Page 844 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Khato
1,370
468
They want flexibility as well in terms of their schedule 18AP is later launch than N2 for Volume. Initial volume will go to DMR
I was wondering how long it'd take before someone remembered that Intel still has about 3/4 of server CPU sales. And 100% of Xeon CPUs are Intel silicon. I'd argue that Intel using their own process for the products which are going into the most competitive and lucrative market is a pretty good indicator of relative performance. Compared to the consumer market where maybe 10% of sales are influenced by actual performance metrics more than marketing?
Reactions: MoogleW
Geddagod
1,672
1,706
I think N2P will be for Zen 6 for next year for sure, I just think N2X for a Zen 6+ Vs RZL in 2027 is plausible.
For AMD to actually take advantage of N2X, they would likely have to change the physical design of the core itself, and I also wonder how much of AMD's N2P node would already use features of the N2X node.
Conspiracy theory- the reason why Techinsights is claiming that Zen 5 is on N4X, multiple times (so not a typo), while AMD themselves only claim N4P, is because the custom node AMD uses actually already has many back-end features of N4X.
Geddagod
1,672
1,706
Client as a whole has been more lucrative than server, has been the case for a while, in terms of operating income and revenue.
Can this logic also be applied to GNR using Intel 3 vs ARL using TSMC N3? Have we been mistaken and Intel 3 was better than TSMC 3nm all along?
19,210
The single 96-core EPYC 9655 Turin processor was also often running similar or only slightly behind the 128-core Xeon 6980P Granite Rapids processors.
If a 128-core Xeon CPU on Intel 3 can't create comfortable distance between itself and an Epyc with a 32 core deficit, there is no way Intel 3 is superior. Had it been, the Xeon would've had higher all core clocks and no way could an Epyc give it a run for its money.
511
5,408
4,819
Not same design it's Golden Cove++ vs Zen 5. You need same design with proper DTCO with the cores
Reactions: DKR
Geddagod
1,672
1,706
Zen 5 has no appreciable perf/watt uplift over Zen 4 in specint2017 at the power level these cores run at, and Turin Standard and GNR perform pretty much the same under a 500 watt TDP there too.
Intel 3 and N4P then are pretty comparable from that product perspective at least, though Intel should have some advantages using better packaging and fewer, larger chiplets to save on power.
511
5,408
4,819
But can you proof that Redwood Cove is better than Zen 5 as a uArch which is clear as Zen 5 is superior than RWC.
Reactions: DKR
Geddagod
1,672
1,706
Well that's why he also have the cushion of GNR having better memory support, better packaging, and fewer, larger tiles.
GNR has quite a bit of advantages that can offset any sort of core architectural disadvantage that would present itself vs Zen 5, at extremely low power levels (which Zen 5 has esentially no improvement over even Zen 4).
But the perf/watt argument is honestly the weakest point against Intel 3 not being a N3 contender, since tbf even N3 doesn't seem like a massive uplift over N5 there. What makes it look really bad is the area considerations. RWC is so much larger than Zen 4 that simply architectural/physical design can not possibly explain the margin.
And yes, it may use HP cells sure, but it is very possible to make an area efficient core while using larger libs, just look at the X925. It may also be the case that Intel had to use HP cells on Intel 3 to get the same perf/watt (at the medium-high end of the curve) and Fmax as AMD could do on HD with N4.
Reactions: MoogleW
oak8292
201
217
Every Intel node in the last 10 years has faced delays, yield issues and had subpar PPA, you can't blame it all on a single decision.
There are delays and there are failures. I would put 10 nm in the failure category, it wasn’t just a delay in improving yields. There was enough time for full node development. Intel 4 nm went with enhanced Cu over Cobalt.
DavidC1
2,154
3,293
Wouldn't it also really depend on *why* Intel is outsourcing most NVL-S's compute tile?
If the issue with 18AP is an uncompetitive fMax with N2, but that fMax still exceeds 5Ghz, then what market besides Intel and AMD desktop CPUs does this limitation impact? 18AP could theoretically be perfectly fine for every application except for high clocking desktop parts.
Why are we expecting Apple/Nvidia to hobble their own products by being forced to use Intel process?
Intel claims 18A is not mobile competitive, and they say 18A-P is. Can we trust them on that? The same slide showed 18A-P is suitable for HPC too. If the 15-25W processors can huff and puff to barely reach 5.1GHz, and we expect ARM processors to reach that range, then it's plausible that it won't reach the targets Apple/Nvidia wants either, cause they operate at much lower power targets for Apple and Nvidia needs high density.
Simply put, if it's good enough for Apple/Nvidia, it should be good enough for Intel. Either that or 18A-P is being used for super low end Apple/Nvidia, which won't materially affect IFS enough to be profitable. I don't see a win here in any scenario.
12 years lol 14nm has delay as well it's not an easy task to fix this mess that was created
14nm? Try 22nm. It was 6 month delayed too.
If 10 nm had met frequency and yield targets only a year late versus what actually happened this whole conversation could be on its head. AMD may be dead as a result of being squeezed between Intel still holding the high ground and ARM products from below. Optane would still be a product. Aurora supercomputer wouldn’t have forced Intel to TSMC and Intel may have had a bigger presence in AI.
That's the thing. For 10nm to succeed, it wouldn't have met the lofty density, performance, and power targets. They simply aimed too high, thus failed. It wouldn't have had cobalt, it wouldn't have had the density, and maybe even Foveros wouldn't have been ready either. Which came to be the end result anyways, but still. 10nm wanted 2.7x density after doing 2.7x density on 14nm, which ended up being mostly useless since the P core team only used standard 2x scaling as they did since Pentium in 1995. Without either scaling Intel 7 wouldn't = N7, instead original 10nm would be "N8.5".
