relies on air to cool off. Thus the ambient temperature makes no difference as to which method (air vs water) is more effective.
Ah, I said "for the most part" because I thought the water could have made a difference, but apparently not
Oh well, hopefully everything gets here in one piece and I don't have to ship for a replacement and loose the money I saved.
I was going to look for a different case to get which suited a strict description I had in mind:
- Sleek appearance, like the Obsidian 550D and Bitfenix Ghost
- Plenty of room
- All the latest features like removable HDD racks, tooless HD mounts
- Support for a top mounted H100i (just pull or push fan config, not both)
- Ventelation where it counts (I'd prefer none on the side panels or on the rear apart from the rear exhaust fan; makes good turbulent air flow)
- A nice, huge window on the side panel, so I can see my gear (willing to sacrifice sound dampening on that panel for this)
- GOOD cable management
- All black finish, preferably just steel, don't need any aluminium or anything
- If course some USB 3.0
- Mid tower size
- No bowed out side panels, I think its extremely ugly when it's done to the extent of Corsair's Carbide 500R. Just add another centre meter to the thickness of the case and that'll fix the space issue.
But this dream case doesn't exist
Lian Li might have it, but, well, all their cases are 50% more expensive then they should be.
Maybe I can design it and hand it over to Bitfenix
I'd make one with and without a side panel, like the Shinobi
EDIT: Your 100% correct about the RAM though, should have gone with 2 DIMMs
EDIT AGAIN: I've requested a cancellation of the RAM shipping, I'll change to a 2 DIMM set if it cancels successfully.
