Page 675 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
858
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Krteq
1,010
730
Lol, x86-64-v3 is using only AVX2, not AVX512.
AVX512 is used in x86-64-v4 and there is also znver5 option with more AVX512 instructions implemented
Reactions: Tlh97
Hitman928
6,755
12,503
It's structure silicon on top of CPU tiles. MI300 has two compute tiles per base tile yet its not visible in pictures either, it just looks like a singular tile
Why would you need structural silicon on the top?
For MI300, you can't see the distinction between the dies from low res/zoomed in photos and bad lighting/angle, but you can see the division with a high enough resolution photo and good lighting/angle. My guess would be the same is true with CWF.
Example MI300 -
Bad photo:
Good photo:
Reactions: Tlh97
cannedlake240
247
138
Example MI300 -
Bad photo:
Good photo:
Doesn't it have 2 compute tiles per 1 base tile?
Hitman928
6,755
12,503
The base tile spans everything, all the compute, HBM, etc. The compute dies are part of an active interposer and there are 4 active interposer dies per MI300. I thought this was what you were referring to, but if you mean the compute tiles per active interposer, then yes, there are 2. Those are surrounded by structural silicon, AFAIK, and very difficult to make out as the process makes them seem continuous from the naked eye (unless you start delayering the chips), similar to the Zen 3/4 dies V-cache chips. CWF could have structural silicon around the compute dies causing the same visual issue. I wouldn't think they would need it, but it's certainly possible.
Reactions: Tlh97 and DavidC1
Hitman928
6,755
12,503
Just need someone to destroy Clearwater forest CPU to see what's it like
I think the Intel slide makes it pretty clear. The smaller details like support silicon are interesting (to me at least), but not important to the performance/functionality of the chips.
MS_AT
943
1,874
For those results here are the flags and the reason for using gcc 10
I fail to see from this message why gcc 10 was used. It is also no suprise that march=native mtune=native would give him bad results as these CPUs are younger by couple of years than this compiler version. Its from 2020, the newest Zen it recognizes is Zen3. Since it does not recognize the target it will default to generic.
x86-64-v3 is probably the newest that version of compiler recognizes, v4 was introduced later if I am not mistaken and this, as was already mentioned in the thread, tops at avx2.
Reactions: Tlh97 and Elfear
Saylick
4,133
9,652
What do you mean weird magical warpage?
Materials will expand and contract under thermal loading. Silicon is no exception. Warping can occur when you have one portion of the package heating up more than another side. On a monolithic die, it's not a big problem because it's all part of the same die. When you have chiplets/tiles, there's no continuity between them so heat doesn't distribute as evenly, causing warping. Having a slab of structural silicon tying things together helps to minimize potential warping.
Reactions: 511
Hitman928
6,755
12,503
Sure, but there are other ways around this. Many 3d stacked chips don't keep the carrier wafer. . .
I also wouldn't call this "magical warpage" as it's something that's very well known.
Edit: Just to be clear, I'm not saying keeping the carrier wafer isn't in big part for thermal warping concerns, just that if that is what was meant, just say it rather than insinuate some weird unknown source of warping that only the carrier silicon can solve.
maddie
5,204
5,616
Also the different materials with their unique expansion coefficients cause extreme strains across the die. Fatigue failures due to thermal expansion stress is a thing.
511
5,535
4,927
Yes but what is the issue if at max if it supports AVX2 they all support it except Zen5 which supports 512 as well a clear baseline and regarding compilers we talk as people use Zenver4/5 flags even Huang uses zenver3 sure the compiler version and settings may leave things to be desired but Intel is at the same settings 🙂
Hitman928
6,755
12,503
PHYs on the AIDs can get real toasty and cause warpage abound. It's why -R slab was ditched in favour of conventional -S.
The carrier wafer doesn't touch the AIDs though. I'm not a mechanical engineer, but I don't see how it helps if the middle die that the carrier wafer isn't attached to is the issue. It would make more sense to me that you want the carrier wafer there to avoid warping from thermal expansion when the compute dies are hot.
I can see switching from COWOS-R to COWOS-S for thermal expansion concerns as it is one big slab that all of the AIDs connect to, so AID heat causing warping at the base level makes a lot of sense.
MS_AT
943
1,874
There is no issue. It's just somebody asked why Zen5 is doing well in FP, quoting these spec results, you answered thanks to AVX512, thing is it couldn't be thanks to that because it was not enabled;)
Another thing is, if the first round of tests he did was gcc 10 march=native, mtune=native then it will inflate Skymont scores compared to LionCove, that is something to keep in mind.
All I am saying is that compiler options matter, and it is good to be aware of they do and interpret the SPEC results with this in mind;)
DavidC1
2,192
3,343
The thing is the 18A dies are under the Intel 3 dies and they are distant apart from the initial diagram each die has distance between them which will slice the area same issue as Zen5X3D
This makes no sense. It would need to go through a layer to the heatsink and make it more difficult to cool. The base layer is SRAM and IO which uses much less power. The top has to be 18A compute.
The picture you linked clearly shows the base tile is at the BOTTOM, with 12 dies at the top.
Something little different: Apple M4 generation is getting 2000 points at just 60W of power. It absolutely can and will demolish in server if they decided to make a chip based on it. Apple is too consumer focused, but there's a potential.
When talking about theoreticals, inserting artificially imposed restrictions(such as the ISA/compatibility barrier) makes no sense. A CPU with a superior uarch resulting in much better performance and performance per watt will be better in everything.
M4 is a clear indication that even Intel E cores can do much, much better. 30% per clock in Arctic Wolf, and 40-50% on top of that by aiming for 2.xmm2 core in the UC generation will do a "Conroe moment" again. Not something incredible for a 2028 core. Good, but not incredible.
Reactions: Tlh97
511
5,535
4,927
The picture i showed were 1 presentation from Intel docs the second is the real image of CLWF from Serve the home
DavidC1
2,192
3,343
Yes and real pics of the 2.5D products are usually much closer between the dies. Look at Ponte Vecchio's artistic rendition over actual shots. Again it makes no sense to have 18A under the IO die. There has to be a specific reason if they did as you suggested because of things like thermal issues.
You aren't seeing the divisions because of camera angle for one.
