Page 846 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
19,210
They'd have been better off doing a large monolithic die on Intel 3 with updated P and E cores. But by how much we'll never know.
They probably had to rule out a large die on Intel 3 because their testing showed that the yields would be abysmal. Not worth it for the prices they have to sell consumer chips at. The crazy thing about Pat's 5N4Y plan was that they barely got any time to refine the nodes to increase the yields. It was just burning massive amounts of money to hit goals for better optics and best yield outcome wasn't one of those goals.
Reactions: Joe NYC and Thibsie
Win2012R2
1,325
1,361
GNR has 600mm2 Intel 3 dies lol and Intel 3 Yield is pretty good it already matched Intel 7 yields last year
How do you know if yield is pretty good or not? Gross margins are way down in DC, and AMD is not exactly selling cheap server chips.
511
5,386
4,810
that's due to selling SPR/EMR Cheap to maintain market share and GNR/SRF is in ramp mode
Reactions: DKR
Win2012R2
1,325
1,361
How do you know they are sold cheap vs yield issues make gross margins tank?
I certainly don't observe cheap Turins or Xeons - in retail and OEM channels (such as SuperMicro).
511
5,386
4,810
OneEng2
981
1,192
Intel 3 is okay, but for some reason they skipped over it for desktop CPUs
I am wondering if it isn't price as mentioned above?
Why aren't they frickin' backporting ARL to Intel 7 and running it at 6+ GHz? Sure, it will run a lot hotter but plenty of folks don't mind the heat generated by 14900K
A lot of folks weren't too happy with returning the 14900K when it burnt up though.
I think this is likely the problem.
I am guessing that Intel has been creating designs that rely on incredible feats of engineering from the foundry. This worked really well for decades .... until it didn't.
It is my guess that Intel must change their entire philosophy from design up.
For Intel, they need to start with the available foundry services and price point and then design around that IMO.
I have been saying for years that it is easy for Intel engineers to best AMD when they have such a big process advantage to work from.
Turns out that once this advantage went away, so did the performance advantage.
Even today, ARL can't best Zen 5 from a full process advantage (N3B vs N4P). Imagine how badly ARL would be pummeled by an N3E Zen5 desktop processor?
Hopefully this is the kind of things being discussed at Intel.
511
5,386
4,810
i think it's more of a their chiplet issue than a design issue. ARL still beats Zen5 in many benchmarks and LNL is a very good product on N3B using the same cores but different Uncore also N3B is more like half node ahead vs N4P. Their axing of HT still baffles me
Reactions: DKR
511
5,386
4,810
Supporting graph because people will be like, WHAT?? :D
Phoronix bench has AVX-512 which increases the average it's not that far apart
and for this Phoronix hasn't updated their 6980P Benchmarks since the release there have been fixes just for reference also OpenVino was updated with GNR specific optimization it's not even close in those with updates
19,210
One would think that Intel would beg Larabel to retest since Linux is what most server CPUs run. How incompetent can Intel be for letting their prized server CPU appear castrated in Linux?
511
5,386
4,810
@511 What does your spidey sense say about Arrow Lake Refresh hitting 6 GHz or higher?
i am not even hoping for 5.8Ghz. Most like validated D2D/NGU/L3 Clocks for 5-7% perf improvments that's it
well Intel be Intel
Don't keep us in the dark. Share the numbers.
Reactions: DKR
DrMrLordX
23,199
13,287
Maybe. Intel 3 should have been mature enough (remember it's just a + node for Intel 4) that yield issues weren't going to plague a desktop chip. 8P + 16e on Intel 3 - even if it was just a shrink on Raptor Lake or maybe an update with slightly different cores (Redwood Cove + ???) - wouldn't be that big. The main thing would be to get rid of the voltage problems in Raptor Lake that caused problems there, update the product stack, and maybe maintain the high clocks of Raptor at slightly lower power. Arrow Lake's performance regressions (there were some) made it uncomfortable.
That being said, Intel 3 relies on EUV meaning that Intel is capacity-constrained to some extent. Such a hypothetical desktop chip would be vying for wafers with Granite Rapids and Sierra Forest. Intel probably gets better margins on Granite Rapids, and in turn that product needs to pull in as much cash as it can to make up for the firesale on Sapphire/Emerald Rapids.
Yup, an updated LGA1700 product on Intel 3 would at least have distracted people from those problems.
MS_AT
931
1,848
Well, you could have picked up better numbers.
The ones you have chosen look poor. 128/96, 33% more cores for Intel makes it complete the benchmark faster by 25%. In the 6781P vs 9575F it does take 8% less time but uses 25% more cores. The FPS scores where it scores 2x as fast as Turin would have been better showing... just saying;)
Reactions: Tlh97 and 511
DKR
21
34
51
Also let's not forget that ARL-U mobile chips are basically MTL-U on Intel 3. And Fab34 is not fully completed construction per Intel's 10K. I think that refers to tooling & not shell construction. it's only partially equipped with tools. I am also pretty sure Intel 4 line is same as Intel 3. So other MTL chips are also being fab'ed in there. So Intel 4/Intel 3 is capacity constrained!
511
5,386
4,810
it's just GNR consuming Wafers ARL-U requires meme wafer count it's a 40mm2 Intel 3 tile with a mature node they will be dishing out good enough dies for that. A single GNR die is 598mm2 a Intel 3 wafer will only have 50 good dies they're doing binning and other stuff to get yield up for this large die but still you only get 50-51 good dies aka approx 17 Full Fat SKU per Wafer and Intel ships Millions of Xeons every year depending on the SKU GNR is a die hog.
One advantage of smaller die is you get more usable area out of a wafer.
Reactions: DKR
Josh128
1,514
2,263
Those are gigantic dies, I didnt realise they were that huge. No wonder AMD is destroying them in profit per CPU.