Reactions: Thibsie
OneEng2
992
1,196
The chip design company is dying too, the only reason this is not extremely obvious is because IFS is dying faster.
For decades (yes, I am old), I have thought that the Intel foundry was the jewel that was keeping poor Intel designs alive.
Only on the back of huge failures did Intel design something really good. Without the foundry keeping so far ahead of the rest of the world for so long, the designs would have frequently been uncompetitive.
Spinning off IFS into a jointly held independent company would actually be a smart idea, which is why I suspect they won't do it.
Maybe it should be a joint partnership with the government.
Why would they let someone else milk the 18A cow if they have invested 100 Billion $ ?
They would rather give up leading edge logic development
To not lose another 100 billion. They can still have a minority stake, of course.
This exactly. I find it amazing at this point in time that anyone would consider it a good idea for Intel to do more of what has ruined them.
AMD has same revenue and more profit than Intel in servers despite lower unit sales. Intel is selling things at cost to keep market share.
Agree. I also think that in the past, Intel was able to buoy their client and other areas with the big profits rolling in from server. They were also able to make package deals with MB makers to sell other Intel chips with their CPU's .... and they were able to keep AMD at bay with exclusivity agreements with big OEM's.
In 2024, AMD made 57% of its profit from server and only 14% in Client.
It is no wonder that AMD has stated many times that it's designs are "Server First" in nature.
DrMrLordX
23,201
13,289
it is confirmed
Oh dear. That certainly is interesting. Is it the same situation with Clearwater Forest?
Intel has been following the trend of lower margins to maintain market share since late in Cascade Lake's lifecycle. It has gotten worse over time. You gotta wonder how much Granite Rapids is discounted.
511
5,408
4,819
No that is 18A. We will get more details on Clearwater in 10 days Hotchips
GNR/SRF are still in ramping phase so they can't use them much for discount GNR/SRF Cost structure is not horrendous for both Intel Products and IFS
Reactions: DKR
DavidC1
2,154
3,293
Granite Rapids' situation would be better if it wasn't for the mysterious lack of scaling when more than 1 processor is on the board. That makes it go from a 15% difference to 40%. To a degree, it also affects Sierra Forest too.
Reactions: MoogleW
511
5,408
4,819
I actually didn't get what you meant
DKR
21
34
51
I believe he is talking about GNR 1P vs 2P performance. In the Phoronix Turin launch review, GNR 1P vs Turin 1P is roughly -20%perf/watt on geomean but that gap increased to -40% for 2P vs 2P. That was weird, all previous Xeons (all EPYCs too) had consistent>1.5x scaling for 1P vs 2P but GNR only had ~1.2x scaling. I think GNR being a new platform was being buggy vs Turin still on same mature platform as Zen4. It probably is fixed now but no updated reviews yet.
There were other issues with GNR in that time frame that made Phoronix ignore some benchmarks for that comparison too as Intel team was working on it at that time (Michael said so in a reddit post).
511
5,408
4,819
those have been fixed from what i know
Reactions: DKR
OneEng2
992
1,196
I haven't heard or seen anything that indicates there was any fix. One would think that Intel would be shouting it from the rafters if they had a big performance increase and that reviewers would be wanting to draw attention to their site with new articles showing the big improvements.
At least this is what has generally happened over the last 30 years I have been following this technology.
reaperrr3
172
494
22nm already wasn't that great in terms of PPW improvement and clocks, despite FinFET.
TSMC and Samsung took longer to get to FinFET, but TSMC 16FF(+) and Samsung 14LPP (which were both really just 20nm FinFET) allowed significantly higher clocks vs. 28nm, no such thing for 22nm vs. 32nm on Intels end.
They were just so far ahead of everyone else in process tech (and ahead of AMD in uArch) at that time that it didn't hurt them, but the execution downturn already began with 22nm, in my opinion.
32nm+Sandy was their peak, they went downhill after that.
Reactions: OneEng2
511
5,408
4,819
it's still debatable everyone took a hit at FinFet many companies stopped doing process for FinFets
DavidC1
2,154
3,293
No, the gains were actually great as Intel said, 37%. The 22nm execution loss wasn't in transistor performance, but that it was 6 month delayed.
The reason most have sour memories regarding 22nm is because later Intel said the 37% number applied to Atom Silvermont. It allowed them to clock at 2.4GHz from about 1.8GHz, exactly 37%. The consequence of that is at Ivy Bridge power levels, we got maybe 5% at max.
That's why I criticized Intel saying they crippled their bread and butter to juice up contra revenue Atoms. It's just a matter of shifting the VF curve. In 14nm and 10nm, and probably Intel 4 and 18A as well, they shifted the curve to favor high power parts again, hence why they said it isn't until 18A-P it's ready for mobile.
Note that 14nm's 2.7x density gains were applied to Atoms as well. Whether due to lack of execution on P core team or not we don't know, but P cores got traditional 2x scaling while 14nm Airmont got an impressive 64% core size reduction, or 2.7x. If Intel survives through this debacle with E core team's Unified Core, maybe this focus on Atom would turn out to be not so bad a thing after all. I argued with Hans De Vries and others that Airmont's core size allowed an equally performing x86 core to be sized as competing ARM cores, something that should have surprised many. Assuming the E core team is mostly intact, they are the ones with the potential to have a competitive x86 core, not P core, and not even AMD. And competition I mean as in top core, not just top x86.
