Page 884 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Josh128
1,530
2,281
Which does what, exactly?
So ARC 140V gets ~4000 in TimeSpy. 70% gets us to 7000, meaning GTX 1080 levels. That's quite amazing, in a 28-35W power envelope including CPU.
Theres absolutely no way its hitting ~1080 (non-Ti) levels in actual real world gaming scenarios, just throwing that out there. Not even remotely close. Their own slides claim ~+50% over Lunar Lake. Lunar Lake is ~ Strix Point (being a little generous here) for real gaming fps. Strix Point is ~GTX 1050Ti for gaming. GTX 1080 is 2.5-3X faster than 1050Ti.
Reactions: lightmanek
dullard
26,192
4,860
IPU = Image Processing Unit
ISP = Image Signal Processor
It does Auto Exposure:
  • Aberration correction
  • De-mosaic
  • IR Contamination Reduction
  • Multi-Exposure Merge (lets you see dim areas and bright areas in the same image)
Noise and Texture Processing:
  • Spatial noise reduction
  • Tone mapping
  • Temporal noise reduction
  • Sharpening
Color Processing:
  • Color Correction
  • Scaling
  • Warping
Basically, it goes from three of these images (red, green, blue, but only green is shown) to this final image with in real-time.
Josh128
1,530
2,281
  • De-mosaic
  • Tone mapping
  • Sharpening
Color Processing:
  • Color Correction
  • Scaling
  • Warping
But what is it used for, internal webcam image processing?
RTX2080
348
551
See the diagram below as a rumor:
MemoryTimeSpy
8533MT/s62xx
9600MT/s63xx
511
5,424
4,844
So let's be real here the HW might have the potential to match 1080 but it's not being fed enough to do so like mem bandwidth is a big factor.
Reactions: Tlh97 and Josh128
511
5,424
4,844
And power draw. And A+ working drivers.
Yup though it's N3E I doubt more than 50W is needed for the GPU alone to max it out for working drivers they drivers are in lot better state than they ever were I play games on my iGPU as well sometimes older sometimes newer.
Meteor Late
347
382
Is the lineup confirmed? I've seen mentions about Core Ultra X5 338H with 4+4+4 and 10 Xe, I find this the most interesting, should be much cheaper than the top three sku and still looks really good in the GPU department, the CPU core race in the laptop space I find it irrelevant too, that is more than enough core count to do pretty much everything, though the lack of HT sucks no doubt.
dullard
26,192
4,860
I don't think that they are anything but rumors at this point. It really depends on the distribution of bins that are actually found in mass production.
I personally have not been a fan of 4E cores. Implementation of software has been fairly poor on chips with just 4E cores. If I were in the Panther Lake target market (I'm not), then I would seriously look at chips that don't have 4E cores (I'd get either 0 of them or 8). But maybe I'm out-of-date with that now that things have changed.
Lack of HT isn't a big deal since we now have LP-E cores to handle that. Instead of slipping threads into down time on the P cores hoping to get 10% or maybe 20% performance, just give them full reign on LP-E cores to run as they please unhindered.
Another thing to consider is your IO needs. The 10 Xe and 12 Xe CPUs have far fewer PCIe lanes. The USB ports and/or drives will be limited on those laptops.
511
5,424
4,844
LNL has 4P+4LPE though also USB/TB are separate and from the PCI-E lanes
DavidC1
2,160
3,305
Radeon 890M is much faster than that, especially in modern games, because they are more demanding, reflected by the Time Spy scores. In some games like Cyberpunk it's nearly 50% better than 1050 Ti.
It's 10% faster than the Ti according to the average but you'll notice the gains are greater in modern titles, because of micro changes that advantage newer graphics architectures. It might not be at the level of 1080 desktop but 10-20% is within ballpark and I doubt many will notice a big difference compared to say the laptop version. If you assume it's at RX 470 level then 70-80% on top of that gets us pretty close.
Intel says in comparison to the 8MB cache version it reduces bandwidth out to memory by in average 20%. GTX 1080 has just 2MB. Xe3 has 256KB L1 cache where Tom Petersen says and I quote: "I'd say that's the biggest change for games", whereas 1080 has 48KB. The lower sized caches benefit speeding up instructions where as large caches speed up things like textures and even entire frames. If you assume 30% reduction, the 320GB/s on 1080 goes down to an effective 224GB/s compared to Xe3. Not to mention the more modern design.
If the leaks say 62xx for 8533 and 63xx for 9600, how do you suppose 2x bandwidth will change things noticeably? That's a 1.5% change for 12.5% bandwidth. 100% will result in 12% performance which is saying Xe3 is not bandwidth bound, and it won't be that large either because there are diminishing returns.
Hulk
4,064
Credit where credit is due. MLID was pretty accurate on these...
MLID October 6, 2023Mobile
Q4 2025 to H2 2026 second half) launch.
Intel 18A
4+8+4, Cougar Cove, Darkmont E cores, LP E Cores.
New tile layout like Meteor Lake that Nova Lake (NVL) will also use.
MLID July 21, 2023H1 2026
Panther Lake cancelled for desktop
Cougar Cove P cores
Cougar Cove to bring "sizeable" performance improvement over Lion Cove
DavidC1
2,160
3,305
He's often right, but also often wrong. The signal to noise ratio for MLID is lot lower than others like Exist50, Raichu, Bionic_Squash. He may also not filter out information and use discernment as he should be, or he doesn't know how.
Reactions: MoistOintment
511
5,424
4,844
Wow I don't want to stone Intel SoC people to death for once.
A once-in-a-generation breakthrough.
Finally using their brains they could have the same SoC tile for Desktop and Laptop ARL/MTL but they had to mess it up.
NVL tile arch is way better they ARL/MTL
Reactions: DKR
