Page 958 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Joe NYC
4,181
5,742
MS is not a real player. Acer is tiny.
AMD key partners are HP/Lenovo/ASUS. All have or are rolling out stxH devices.
Lenovo - I was not aware of. Finally, some signs of life.
BTW, I meant Dell (rather than HP) not offering Strix Halo.
Q1'25 was ARL-H, and Raptor had the same 1t anyway.
Intel did other things, such as added LP cores, added NPU (in order to stay in corporate PCs), improved the iGPU.
But Intel could not ship volume because of lack of EUV capacity, most of Intel fabs could only churn out Raptor Lake. That was the opportunity AMD had, but did not take advantage of.
you have no idea what you're talking about.
TSM price hikes alone are thinning whatever margin laptop parts had.
Which makes it even more important that the design printed on the silicon is the most competitive, not stale.
If the price of silicon went up, but the quality of the CPU is still the same, it is not a good recipe for success.
Reactions: MoogleW
adroc_thurston
8,434
11,166
Dell barely started offering AMD in normal commercial.
that's nice. where's the CPU perf? this is 2026, not 2023. QCOM is breaching 4k GB6 1t.
no, it means you gotta run tf away from that market until you're out of breath.
mikegg
2,110
653
I halved my CPU's clockspeed in BIOS, and ran the test again. The LCP took 780ms, which is only took 7% longer than stock. So it looks like chrome devtools CPU throttling is inaccurate, just not in the direction you expected.
For GPU rendering, input, OS scheduling, etc. I don't see your point. We are discussing Intel Laptop CPUs scoring lower in javascript benchmarks. They might also throttle GPU or have bad input latency, but I've seen no reputable claims for that.
That’s because clock speed and performance isn’t linear. Chrome dev tools literally divide the JS performance by 4.
For GPU rendering, it’s relevant because we are talking about battery life while browsing here. Intel is going to throttle the entire chip, CPU and GPU.
511
5,394
4,816
it's better for intel to keep working on a in house Linux Distro for their hw and support it and focus on it rather than rely on microsoft same for AMD microslop has been making windows bad
511
5,394
4,816
throttling is power profile dependent you don't get throttle on performance mode you get it on balanced so there is that
mikegg
2,110
653
Trace the replies back. No Youtuber ever tests battery life on performance mode. It's always the default mode.
PS. Windows does throttle on performance mode as well.
coercitiv
7,470
17,850
Let's do the data thing:
Header Cell - Column 0Qualcomm Snapdragon X Elite: Plugged in (Best Performance)Qualcomm Snapdragon X Elite: On battery (Best Performance)Qualcomm Snapdragon X Elite: On battery (Balanced)Intel Core Ultra 200V: Plugged in (Best Performance)Intel Core Ultra 200V: On battery (Best Performance)Intel Core Ultra 200V: On battery (Balanced)AMD Ryzen AI Max+ Pro 395: Plugged in (Best Performance)AMD Ryzen AI Max+ Pro 395: On battery (Best Performance)AMD Ryzen AI Max+ Pro 395: On battery (Balanced)
Geekbench 6: Single core (Higher is better)2,3792,2832,3092,7212,6991,5992,8372,6472,224
Geekbench 6: Multicore (Higher is better)12,3409,2077,58911,03510,9889,05817,72114,24413,416
Cinebench R23: Single core (Higher is better)1,0831,0731,1041,8291,8911,0331,9301,9401,050
Cinebench R23: Multicore (Higher is better)10,13011,1029,9418,4317,9527,87529,46924,20819,733
Handbrake video encoding (Lower is better)06:5011:3008:0907:2608:5008:4402:3603:2703:37
3DMark Fire Strike (Higher is better)5,8005,7954,9658,4627,4127,78723,45916,15115,593
3DMark Time Spy (Higher is better)1,8731,8911,8033,8963,5573,73510,1147,3626,689
Let's take a look at GB6 Multicore, which is quite representative for a mixed workload running on a laptop (not ST, not massive MT either).
