Page 676 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
859
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
DavidC1
2,192
3,343
Given their current state matching M series will be a truly heroic achievement on the same level as Zen. Apple themselves weren't a struggling company during the last decade
If they can't match it then the conclusion is that the enormous gap is due to the ISA, which I flat out don't buy. Heard of too many excuses in both directions.
It was back in the Athlon 64 days when some outlets(really good ones at that) express doubts whether perf/clock could improve. It did, and today's CPUs far surpass that chip. The E cores ground A64 to the dust.
I do believe it is the capable people leaving that made Apple Mx only get little gains. You have Jim Keller at Tensorrent focusing on AI now. You have intellers saying that they pulled engineers off the Royal Core team to work on GPUs and AI. Tell me that doesn't have a negative impact on CPU teams?
All the way to Skymont they managed to get linear scaling between core area increase and scalar integer performance. And suddenly it'll barely scale from there? How does that logic even work when the Skymont E core is one of the smallest modern cores?* It has way more room to grow, even in an efficient way, and then add to growing to a 2.xmm2 core on TOP of that.
@Hulk Add 5% to both Lion Cove and Skymont with a good fabric.
*Think of how a "9-issue" Skymont with 26 dispatch ports is only 27% larger than Oryon-M with 4-issue and 8 ports. Either the E core team is really, really good at dense chips despite being on x86(questionable), or they still had to make compromises.
cannedlake240
247
138
Nah it just means Apple has the engineering prowess and finances to support that. They can probably afford multiple projects like Royal core working in parallel on all sorts of innovations. In contrast even back when Intel had 95% market share pretty sure they weren't known for high pay
That just seems like hopium, in reality they all probably left for the new startup founded by the same team leaders that allegedly set out to implement their vision on Risc V, or other companies where grass is greener. The program apparently wasn't frozen it was completely abandoned
Well if they exhausted all the low hanging fruit then yeah improvements are likely to slow down
511
5,545
4,943
The Royal Core program was abandoned but not their Ideas and things they have already worked out
DavidC1
2,192
3,343
Yea, no this is nonsense, sorry.
They can catch up to Lion Cove by making up the area just by adding more caches. Just watch, they'll be able to claim equal performance to previous generation P cores, not just per clock performance, all with 1.5mm2 core on Arctic Wolf.
Intel had to abandon the project, because the important numbers left, enough that they could create a startup. And it started because they pulled members off the project to focus on "AI".
Another team to watch is Qualcomm's Nuvia team. The second gen is quite an improvement.
Nothing to do with pay. Intel management simply told after Sandy Bridge that "we don't need to focus on uarch". Hence the stagnation.
511
5,545
4,943
Biggest idocity don't focus on core buisness and let us get ourselves into problems
They had the moat of TSMC+Nvidia combined and they killed it
Reactions: Tlh97 and Thibsie
Abwx
12,035
5,005
I thought this data was worth reorganizing.
Those numbers are truncated, here s Huang s numbers, the score for the 265K is comparable to those scores for the 285K, as well as for the 14900K, but seems that Raichu is completely wrong for Zen 5, indeed in all INT apps that are lowly threaded Zen 5 is faster than ARL.
cannedlake240
247
138
Idk ex-/intellers complaining about uncompetitive pay at intel goes back when they were still counted one of the "big tech" companies. Now they can't even afford it and are constantly slashing bonuses etc. How can this and culture problems not be a problem for retaining talent?
Never said Atom will just stop improving. Just that uplifts may not continue at the same pace
Exist50 on reddit has since said that they all pretty much left the company...
Reactions: Thunder 57
FlameTail
4,384
2,762
That does not surprise me.
Intel has 2x the revenue of AMD, but 4x the employee count.
Intel has 50% more revenue than Qualcomm, but 2x the employee count.
The disparity is even bigger with Nvidia.
Reactions: Tlh97
511
5,545
4,943
Diffrent compilers and flags used 🙂
511
5,545
4,943
Middle Management should have been layed off in this wave just wipe One tier
Hulk
4,154
What do you mean by truncated? He left digits off the result?
Or do you mean all of Raichu's results are just wrong?
Abwx
12,035
5,005
He states 10.46 in Spec_int for the 9700X while Huang has 12.6 for the 9950X, at isofrequency that s a 16% difference, notice that Huang has the same numbers for ARL and RPL as Raichu.
Hulk
4,154
I believe the numbers you are quoting for Raichu are at stock clocks, which would make sense, because the 9950X clocks higher than the 9700X right?
Someone here said that the Raichu results where only core names are listed are iso-frequency. The ones where CPU names are listed are stock frequency. We don't know the frequency either were run at though.
Abwx
12,035
5,005
9950X clocks merely 4% higher with a good chip than an average 9700X, at 5.7GHz it would score only 10.84 according to Raichu s 10.46 number wich is at 5.5GHz, that s quite a stretch from Huang s 12.6 for the 9950X.
The fact that his ARL/RPL s numbers are about the same as Huang is an indication that he did the tests at stock frequencies for all CPUs, as for Huang he has Zen 5 perf/GHz at 2.21 while it s 2.02 for ARL.
Reactions: Tlh97
Hulk
4,154
I don't know how I got in the position to be defending Raichu's results. I thought I was doing a favor to the forum by making them easier to read.
If the forum assessment is they are unreliable garbage I will delete the table from my post.
I agree with you BTW. One of the two tests, either Raichu's or Huang's, is bugged.
This is why I always say we can't trust any results that were run by someone on this forum so we can get all of the testing procedures in detail. Ask questions, get replies.
Hitman928
6,755
12,503
It's all in the compiler flags 🙂
I have found the gain from Intel 3-> 20A(10% ppw) and 20A -> 18A (10% ppw)
From official Intel sources when they were developing it
So the gain target was about 20% and they ended with 15%
Originally, Intel 3 to 20a was supposed to be a 15% improvement in ppw.
511
5,545
4,943
I have seen slides with 10-15% estimate as well but looking at everything they played marketing tricks by saying " upto 15% " apparently they were not sure either what they will get
Hitman928
6,755
12,503
These quotes are always up to. Either way, it started at 15% + 10% and is now 15%.
Edit: she was also talking about saying it was 10% when they first announced it, which is wrong, everyone reported it was 15% at the time. So, either she’s trying to revise history to make it seem like they weren’t going to miss their target (and 20a ended up cancelled anyway) or she doesn’t remember what they told the world back at the time of announcement.
OneEng2
1,014
1,212
Sure, performance per clock has continued to increase over time; however, I would argue that it does so by using more transistors to do it.
More decodes, more dispatches, more execution units, bigger cache, more set associativity, more complex branch prediction units, etc, etc, etc.
Sometimes new instruction sets and data paths are introduced which improve performance per clock, but again, at a penalty of more transistors.
My question is, have we had any innovations that with the SAME transistor count, performance per clock is improved dramatically?
I think this type of argument is precisely why SMT is such a design win. For very little additional transistors, you can get 40% more performance per clock from the design.
As we move into the period of history where Moore's law is truly dead (or severely limited), I think it will come down to how well you run your business, including how well you taylor your products to meet different market demands. Intel has (for decades) enjoyed a process advantage lead over everyone else. I think that this gravy train just dried up though, and now Intel has to find a business model that is competitive.
Intel needs to (very quickly) decide if it is a foundry or a design house. Right now, they seem to believe they can continue to be both. I don't see the math though.
As far as the excellence of Skymont, I suspect it isn't as rosy as it appears for all workloads. We need some detailed analysis on what Lion Cove is doing vs what Skymont is doing in Arrow Lake.
