Page 864 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
940
852
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
ToTTenTranz
908
1,519
Even if CPU performance and efficiency underperforms, Panther Lake's 12x Xe3 iGPU with 16MB L2 plus access to 18MB L3 seems really promising.
New MLID "Leak" Panther Lake is being nicknamed "Pathetic Lake" by board partners testing it.
If that NPU really is trouble, then Intel should just disable it. The iGPU alone should be able to reach above 100TOPS by itself, when making use of the XMX units.
511
5,342
4,755
That's MLIDs Claim
120 TOPS for iGPU nearly the same as RTX 4060(131 Int8 TOPS)
Reactions: ToTTenTranz
Doug S
3,797
6,726
OLED burn in is overstated. I still have 4 2013 & 2014 model Samsung plasmas in my house, most of them get daily use, and they all still have stunning pictures. The advantages of OLED over LCD are 100% worth it over any disadvantages.
Uh, you realize plasma is a different thing than OLED, right?
The main issue with OLED is blue pixel life being shorter than red/green. Pixels of different colors fading at different rates accounts for what we observe as "burn in". That's what tandem OLED is intended to solve, at least until there is some breakthrough in blue pixel lifetime.
Thunder 57
4,246
7,041
I'm more bothered about having a finite lifespan. It's like SSDs, but worse. Same with electric cars. SSDs at least last long enough on average use. Electric cars turns your fuel tank be the bottleneck in obsolescence and have trash resale value, and OLEDs will eventually have significant burn in so in average use it'll likely die.
They might make sense for TV's where no parts of the image are static but I'm just fine with IPS for now.
And suddenly what I wrote above might be bunk. I wasn't aware this was the problem. But hey, even more time for the tech to mature and hopefully get cheaper before I have to think about it!
19,209
That's why LG uses WRGB pixels in their OLEDs (or at least used to. Not sure about their current line-up) to prolong the blue pixel's life.
19,209
It mostly works fine for three years minimum if you take good care (let it wear level by not turning it off completely and letting it "sleep") and watch varied content. It's perfectly fine to use as a secondary "premium viewing experience" display. Not as a primary work and play display.
If you have never used an OLED, it makes a kind of annoying low frequency whirring sound when it's scrubbing the pixels during sleep mode.
Thunder 57
4,246
7,041
Three years is garbage for a display. An expensive one at that, compared to IPS/VA.
Reactions: Thibsie
19,209
It's not that expensive anymore. If you absolutely love HDR and vivid colors and just amazing visual quality, it's worth the price even for 3 years. Besides, that's just my estimate. No one has enough time to consume content eight or more hours a day so it will definitely last longer with proper care. Don't buy it though if you are not accustomed to viewing content in a dimly lit room. It doesn't look its best in bright ambient light. For bright room viewing, QNED is probably the answer. Or maybe QD-OLED.
Thunder 57
4,246
7,041
Unfortunatly everything is expensive when you have multiple medical issues :(.Most of it is managable but I just got a tooth problem not even a week ago and insurance does jack all for it.
poke01
4,761
6,095
September, no Geekbench panther lake leaks
What they made this generation so secretive cause the performance sucks or what…
Thunder 57
4,246
7,041
Maybe they plugged all leaks 🤣. Who knows. Tom's has an article where they say Nova will have a limited launch late next year (K series?) rolling into 2027 for volume it sounds like. 18A can't be that late, right? Or is Panther Lake N3B and I'm having a brain fart? I thought at least part of PTL was 18A.
511
5,342
4,755
NVL-S will launch End of 26 rest CES 27
Maybe Intel tightened the leash around Partners
Josh128
1,508
2,260
Uh, yeah. My point is that modern OLEDs are acceptably resistant to burn in provided you dont watch CNN all day or play a game with a HUD in the same spot for 4 hours a day for years, and the image quality and motion clarity is unmatched by LCD.
ToTTenTranz
908
1,519
5,342
4,755
Well it's the claim from anyone looking at the specs. Intel is putting a lot of die area on Panther Lake's iGPU.
If you look vs LNL Xe2 it's 35% Area increase for 50% more Xe3 cores and 2X L2
There are lots of changes in Xe3 and N3B is slightly denser than N3E as well so it's PPA is improved as well
deasd
609
1,043
This is from yesterday:
for an example and reminder, a bench leak should be something like this below:
Meteor Lake's bench leak was found 7 months ahead of its paper launch.
511
5,342
4,755
I can think of only one reason Intel has tightened things regarding leaks and stuff.
ToTTenTranz
908
1,519
CPU doesn't so many Drivers and software xDd especially considering it's LNC on 18A
Were people really expecting Cougar Cove's performance and efficiency to be better than Lion Cove's? It looks like a small evolutionary step at best.
Same performance as Arrow Lake, same power efficiency as Lunar Lake. That's really all there is to it.
Intel isn't bringing any significant CPU performance boost before Nova Lake.
Reactions: fastandfurious6
511
5,342
4,755
Efficiency Yes performance maybe maybe not
What would you think of ARL-H(45W) performance at 25W and similar battery life to LNL with much better GPU And Uncore than ARL not to mention new Display and Media IP
19,209
It's almost a boring generation. No one is interested in leaking it.
People are almost embarrassed and ashamed to leak it. They are like, I don't want my name (even just online one) attached to THAT!
ToTTenTranz
908
1,519
I'm looking forward to see if MSI will launch a Claw handheld with Panther Lake. Unlike anything else we have right now, it should bring a significant gaming performance upgrade from my current Legion Go.
Unless one of the big players launches a STX Halo option, that is.
Josh128
1,508
2,260
Absolutely, as 18A was supposed to be the absolute best process available. Now people are saying its ~N3. I dont buy that.
