Page 749 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
Very bad efficiency in single core, worse than Strix Point with a better node, except at the top of the curve.
DMR Launching Q2/Q3 26?
Idk how impactful DMR will be without smt and probably slightly lower core count... It might narrow the gap vs Epyc in some scenarios but lose ground in others, as opposed to Granite which was a clear improvement over prior gens in all aspects. Xeon L3 has the same latency issues seen on client too. Guess 2028 is the new 2025, Jaguar, Coral etc is their next chance at catching up.
AMD's good days in mid-to-high-end notebooks are over, even with an 8-10% IPC limitation on Pcore@285H (compared to 258V), ULTRA2 still has considerable competitiveness. The only competitive products AMD currently has in the laptop market are the low-end 7845H and 8845H.
But for some reason, NVL is again switching back to MTL/ARL tile layout (mostly) with some modifications/improvements
Cost.
Funny thing is, Zen 6 is also expected to follow similar Intel tile designs.
It follows Strix-halo.
PTL is expected to bring in better performance due to the new design compared to ARL-H.
w r o n g.
Improvements in design. Like how AMD went from Bulldozer to Zen.
what the-
So apart from iGPU, PTL is not exciting?
Hopefully NVL-H is better otherwise AMD gonna eat Intel for lunch with their mobile designs.
PTL does not introduce any new cores.
Last rumor that I saw was more LP-E cores (4 instead of 2). And all cores get upgrades. Cougar Cove P cores instead of Lion Cove. E cores get a few optimizations, but aren't much different. LP-E cores should be able to be ran much faster (and hopefully will then be functionally usable) when not on TSMC 6. And that isn't even counting if there are power efficiency gains from 18A.
What evidence do you have that this is no CPU improvement over ARL-H?
