Page 541 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
940
852
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
5,342
4,755
Let me correct
On October 7 we will get official slides leaked like Lunar lake
On October 10 the official launch will begin
naukkis
1,030
854
Once you've lost your mind and think a 24 wide design isn't the stupidest thing ever, you better figure out a way to keep it doing something halfway useful when the magic compiler you're depending on fails to materialize (like they always do)
It wasn't traditional 24-way cpu but 4 clustered 6-way cpus with register-to.register moves and ability to execute single thread together. X86 is worst ISA to do such a cpu so Intel would have need to implement new ISA to support that cpu. I speculate that Jim Keller did want to do it with Risc-v ISA and after Intel changed that to x86( and doomed it to fail) he left. Actually rest of Royal core lead designers also left Intel and are building that Royal Core on Risc-V under new startup Ahead computing - curiously see if they can bring something out.
And if they get something good out Intel sure need to reorganize their management layer - sack everybody.
Wolverine2349
526
180
86
The sample you have is it a QS?
So Arrow Lake can do DDR5 Gear 1??
Shoudl that more than make up for the IMC being on a spearate tile form CPU corers and ring unlike Raptor and Alder? Raptor and Alder can only do DDR5 Gear 2, but they have faster IMC latency due to the IMC being on the same die on CPU cores and ring? Am I right on that thinking?
9949asd
139
I don’t know it’s a bug or not. For the cudimm When showing 1:1 is g2, when showing 1:2 is g4.
For ARL there is no d4 inc anymore.
Magio
205
242
Hmm? I thought it was more dense.
If you read between the lines of Intel's own communication, this isn't a big surprise:
This is Intel's own assessment of how their nodes will fare against TSMC's, which logically you'd assume would have Intel pit 18A against TSMC's top of the line node when 18A is set for HVM.
"≈" in a marketing slide may as well mean "slightly worse", and 18A will reach HVM before N2 so TSMC's top of the line would be N3P at that point. So 18A having slightly worse density than N3P is the logical take away from this. But keep in mind N2 is "only" expected to have +/- 15% density uplift over N3E, so that's not actually too bad especially as 18A-P would bridge some of that gap again probably within reasonable timelines.
"+≈" on the other hand in marketing speech would most likely mean "maybe barely better but generally as good", so they expect 18A to fare well in PPW (at least in HPC scenarios) vs N3E/P and 14A to finally actually see them reclaim the density lead even if not by much.
Napkin math from SemiAnalysis' prediction that 18A will have a 50+% density uplift over Intel 3 would probably mean it should land a bit above 200MTr/mm² which is indeed a tad behind N3E/P.
Reactions: Tlh97 and Saylick
GTracing
478
1,114
Abwx
11,996
4,954
Geekwan lunar lake test
Limited board power to 30w and 15w, lunar lake crush every things.
View attachment 108556View attachment 108557View attachment 108559View attachment 108561View attachment 108562
First pics : 258V 22W soc power, HX370 15W.
Last pic : 258V 12W soc power, HX370 9W.
So that s just a tiny 50% more power.
Yeah, it crush everything when it comes to cheating.
Same here, 258V at 12W vs 9W for the 370, that s just a joke of a test.
DavidC1
2,106
3,227
And they are completely wrong, ignoring Intel's own presentation that 18A offers mere 30% density improvement over Intel 3.
You clearly did not watch the video.
What else can you expect from him?
cannedlake240
247
138
TSMC N3 is also a mere 30% density increase over N5. Because it's chip density not logic density. Chips aren't made entirely out of highest density logic cells
511
5,342
4,755
Intel said Chip density they never said logic density two are different things
Chip density means Logic+Sram+Aanalog
Analog doesn't scale well Sram scaling is nearly dead for now
Yeah he is here to 🧌 don't mind him
DavidC1
2,106
3,227
Please take a look at Lunarlake and tell me there's enough SRAM cells to change density improvements from 60% to 30% just because SRAM doesn't scale as well. Even if we assume SRAM improvement is 0%, it's a big stretch.
Daniel Nenni was guessing and he's wrong.
