Page 715 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
5,461
4,888
In server loads, SMT has gained AMD 40% per pheonix reviews. For a desktop application, while 30% is certainly less than 40%, it is still considerable.
I also question the general use of Spec Int as a general performance metric. Arrow Lake really gets taken to the cleaners when the code has lots of back and fourth memory access. It really needs things to fit and STAY in the local L2. Skymont gets in trouble with lots of branches. I think this makes for a really tricky scheduler.
Yup code spilling to L3 is disaster in ARL maybe due to 84 Cycle Latency in ARL L3?
I am hoping to see SMT and AVX512 in Intel's next generation. They can't keep on having less of everything than AMD and expecting people to buy them (at least not at the same price).
Be ready for AVX 10/256 where Intel will not give you 512 Data path on client but will give the full Instructions at 256b and a bit more and no fragmentation!
Just to be fair, when AMD had dismal single threaded performance, but more cores, AMD suddenly moved the goal post to MT .... which at that time was a small amount of applications. Intel bet on high performance single core and won hearts and minds.
I see AMD doing the same thing today with Zen 5 and Zen 5 X3D. Seems like this message still works today.
Peak Gaming Performance sells i am wondering though how will 144MB L3 on Intel will do on NVL too long to wait
I am surprised more people aren't talking about how great Lunar Lake is in thin and light. Seems like that product really hit a good cord, but all anyone cares about is high performance desktop benchmarks. Strange.
There was a LNL laptop going for $650 i was like i can't buy it that was U5 with 16GB ram but it was decent you can't find a better deal
Reactions: Tlh97
DavidC1
2,187
3,340
He is clearly confusing 285K for P core and 258V for E core, when 285K here is also E core, the difference in IPC between the two is down to using a much higher latency LPDDR and lower cache configuration in Lunar Lake, among other things.
Is it confusion?
Abwx
12,029
4,990
Is it confusion?
There s no confusion, even if we take a very optimistic 40% SMT yield in everything
the numbers talk by themselves, with 16 cores + SMT you have the equivalent of 22.4 SMT less cores of comparable IPC, with 24 cores among wich 8 have same IPC and 16 say your theorical 10% deficit since SKT is supposed to be better than Z4, you ll get 8 + 16 x 0.9 = 22.4.
So the same amount, but since 24 threads scale quite better than 32 then the 285K should beat the 9950X in about everything knowing that the 8 P cores work at higher MT frequency than the Zen 5 cores, and that the 16 SKT cores work at about the same frequency than the latter, and remember, that s with a 40% SMT yield figure that does not occur homogeneously, let alone a same scaling up to 32T compared to 24T.
Meteor Late
347
382
So you were talking about ST IPC and now you have moved to MT?
511
5,461
4,888
You can Spam Skymont better and keep the area in change Make it 5+24 or 4+27 🫠🫠 you can compensate logical cores for Physical core if you can cram more in the same area
Abwx
12,029
4,990
That s not worse than estImations that cant totaly isolate the core under test,
since you cant disable all P cores and that there will be at least one wich is active how do you measure an e core throughput with enough precision ?
Computerbase said that the usual tools to stick a process to a given core doesnt work with Intel s new gens contrary to ADL/RPL.
So what is the footprint of the P core in thoses tests when done in ST, obviously the difference between the 258V and the 285k cant come from a better cache or RAM access as we re talking ST, there cant be any bottleneck otherwise it would be a disaster in MT if in ST there s already cache and RAM access limitations.
OneEng2
1,011
1,211
Moving the goal post here a bit?
Ok, let's talk about MT overall processor performance then.
Arrow Lake gets beat by Zen5 in nearly every MT benchmark with the exception of CB24 Where I believe bandwidth is a significant factor.
If you look at total performance, you need to also consider clock speed of all cores, not just IPC and number of cores. You also need to take into account SMT effects and the performance on real world applications.
This isn't just a math exercise.
Reactions: Kryohi
511
5,461
4,888
Arrow lakes fine tune mechanism destroys power at higher end anyway so the gains of process are negated for multi thread
OneEng2
1,011
1,211
One could argue the the process is taken full advantage of.... But that simply means the design has some issues IMO. In this case, latency.
