Page 915 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
858
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
LightningZ71
2,704
3,397
There isn’t a lot of ‘translation’ layer going on in servers. If you read the interview I linked you will see that even architectural differences with the same instruction set matter. If software is optimized for AVX512 then those are the x86 CPUs that hyperscalers want.
One of the biggest issues for ARM was a ‘standardized’ plug and play server core with a stable release of Linux.
Volume matters. AMD has a 50% margin for architecture. They don’t develop process. That is the margin that hyperscalers have to license Neoverse cores, customize a processor for their specific loads and develop the software stack. AWS was already fabricating a DPU, Nitro with TSMC in the millions and Graviton was an easy extension with savings on purchase and power.
The translation layer would be for client software running on their provided VM nodes. There won't be much in the way of third party RiscV software that's available for VM clients to use natively, so they'll need a translation layer for their VM instances. In house hyperscalers that just need computer clusters for themselves will use RiscV Linux instances, and recompile any inhouse applications they intend to use on it. It hasn't made financial sense to do that so far, but with ARM trying to squeeze everyone for revenue, that point will be coming.
Doug S
3,856
6,811
Long term, the only thing that ARM's new strategy is going to do is push hyper scalers to develop RiscV products eventually. Eventually, they will need to find cost relief somewhere...
Not sure they would go RISC-V (that ISA has issues) but I agree if ARM squeezes too hard they'll go somewhere else. They can easily port their own stuff from ARM to whatever, and customers who have ARM stuff have ported it recently so another port would be little problem for them if they got lower pricing in return.
If I was in charge at a hyperscaler like Amazon or Microsoft I'd make an announcement of some sort about a backup plan in case ARM gets too greedy. Whether that's RISC-V, MIPS, licensing the rights to use an existing ISA like POWER, or developing their own doesn't matter. Bonus points if multiple hyperscalers go in with a joint announcement. The cost would be minimal (they don't need to actually start designing a chip until they decide to bring the backup plan into action) for them, and the fear of losing their revenue would keep ARM in line.
Geddagod
1,683
1,720
Lion Cove in ARL-H(N3B, 3MB L2 cache) is somewhere around
~4.6 mm^2, right? Those estimates put Cougar Cove on 18A a little below that. Still until something concrete comes will treat those as rough estimates.
Darkmont cluster looking good.
Yes. That's around what I got, but I also didn't include power gates in my measurement, no idea how that dude did his.
Idk how seriously ARM is going to take though unless they actually start making progress on those chips. I'm sure ARM would hear about it if it was just an empty threat, even if it's unofficially.
LightningZ71
2,704
3,397
Instead of going with RiscV, they'll form an industry consortium and develop an "OpenRISC" ISA? I like that idea. It'll only take a few years of lawsuits and licensing to get past all the payments for the most obvious ISA components ever.
OneEng2
1,013
1,212
If Zen 6 is already out there in the wilderness, it will have to be Zen 7 in ~2028?
AMD needs to compress the cadence back to 18 months...
The cadence will always be linked to the process change cadence.... which is getting longer and giving less improvement each shrink .... so if anything, I am guessing the cadence is going to double not shrink.
Then what? Now you are at mercy of fluctuating and declining PC market.
Good point. Not a great strategy to put all your chips on one market ..... that is declining.
Reactions: Josh128
Doug S
3,856
6,811
I'm not suggesting an empty threat. You have to do it, but you ALSO have to announce it, because you don't want to take the chance that ARM doesn't hear about it. You want to them to know it, and to know that you want them to know it. The cost of implementing such a backup plan is tiny versus the cost of ARM turning the screws on you royalty wise.
The other alternative is they could do like Apple and sign a long term deal that specifies royalty rates so ARM doesn't have any ability to raise prices on you. You'd have to agree to more than you are paying now, but if you have certainty of rates for a decade or more you've removed your business risk in that area.
DavidC1
2,191
3,341
So 18A is somewhat more dense than N3B.
Based on this data:
-Darkmont is 14% more dense than Skymont
-It's not a pure Tick, but something greater. It might suggest 20% logic advantage of 18A over N3B
-P core size reductions are no less than E cores. Remember, the P core includes the L2 cache, which increased in capacity by 20% over the predecessor, while the E cores stayed the same. If anything, P cores shrunk a bit more than E cores.
-Official data puts SRAM sizes at, 0.023um2 for HCC, 0.021um2 for HDD 18A, and 0.0199 for N3B HD.
So the possible implication is that Novalake uses N2 on high end because Intel is still struggling to get clocks high up while they use 18A on lower chips because it'll be much cheaper to produce.
5,523
4,910
Based on that the caches aren't scaling. Actually according to official data, N3B's HD SRAM is 16% more dense than 18A HCC, and 6% more than 18A HDD. Darkmont is 14% more dense over Skymont. This isn't pure shrinks either. The cores have uarch enhancements greater than typical Ticks. The P core size reductions do not seem lower than E cores. If anything, P cores have benefitted more. That does jive with Intel 18A presentation that HCC SRAM has shrunk more than HDD over Intel 3. Remember the P core number includes the 1.2x increased L2 cache size, while the E core cluster has same capacity.
i want to see high res image and compare without the L2 blocks for both Darkmont and cougar but it's >3X the area difference for Core+L1 the peak performance is not known for both cores on 18A
DavidC1
2,191
3,341
If we apply 14% density for logic, then the P core size is only possible if it's also using HDD cells for SRAM. Using HCC cells would make it quite a bit greater in size versus Lion Cove. I got 4.498mm2 using the official SRAM number and 14% logic scaling. This would partially explain the lower clocks.
TPU article said this: https://www.techpowerup.com/review/intel-panther-lake-technical-deep-dive/5.html
The Cougar Cove performance core succeeds Lion Cove and brings a series of targeted refinements focused on efficiency rather than higher peak clocks.
The P cores are doing relatively better. The gains should end up greater than Darkmont. This is no excuse. This is likely executing on things they couldn't on Lion Cove(because it underperformed the typical 20% gain).
Fjodor2001
4,663
752
Which NVL-S SKUs would be considered "lower chips" in that case?
Also, any chance they could initially launch NVL-S using N2 for (some of?) the compute tiles and then do a refresh later where they switch to 18A, when the latter one clocks high enough?
Geddagod
1,683
1,720
Much too low rez, but just as important, hard to tell where the die ends/where the scribe lines should be.
4+0 T-T
Previously thought the 4+8 dies would also be on 18A
Don't see why this can't be the case for RZL.
Also heavily dependent on how much IFS is going to push for high performance/high voltage performance instead of focusing on other aspects of the node.
Reactions: Fjodor2001
511
5,523
4,910
4+0 T-T
4+0+4 is the volume config and should be cheap like it only contains 4P Cores and 2P cores sharing 4MB L2 with 2 Ring Stops
RZL is big unknown
DavidC1
2,191
3,341
We're talking Intel here. Them failing to meet project goals doesn't mean they haven't aimed for high performance.
511
5,523
4,910
they should tone down their Higher performance focus and shift to Perf/watt and Density as well
