Page 863 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
That would lead the whole internet into an uproar that they were "promised" one thing and got another.
Just label them as "preliminary" slides.
They can begin such slides with statements like "We are working hard and can't wait to share the final silicon with you but here's what we have so far and hoping to make it even better!".
They have released quite a few slides.
Any URLs?
I found this speculative thingy:
Yeah, they really should release tech slides way ahead of the launch to generate "excitement".
And they can share only the IPC improvement. Final clocks for both CPU core and memory don't need to be mentioned. I don't see what's the big deal about sitting on the tech information so long unless they are afraid to give their competitor time to prepare an effective response. If that's true, Intel being afraid of AMD is something Intel shouldn't even be hinting. It's a bad look for them.
PTL isn't exciting except for hardware enthusiasts and investors who get to see 18A in action and compare it to N3B considering how little the core design changes.
It'll be minimal improvements over the current product stack. Probably slightly better gaming in the H series due to fixed SoC
Actually, if they can keep Lunarlake efficiency on low-moderate load then it'll actually a boon especially if the lower BoM results in some lower cost laptops.
I want to see a true ultraportable that forgets obsolescence focused tech like OLEDs that also reduces battery life. 1080p IPS please! You have manufacturers like NEC in Japan that does this but for the most part LNL's advantages are absolutely killed by 1440p OLED displays. The advantages in battery life for LNL over both AMD and Meteorlake is greater than 30%.
agreed a reason Apple haven't switched to OLED on Mac. Tech tuber will always say Great OLED display but won't say It will kill battery quicker.
agreed a reason Apple haven't switched to OLED on Mac Tech tuber will always say Great OLED display but won't say It will kill battery quicker.
I'm more bothered about having a finite lifespan. It's like SSDs, but worse. Same with electric cars. SSDs at least last long enough on average use. Electric cars turns your fuel tank be the bottleneck in obsolescence and have trash resale value, and OLEDs will eventually have significant burn in so in average use it'll likely die.
And OLED's flaws are way less suited to laptop use than to smartphone use. Way more static pixels for much longer periods (and the "pixel shift" OEM stuff is more gimmicky than anything).
I love how OLED screens look, but I'd prefer if we started getting more MiniLED laptop screens, it gets you to like 95% of OLED contrast and image quality without the drawbacks.
Mini LED with Anti reflective coating for me hate glossy display
OLED burn in is overstated. I still have 4 2013 & 2014 model Samsung plasmas in my house, most of them get daily use, and they all still have stunning pictures. The advantages of OLED over LCD are 100% worth it over any disadvantages.
But on Large Screen they are a power hog and if some website is not using darkmode with full brightens it consumes mor epower than SoC xDd depending on the scenario.
Yea... no. I still have the NEC monitor that I bought it used off Craigslist and used it for few years after that. It came out in 2006. It should last if you need it too. Also, Plasma is not OLED.
I hate the whole move to stream-everything, subscription-based, replace every 1 year or 2, proprietary, difficult to repair mentality. Look at videos by Louis Rossman and see how greedy and borderline evil those companies are in a quest to extract every cent from you and just because they can. The trend has been in household appliances like refrigerators, dishwashers for years now. Difficult to repair, expensive, garbage that doesn't even last 10 years. The whole quest is basically to extract every bit of control away from you in the worst kind of dystopian sci-fi all combined together.
It's one thing in the electronics that can be often replaced by 10 cent capacitor or something to fail. It's another when the screen itself is the issue. They should go ALL open source and upgradeable like Framework. Once the company is successful enough, sell all the proprietary parts at a *reasonable* price, give freely all schematics.
I still have working Sanyo CRT TVs that I purchased in 1996 and multiple large Trinitrons manufactured from 2003-2005. All still beautiful, all still working. They are also susceptible to burn in. LCD is not some unicorn that never fails. All can fail. My dads 4K Vizio died at only around 6 years old. Screen failure, started with stuck colored pixel rows and progressed to failure.
LCD liquid goo displays suck for contrast and motion. Emissive display tech is superior. Theres nothing to debate. Ive repaired 3 of the plasmas in my home, also a 65" LCD whose backlight LEDs turned blue. None of the screens are repairable on any display type, all are replaceable though.