19,218
I wouldn't call Lion Cove a total disaster, but it's very close to being one. Not performant enough, which brings the overall performance down.
IPC uplift over 14900KS is real but doing the disaggregated experiment with it destroyed almost all gains that could've been had.
511
5,461
4,888
Yeah the funny thing is Nova Lake will look insane with the changes in ST
One Tick Cougar Cove (8%)
One Tock Panther Cove(15%)
Roughly 25% + addition of IPC that lost due to their L3 AND NGU
OneEng2
1,011
1,211
Nope. RH clearly mentioned in the interview that the high latency is caused by a combination of bad scheduling + core parking. It's the wake up delay that causes the latency. There is no "latency issue" per se. Also, not all fixes are available at the moment. The full suit of fixes is coming this jan. Should solve most of these issues.
Generally speaking:
I think we're missing the bigger picture. The E cores are excellent. Very performant, very efficient & has better PPA than Zen 5C. Skymont is an amazing core. The problem lies with the P core. The damn Lion Cove.
Last gen Meteor Lake RWC was a total disaster. And this gen Lion Cove has barely shown any ST improvement (forget efficiency for a while). I wouldn't call Lion Cove a total disaster, but it's very close to being one. Not performant enough, which brings the overall performance down.
Not sure about any interview, but the bench testing I have seen for the latency clearly shows the huge deficit Arrow lake has in latency compared to Zen 5.
I think using CB single threaded benchmarks for representing general single threaded application work is misleading. CB tends to be quite bandwidth heavy, and branch light. This falls right into Arrow Lakes sweet spot IMO.
Applications that do not fit into the L2 and have lots of branches perform badly on Arrow lake due to the latency issues.
Now, I do agree, that when a new architecture comes out having fixed this latency, Lion Cove may roar quite loudly. I think Skymont is already doing about as well as its engine can.
As for the "bigger picture", Arrow Lake performs below Zen 5 in most applications and sometimes below 14XXXK IIRC. This is IMO due to the latency issue in the current design. Intel is burning through cash paying for 18A bring up and paying for premium wafers at TSMC for its processors.
I agree that 18A is a turning point for intel, but as others have stated, it will be another 2 years beyond 18A before the financial impact is resolved.
We will see if Intel can remain the "Intel" of today for that long.
OneEng2
1,011
1,211
I sincerely hope these words come true. I'm not very sure about Panther Lake as it appears to be a bit incremental. But should solve all ARL issues and bring the platform to full potential. And most importantly, I think Nova Lake with Arctic Wolf is the one. The real game changer.
Me too.
It is my understanding that Panther Lake is a laptop part with its highest configuration -H being 4P + 8E + 4ELP (total of 16 cores). Still, this may be more potent than we think if Intel can fix the latency problems they currently have.
Nova is just so far out that it is hard to imagine investors waiting that long for a product that breaks away from the competition .... and Nova may well have to compete with Zen 6 vs Zen 5 variants today and in 2025.
DZero
2,162
782
Only if the fab expenses drag them down again. AMD never has enough supply to fulfill demand so Intel will still get decent sales no matter what product they put out.
The issue is that they were the only players in the Windows market, but once Qualcomm estabilishes and nVIDIA + Mediatek appears.... the situation will become wild.
Reactions: Tlh97 and 511
ajsdkflsdjfio
185
133
Nope. Qualcomm's foray into the laptop segment with it's Snapdragon X Elite was not just a disaster but a total bloodbath. Considering the extremely poor sales & very high return rates, ARM can't be considered a x86 competition for the foreseeable future (excluding Apple which plays a different game altogether).
Yup, Apple is able to effectively sell ARM products because the regular Mac users were already used to the more limited program compatibility that comes with Mac, and the key programs that already worked well on x86 mac were able to be converted to work just as well on ARM due to Apple's heavy draw power.
I just don't see non-apple ARM taking market share anytime soon unless there is a large push by Microsoft to make ARM work flawlessly. The average Windows user isn't going to accept kneecapped compatibility with all the various third-party and obscure programs they like to typically use on their x86 windows machine.
