Page 746 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Geddagod
1,675
1,708
There isn't any desktop socket sized cooler that can handle anywhere near 600W.
Or maybe Intel could just not have this sku have the all core turbo pretty much at every cores Fmax this time around. Even iso power it's going to be a huge nT perf improvement, even if it's not 2x.
OneEng2
998
1,200
Yeah but he is the president of US so even things like that are scary for companies that is why even bluff works
Lol 2025 was supposed to be THE year Intel returns to form with Diamond Rapids, Falcon, 18A and Nova Lake. I guess in hindsight there was no way they were going to accomplish all that. Now the next estimate for recovery is 2029 at best, after four years Intel is back at square one. DCAI(both traditional & AI) is in shambles, no major foundry clients, maybe NVL will be another "Alder lake moment" or similar
I struggle to see how AMD can compete with Zen 6 now in nT at least. Idk how important that will be for them, considering I fully expect them to have the gaming crown by a decent margin, but still.
And I struggle to see how Intel plans to double core counts at any reasonable TDP.
I struggle to see how Intel plans to get any kind of decent yield with pie plate sized die (if they indeed plan as in the above link)
It's almost as if Intel can't understand that it ISN'T enough to make the most performant processor in a market segment ..... they have to MAKE MONEY doing it.
Yields and efficiency are critically important. Intel has spent enough money to purchase a US Ford class air craft carrier on 18A R&D to date. If their plan is to make a relatively small number of units at low yield on 18A for a couple of years and then spend ANOTHER 20Bn to develop the next process node .... I don't see the math!
511
5,413
4,833
They should have figured out something they are using HB with Intel 3/18A/TSMC for NVL
Geddagod
1,675
1,708
The rumor is 2x 8+16 dies. Not one large one. Even if Intel was to do that, which is not the rumor, I doubt a 16+32 would be much larger than 200mm2, if that. Which is still large mind you, but no where near so large that yields start becoming a massive issue.
E-cores, canning the rumored 8+32 ARL die, canning a bunch of Halo skus, I would imagine are all responses to cost cutting. I think Intel is becoming very cognizant of the fact that they have to cut costs.
LOL that's so funny
Reactions: OneEng2
Geddagod
1,675
1,708
It's gonna be a HUGE socket. Maybe 2000+ pins now.
I hope they give at least NVL-S to Z890 owners for their loyalty.
I wonder if NVL's new platform may have some high end DDR6 boards, kinda like ADL supporting both ddr4 and ddr5 depending on the mobo. I have no clue, I'll admit I don't follow memory tech much at all.
I mean, wouldn't such a massive core count CPU also require equally massive amounts of memory bandwidth?
Geddagod
1,675
1,708
Hybrid Bonding 😅 also I think 8+16 will be around 100mm2
Ah I'm dumb, HB being hybrid bonding makes sense lol.
Yea, I agree, one 8x16 die will prob would be ~100mm2. ARL's die is around the same size IIRC.
511
5,413
4,833
It can be a lot smaller if they move the ring bus and L3 to the base die like Clearwater Forest but will not get my hopes up also it's not dumb.
If you wanna see dumb see Intel's Board
the finances dudes are alright sometimes. they were on top with Otellini. He gets blamed for not entering the smartphone market but, whoops, he actually did try to enter it and build a foundry service but efforts were demolished by Intel's board due to lower margins. Efforts towards a GPU were killed in the same way and demoted to Xeon Phi.
All these years later and again the board cripples a foundry initiative before it even gets off the ground while scapegoating the CEO.
19,210
Yeah that's why they should release NVL-S on LGA1851 to prevent having to waste money on developing a new DDR5 chipset. Let the existing chipset shoulder that burden.
511
5,413
4,833
It's not going to happen NVL will get a new socket if it gets ddr6/PCI-e Gen 6 it will definitely require new board I doubt ddr6 but not PCI-E gen 6
LightningZ71
2,688
3,383
2X8+16 can easily fit within a reasonable TDP. Single and light load boost can still run wild, they just have to keep a rational limit on all-core boost speeds. With 32 e-cores, if they keep them near the sweet spot on the power/frequency curve, they can still have a massive amount of throughput. In those situations, they don't need to run the P cores at high boost speeds either. Keeping them constrained to near the sweet spot can also keep their power draw reasonable.
Saylick
4,117
9,627
Fwiw, in Lunar Lake which was on N3B, the P cores were roughly 4.5mm2 including L2 and the E cores were roughly 1.7mm2 including L2, if we believe this Reddit post: https://www.reddit.com/r/hardware/s/Yo9vTQnk1k
Scaling this up to 8+16 means 64mm2 of compute area, which probably gets a small 15% reduction going to N2, so somewhere around 40-50mm2 after it’s all said and done. Double this for 2x(8+16) and it’s not that much die.
Kepler_L2
1,081
4,666
That's assuming they don't bloat up the core again.