Performance retention on battery /w Balanced profile in GB6 MT:
Snapdragon X Elite: 61.5%
Intel Lunar Lake: 82%
Performance retention on battery /w Best Performance profile in GB6 MT:
Snapdragon X Elite: 74.6%
Intel Lunar Lake: 99.6%
Intel has tried quite a few times in the past to dunk on AMD for the exact thing we're discussing here, they claimed their chips were superior because they offered more consistent performance on battery vs AMD. People didn't really care, users are willing to sacrifice some performance for stamina on battery as long as performance is still adequate. (ideally we want user choice, I like how MacOS does this with very good performance retention on default and additional profiles for better battery life and/or noise/thermals)
The part that really sucks here is Window's implementation of power profiles and power settings that need to be changed in multiple places. One good thing they accomplished somewhat recently was to introduce both "Plugged-in" and "On battery" dropdowns for power modes, in the past there was only a "unified" selector that changed value depending on whether the unit was on battery or plugged in, which meant inexperienced reviewers did not even know what profile they were testing with.
Look at this, and prepare to facepalm:
regen1
351
427
Some U5 338H(B370/10Xe3) benchmarks from "Goldenpig Upgrade"
Gaming and Synthetics:
Cinebench:
some "AI"
Covfefe
101
177
I ran speedometer stock and after throttling in bios. I scored 39.6 and 21.2. conveniently that lines up exactly with the 54% that panther lake scores on battery.
The fact that they're throttling CPU in certain applications doesn't mean they're throttling GPU. I'm sure they're power limiting it, but so is AMD and Apple and Qualcomm. There's no indication that Intel is throttling the GPU enough to make the experience choppy. If they were, reviewers would have mentioned it.
DavidC1
2,138
3,273
Ultra 5 338H is the star of the show. 85% of graphics performance. Still 50% faster than predecessor.
Balanced isn't necessarily slower than performance. The Dell XPS 12 I had ran Starcraft 2 better on battery Balanced than on Performance mode. Noticeably actually. In the 25% range.
Reactions: sgs_x86
DavidC1
2,138
3,273
you mean 10?
I mean 8. There's a video where it compares all those generations. 8.1, 10 and 11. It's progressively more bloated, more memory use and such.
Also, laptop battery life will vary depending on vendor, implementation and tested settings too. I doubt the differences will be noticeable overall. I would bet the dual screen implementation means it has some overhead even if one screen is off. Laptops are finicky like that.
regen1
351
427
For gaming something similar was observed here, around 13 minute :
For this particular test it was more performant, quieter in "Balanced" mode.
DavidC1
2,138
3,273
I assume it's because how Turbo 2.0(Sandy Bridge) works, which uses unspent thermal headroom of a cooling system. Performance runs full throttle all the time, thus the heatsink is in average warmer, while Balanced mode allows the SoC to cool down having a reverse effect of being faster.
coercitiv
7,470
17,850
Dell XPS 13 Elite 1st gen versus LNL, custom battery test with developers workload, max screen brightness and AFAIK Best Performance power mode (as claimed previously during the video):
The Lunar Lake machine outlasted the X Elite model. Now, we could argue that we need to establish a proper baseline for such a test, such as exact same display panel and battery, but like I already hinted in my previous post, even the power modes are not the same on many Windows devices.
mikegg
2,110
653
These tests are meaningless without the amount of work done.
The Qualcomm version could have done 50% more work before it ran out of battery first. X Elite doesn't throttle (or not nearly as much as LNL) and it has much higher MT performance. So it could very well have done much more work than LNL in the same time.
DavidC1
2,138
3,273
@coercitiv Just showed you that Snapdragon throttles more than Lunarlake in certain implementations.
Reactions: coercitiv
DavidC1
2,138
3,273
I would think at this point, a separate GPU oriented SKU for desktop with 12 Xe cores might have been interesting. Say a Core Ultra 5 245 had that for $430. That's $130 over the normal chip. On desktops DDR5 goes quite high clocks.
Lunar is better, interesting
I looked closer. The 388H is getting 7.7 with 120Hz display. Lunarlake is getting 7.9, so that's a minor difference, not even 5%.
The efficiency comparison becomes interesting with lower TDP values for the Arc B390. The efficiency is almost at the level of the Apple M5 GPU even at 35 W, and this gets even better at 28 W and 20 W.
Same process, same efficiency. GPUs are embarassingly parallel so much easier to catch up, hence why Apple doesn't get decisive advantage in GPU vs competitors.
