Page 589 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
859
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
coercitiv
7,510
17,970
Correct me if I'm wrong, or is Netburst being a failure more hindsight is 20/20? This is years before I started following hardware, but I heard that when Netburst design first started, many believed clock speeds would just keep increasing, so focusing on clockspeed at the expense of IPC sounded like a good idea initially at the time the development started. Only later on was it discovered to be a terrible idea. Going from 2Ghz to 4Ghz is 2x performance, without any change to IPC. Intel was predicting publicly that they'd be hitting 10Ghz in a few generations.
IMHO the problem everyone has with Netburst is how much it took between launching the first products and ending the madness. Taking a quick look at Wikipedia, Netburst lasted for 6 years. Since we're talking about hindsight and judging the decisions of the 2000 era through the lens of 2024, consider a modern company launching a flawed architecture today and then pursuing the goals of that arch for another 4-5 years or so.
But personally after Willamette I think they should have realized some problems but they doubled down with Prescott.
Yup, taking the path was not the problem. Pushing on in spite of all the warning signs was.
vanplayer
78
121
66
Does Blender CPU take advantage of AVX-512?
AFAIK rendering engines don't utilize any vector instruction set which are beyond 256bit due to technical reason, either it doesn't have any benefit or simply cannot implement. More cores/threads makes much more sense in this area. I believe Blender can utilize up to AVX2 256bit inst, nothing more than that, and Blender results database doesn't have any indication that AVX512 make sense.
Reactions: Tlh97 and poke01
yuri69
699
1,252
For me the astounding fact about Netburst is that so many super smart people can get lost in an area they know so well, and have lived in and studied most of their lives, yet they still end up taking a devistatingly wrong turn on a super highway with no exit for 50 miles, which made them late for an exceedingly important event.
It was simply the zeitgeist. Processors clocked faster, Netburst aimed to accelerate that trend.
AMD was apparently seriously worried about Netburst. It was so much they pursued their own Netburst - called K9. That was just after they finalized K8 (Athlon 64) and thought they couldn't compete with future Intels. But yeah, K9 was canned when it was apparent those designs would burn like 100+W with a just single core but the world was moving towards multi-cores.
As always, you can't easily simply resteer the core roadmap - it takes years to build a CPU.
DavidC1
2,196
3,354
The problem with Netburst was that the clock increase came at a significant sacrifice to performance/clock. The 1.5GHz was anywhere from 1GHz P3 to a 1.5GHz P3.
And they did it again with Prescott. Well, actually Prescott lost a lot less, but at 3.4GHz it was already using 125W, which was huge in those days. There were reports that they were expecting Prescott to reach 5.2GHz, and 5.6GHz, and 6+GHz very soon, like every 1-2 quarters.
Moore's Law and tech advancements always favor the low, meaning lower clocked, lower power, and lower cost. So as time passes, the difference between them gets reduced.
If it was 10 years ago, Apple cores may not have been so close to Intel's top chips today.
Very interesting. They did get Bulldozer out though.
Additionally, the power density becomes a major issue a7s you continue to scale to smaller and smaller geometries.
Power Density is pretty much the dominant factor at certain frequencies.
Overclocking World records prove this.
If they ever get microfluidic channels(which has immense hurdles to go through to make it reliable and low cost) through the die, maybe we'll get to see 7GHz chips. But what's the point really? Power efficiency is needed anyway.
Det0x
1,490
5,121
More 285k results showing up in the geekbench 6 database
Seems like average results are going down with a larger sample size, just as expected
btw, does anyone know where our swagger guy have gone ? Have been pretty much radio silence for a few of this thread regulars, after these latest leaks it seems (?)
+20% ST performance over the 14900KS was always fanfiction, but this seems below even my expectations, althought i did get some of my predictions right, even if i took some flak for that at the time
So we get 253w instead of 353w ?
Taken from here:
NostaSeronx
3,815
1,294
Bulldozer was being prepared as the "future experimental" core - called K10 - around the time K9 was still alive.
Original Bulldozer was the multi-core/high IPC variant of Bobcat.
