Page 607 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
AcrosTinus
221
226
Wonder how many Intel employees have their parachutes at the ready...
I won't blame them, their tiles seem to be quite bad, higher latency than AMDs cheaper approach somehow....
No wonder they started reducing the complexity on the server parts, xeon 6 is in fact 3 monolithic dies and turin is really a chiplet design because the smallest part is a 8 core cluster not a 44 core one.
511
5,481
4,895
EMIB and Foveros are two different things it's not the tiles but the fabric the Ring and NOC dragging it down
511
5,481
4,895
Tiles from an Actual Intel Engineer
I can answer some of that actually. ARL is an MTL successor and ARL-S belongs to the same family of chips as MTL-S. They share a lot of DNA, right down to how tiles were laid out.
The splitting of the CPU, SoC, I/O, and GPU was done on MTL to power down parts that don't need it. You also get to pick and choose process nodes at will to balance performance and cost for each subsystem. The tiny iGPU doesn't need the absolute best, so it gets 5nm. We're not exactly making some super APU here, just drive a couple monitors. The CPU needs to be on the bleeding edge, so it gets 3nm. SoC and I/O don't generally scale down that well, so they get even older nodes than the iGPU because there's not much point in using anything better.
LNL needs everything to be super localized as they can't afford interconnect losses in that power segment as MTL-U proves, so it gets to be basically monolithic with the APU tile and I/O tile split. The die is also small enough that the yields and cost of 3nm are still very reasonable. LNL's APU tile is similar in size to some upcoming Smartphone SoCs.
Building ARL like LNL would have been insanely expensive as that's a ton of 3nm silicon, so it got carved up. I suspect the reason for the GPU being split off is to reuse MTL stuff. Even if it isn't the exact same tile, they've done a 4 Xe core iGPU on its own tile before.
IMO, and I say this as a die packaging engineer, there should be 3 tiles (plus interposer) here. The CPU cores and memory controller can go together to give the latency-sensitive cores the fastest access possible. Foveros latency isn't completely atrocious, but it's never beating being on-die. Nothing on SoC needs super low latency so that's fine, and we can combine in the GPU here so it still gets a link to the tile that has the memory controller on it rather than needing to go through the SoC tile to the CPU tile for it. I/O can stay split off by itself. Nothing on the I/O tile scales down very well, nor is there any substantial benefit to combining it with other tiles, so it can stay as is.
511
5,481
4,895
Basically the design choices were wrong for desktop
Can someone delete this post as it is a duplicate post
Some Moderator 🙂
desrever
341
832
If other reviewers show what the leaked review does (more or less) and it wasn't due to a bad motherboard or something, I am curious to see if outlets will publish multiple videos on how Intel was lying about performance in their pre-release marketing slides :unamused:
They will instead make videos on "we decided not to do gaming benchmarks", "the performance per dollar in cinebench r24 is unmatched" and "Give Intel a chance to release new bios, we need competition"
19,218
I don't know. Results are not very typical. I will wait for other tests. I expect it to do much better if the scheduler wakes up.
It was someone on this forum who not sure if he was joking or serious but I think I read that Microsoft has a special Win11 patch slated for release soon after Arrow Lake.
