Page 862 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
939
851
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
DavidC1
2,101
3,221
Strix Point's iGPU begs to differ about being memory bandwidth limited. Despite being twice as large as Kraken's iGPU, it is FAR from being twice as fast.
I stand corrected.
However, except for the eDRAM-less Iris parts way back ago, Intel iGPUs were never limited as AMD GPUs were, unless you are putting single channel memory. Plus, Pantherlake is a new architecture and if @511 is right, it shares the LLC with the CPU. 50% extra is not a huge issue in any terms. PTL also supports faster memory too, no?
@511 Who said Panther Cove has clustered decode?
DrMrLordX
23,167
13,257
More like Ayyy Eyeeee
That's exactly what kept Strix Halo alive. Kinda makes me wonder if or when we'll see some kind of Intel miniPCs sold with 64GB and 128GB configs. Would be an interesting dumping ground for some Nova Lake variant. Maybe.
511
5,336
4,751
Trust Me Bro /jk
Sources and if you look at it they are sharing L2 Cache similar to E core team and cluster decoding cause 8 Wide Core like LNC is too Area heavy and 10 Wide would be nuts so Cluster Decoding like E cores
coercitiv
7,461
17,807
So are we getting a token/paper launch for Panther Lake at the end of the year? I know availability is set for 2026, but I would expect Intel to pretend their assurances about Panther Lake being a 2025 product were real.
I just want the tech talk, they can launch it whenever :p
511
5,336
4,751
Same I wanna see the iGPU Arch and the PnP comparison of Cougar Cove vs LNC and Skymont vs Darkmont.
19,208
Yeah, they really should release tech slides way ahead of the launch to generate "excitement".
And they can share only the IPC improvement. Final clocks for both CPU core and memory don't need to be mentioned. I don't see what's the big deal about sitting on the tech information so long unless they are afraid to give their competitor time to prepare an effective response. If that's true, Intel being afraid of AMD is something Intel shouldn't even be hinting. It's a bad look for them.
RTX2080
347
551
According to leaker Golden Pig Upgrade, Pantherlake early enablement program(EEP) is postponed to 2026 and very likely the availability for consumers would be 1Q later. So possible paper launch might be during CES.
Reactions: coercitiv
19,208
@511
I just had a genius idea on how to use up the available Arrow Lake desktop CPUs that no one wants.
Intel should introduce the briefcase form factor. It looks JUST like a briefcase. Inside there is a mini-ITX mobo and desktop CPU and a removable battery pack plus a removable display giving users the flexibility to replace the bog standard display with miniLED or OLED or AMOLED if they like. Plus, small compartments for SATA SSDs and NVMe SSDs that you simply plug in vertically. The keyboard and touchpad should also be replaceable for people who want something more expensive. A thin and sturdy tray should come out from the right or left side that can support a mouse pad.
Here's the really genius part. The bottom of the briefcase has the CPU and mobo but the back side of the display has the GPU. Thus it is thermally isolated from the CPU and it will be able to consume up to 250W if needed and that heat will be transferred away from the user.
Without AC power, the CPU will run at 1 GHz or lower and the GPU can also be similarly either downclocked or only the iGPU is available in battery mode. Plug in a power cable and suddenly the whole machine comes alive!
How's that???? File a patent now and name me as your partner. Let's become billionaires! :p
Reactions: 511
DavidC1
2,101
3,221
Trust Me Bro /jk
Fatter decoders exist even though significant amount of code can't really do high ILP because it helps during peaks when it can actually reach that high. And it requires a major redesign which is not too realistic in 2027 for something that'll be replaced soon.
DavidC1
2,101
3,221
0% for P and 3-4% for E?
I'm interested in whether they did improve efficiency for the E cores like that Intel reddit guy claims and what the Celestial architecture brings.
511
5,336
4,751
New MLID "Leak" Panther Lake is being nicknamed "Pathetic Lake" by board partners testing it.
It's MLID he has vendetta against Intel I don't believe anything he says. Only take his core count leak seriously nothing else.
MLID:
If he hypes a Intel product it's bad or is getting cancelled.(Royal Cove/Arrow Lake)
If he doesn't or says negative thing regarding it it's gonna be fine.
Josh128
1,508
2,260
The Osborne effect.
dullard
26,187
4,853
They have released quite a few slides.
The issue with sharing an IPC improvement is that it is subject to change. As BIOSes are developed, microcode is written, errata are addressed, temperatures are optimized, stability is improved, etc, the final IPC changes slightly. The change is not mind-blowing. Usually it is a percent or two here or there. Sometimes worse, sometimes better. But if one chip is close in performance to another chip, then these last minute tweaks can certainly move one chip from a slight lead to a slight loss. That would lead the whole internet into an uproar that they were "promised" one thing and got another.
Reactions: 511