K10(AG/MB) was the simpler design to port, so original Bulldozer(JK/CM) was killed off. AMD had issues with Bulldozer's synthesised macros but not with K10's custom macros.
K9 had a single monolithic 4 ALU-PRF group w/ 4-wide decode. While K10 split the ALU-PRF in half doing 2x2 w/ 4-wide decode, shown in the MA patents for K9 and K10. However, when it went to MB the design was revised to what it launched with. The MB design was specifically changed to get into a Microsoft device that was never named. So, if anyone is wondering why it doesn't do PH's Bulldozer 2007(High IPC/16-core) or FW's K10 2002(9 GHz/quad-core) it is because of Microsoft.
"For the mobile market we are optimizing for low power, lower-cost devices; we’re focusing on power efficient devices in the desktop space, and on scalable, power efficient, highly available designs in the server space." -- "...The mobile microarchitecture could be pushed up to the desktop..." -- the main reason why DM was kicked out.
Timeline CM joins 2004, PH gains position in 2005 ==> 2007+ CM gets promoted to irrelevant position, PH leaves, etc. Why it went from K10 (2002-2004) -> Bulldozer (2005- early2007) -> Modified K10 (stole Bulldozer name, late2007-to launch).
Markfw
May 16, 2002
27,414
16,274
swaggers come and go, on all sides of the isle. heh, we might as well coin this term for them.
I like that comment.
I like that I was going to say he is a (forbidden) and if his favorite company is not doing as well as predicted he will not comment.
Nothingness
3,374
2,475
I don't know about Blender, but some other renderers certainly benefit from AVX-512: https://www.phoronix.com/review/amd-zen5-avx-512-9950x/3
FlameTail
4,384
2,762
Until Intel has an answer for X3D I don’t see them competing with AMD for the gaming crown anytime soon.
Doesn't AMD benefit more from X3D because their memory controller is worse? Intel will have much less to gain from putting X3D to their CPUs.
Reactions: Joe NYC
poke01
4,916
6,265
From a consumer standpoint, you can buy 6,000MT/s RAM and still get great performance on a X3D CPU.
What you said was true for Raptor Lake but Arrow Lake is a regression in every way for gaming, only efficiency is improved.
Hulk
4,166
Lotsa eggs on the faces of people who tried to play semicon Nostradamus this year
Yes, I was waaaaay off base with Skymont. I would never have guessed the IPC gain vs Gracemont would have been possible in one generation. Lion Cove is on the lower side of what I was thinking.
511
5,555
4,960
I will reserve my final judgement on Lion Cove until i get a Power Performance curve vs Zen 5 but Area is already Worse for P cores and on a more advanced node if Power and Performance is similar than it is bad
Skymont is hilariously Good in PPA it's just not good for Peak ST Performance that is only good in desktops
tsamolotoff
263
519
I'd say most of the extra performance of 13/14th gen over 12th gen was due to extra cache added and not memory performance. Also, you can't really compare intel and amd RAM controller 'quality' as they work in completely different modes - AMD can work both in gear1 and gear2 mode with DDR5, while Intel only does G2 or G4 even with Arrow Lake, Intel's controller is (or rather was) integrated into the ring bus while AMD one is connected via an interface that has inherent tradeoffs to allow it to scale better with more core clusters. Also, if your software is coded in a numa-aware fashion, you'd be able to utilize the bandwidth in a proper fashion in 1:2 mode with Zen4/5, contrary to the stigma of "amd ddr5 bad"
Reactions: Tlh97 and Elfear
Det0x
1,490
5,121
AMD currently have the strongest/best memory controller on the X86 market with the 8000 APU series
But as with regular 7000 and 9000 series, the infinity fabric is the main bottlenect, but that's a seperated thing from the memory controller itself..
Here is one example of said IMC -> dualchannel 9800MT/s without any cudimm in normal ambient temps
5,555
4,960
AMD currently have the strongest/best memory controller on the X86 market wuth the 8000 APU series
Here is one example stable dualchannel 9800MT/s without any cudimm
I think LNL has the best one 🙂
