Page 885 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
adroc_thurston
8,500
11,244
Reactions: Joe NYC
511
5,431
4,854
PTL is good overall they are sharing Panther GPU Tiles with Nova as well there is certainly lot of reuse.
DavidC1
2,171
3,324
Finally using their brains they could have the same SoC tile for Desktop and Laptop ARL/MTL but they had to mess it up.
NVL tile arch is way better they ARL/MTL
Intel has smart people, it's just there's a lot of infighting and constant change of plans. And you add DEI-hiring policies on top... It's like in Warcraft 3 where you have limited amount of numbers and you charm one enemy unit to your side and suddenly the whole battle changes.
If there are 100 people, and there are two sides equally split between 50 people each, it's effectively like there's no one working cause they cancel each other out.
ToTTenTranz
936
1,557
Their own slides claim ~+50% over Lunar Lake. Lunar Lake is ~ Strix Point (being a little generous here) for real gaming fps. Strix Point is ~GTX 1050Ti for gaming. GTX 1080 is 2.5-3X faster than 1050Ti.
Lunar Lake is faster than Strix Point when it's not hampered by drivers, and Strix Point is a lot faster than the GTX 1050 Ti:
And this is using pure raster which, to be frank, few people are using on modern hardware in modern games.
Fjodor2001
4,600
741
For the U-range, what improvements are expected going from Panther Lake to Nova Lake? I wonder if it's worth waiting for the latter.
regen1
360
452
For U-class/4P+0E+4LPE config
P- core changes to Coyote Cove, (E)/LPE- core changes to Arctic Wolf with APX, AVX10.2 support, CPU tile(4P+0E) on 18A-P node
New media engine
Integrated Thunderbolt 5
New NPU
Potential improved memory speed support
Reactions: Fjodor2001
Fjodor2001
4,600
741
Thanks. Not that many improvements with Nova Lake after all then, for the U series. Might go with a Panther Lake based laptop then. But will be waiting for reviews first.
Seems like there are move improvements coming on the desktop side side for Nova Lake, with NVL-S.
Josh128
1,531
2,289
These are cherry picked, and this is GTX 1050 Ti Mobile. Im talking real GTX 1050 Ti desktop. When not VRAM limited, its usually as fast or can be faster than 890M, as seen below.
But I digress, its hard to find decent comparisons with 1050Ti due to the age gap. GTX 1060 desktop is definitely faster than the 890M, and GTX 1080 is ~50%-75% faster than GTX 1060. Panther Lake will not be matching 1080 in real gaming scenarios.
890M vs 1060
1060 6GB vs 1080
W
Reactions: 511
ToTTenTranz
936
1,557
1050 Ti Mobile and desktop have practically the same performance.
It has 4GB VRAM. It's pretty much always VRAM limited in any modern game.
That's a synthetic benchmark. I showed actual videogames.
The more recent games in that video, Forza Horizon 5 and Cyberpunk 2077, show better performance on the 890M. And that's before applying FSR3.
It will probably surpass the GTX1080 when using XeSS at lower resolutions.
The thing with desktop Pascal is it doesn't even do double-rate FP16 so the architecture is completely hopeless even for upscalers, let alone ML-based ones.
Tup3x
1,301
1,438
890M vs 1060
1060 6GB vs 1080
W
Valley has been obsolete benchmark like forever now.
Reactions: Tlh97 and 511
DavidC1
2,171
3,324
I showed you the link comparing gaming performance against 1050 Ti Desktop. It's in average 10% faster. Newer games bigger advantages, with much as 30% gains. It's not my fault you chose to ignore it. Lunarlake is even faster with driver updates and the change to having PL2 at least 1W higher than PL1.
And Intel says Xe3 is >50% faster than Lunarlake. > means Greater than. It looks like it might be 70-80%. At that point it's practically 1080 levels. Even if 10-20% behind it won't matter because it's close enough, since I have one and it uses 170-190W in games to do while Pantherlake can do it at 35W including the CPU. Modern gaming performance is more relevant anyway since older games run fast enough already.
Only real issue with Xe3 is that I have to spend a grand american dollars whereas you can buy used 1080 for $120.
LightningZ71
2,690
3,390
The most relevant comparison points should be the mobile 1650 and the high memory 3050 mobiles. The next step should be the mobile 4060 8gb. Those were VERY high volume parts and are going to be either up for replacement or what most users currently have.
The 890m, when given enough power and cooling, tends to hang with the full spec 1650 mobile parts in most games, especially when implementing FSR/XeSS.
DavidC1
2,171
3,324
And it'll be close enough to RTX 3050 laptop that most will choose Pantherlake.
They said they addressed the issue where too much CPU is allocated, a longstanding Intel problem that existed since Extreme Graphics days. I saw one video where Intel had the core running at 4GHz whereas the faster AMD was running at 1.3GHz for the CPU.
I think a 12 Xe3P Novalake Core Ultra 3 series would be great. But again, too much logic for beancounters.
DavidC1
2,171
3,324
With Pantherlake it also has an interesting feature where the shader compilation is streamed in from their cloud server and then downloaded to a specific folder. It reduces load times and stuttering. Pantherlake is better than I expected.
