Page 484 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
940
852
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Josh128
1,508
2,260
I get the throttling for MT. But for ST?
Time to throw it in the freezer!
If you remember, Strix had the same issue on the Zenbook models, not able to attain the full 5.1 boost, while the larger, better cooled ProArt has better cooling and hits the full SC boost.
naukkis
1,030
854
Still something not right. L2 are too slow. And for ARL everyone can use CUDIMM xmp 9200
L2 is actually L3 now so its latency see that intermediate 192kb cache latency added, which is about twice of L1. So seems to be just in line.
MarkPost
378
794
ST is not disappointing at all here. @5GHz it is beating Strix @5.1 by 8-10%. Its beating the newest, fastest x86 core available by 10%, what more do you want? MT is nothing special, but if this is at 17W, its ~passable. Strix gets 954 @28W with 12 cores.
dunno if Strix is slower than Granite, but zen 5 desktop scores ~128 pts. fixed @5.1 with DDR5 @6000 EXPO
dullard
26,187
4,853
Edit: Btw, I think someone also mentioned it. 20A being scrapped is probably because 18A with PowerVia had good enough yields, and 20A use was going to be limited (one ARL-S SKU that we know off). However, 18A is falling short on performance expectations (from around 25% improvement in perf/W over Intel 3 to only 15%). The new 18A-P node they added to the roadmap will have the expected additional 10% improvement, but I don't think that will be ready before end of 25, early 26.
I think something that has been missed in the last week of node discussions. It is that Intel changed 18A about a year ago (at least they confirmed the change a year ago). https://www.anandtech.com/show/2006...v-work-on-intel-18a-production-in-future-node
18A was originally going to be made with high-NA EUV. But they moved 18A from being manufacturing ready in 2025 to H2 2024 which is before high-NA EUV is ready: https://www.anandtech.com/show/1734...on-moves-up-intel-18a-manufacturing-to-h22024
This has two impacts:
(1) 18A will not be as advanced as originally planned by dropping high-NA EUV and pulling it up a half year earlier. Thus, they have 18A-P that uses more EUV. https://www.intel.com/content/www/u...es/foundry-direct-connect-2024.html#gs.evm56y Yield, and performance discussions should reflect that (don't use performance expectations from before the change).
(2) There is no longer much need for 20A. Since 18A was moved up half a year, since the risk of high-NA EUV was removed, and since 18A has low defect rates according to Intel, then 20A is just redundant. https://www.intel.com/content/www/us/en/newsroom/opinion/continued-momentum-intel-18a.html
As an aside: we should be clear to discuss defects with respect to which 18A we are talking about. 18A or 18A-P.
DZero
2,073
769
Intel should accelerate their 18A since relying too much in TSMC would put them in a similar situation AMD is.
MS_AT
926
1,848
Probably due to some degree of thermal throttling still on the laptop, that and they say mem speed can affect R24 as well, so yet more uncertainty there. :confused:
For what it is worth, desktop parts have twice as big L3 cache [32MB vs 16MB] but L3 is a victim cache so not sure how well R24 is able to make use of it.
511
5,340
4,754
Btw TSMC Said 18A is Comparable to N3P means superior to N3E but Intel 4 is closer to N4 and I3 is closer to N3B which makes Intel 18A closer to N2!!
Source
cannedlake240
247
138
Intel still doesn't have proper dense logic cells. I3 HD is only 10% denser than i4 HP, meanwhile between TSMC N3 HP and HD, used by AI, iphones etc., there's a massive density difference.
Plus there's some rumors that high end NVL will still use N2. Lol even the next lake after NVL is apparently partially outsourced instead of using 14A, which is supposed to be the Intel's crown jewel
511
5,340
4,754
I think intel should stay with TSMC for the msdt until they’re fab is better than tsmc(impossible).
You mean comparable ? I don't understand people's problems with Intel Fab they got in that state due to BK and Swan BK gutted the funding and Swan didn't do anything after that to save it the only reason intel has such a scale is the fab do you know TSMC copied Intel untill intel F***** up good
Reactions: AcrosTinus
AcrosTinus
221
226
You don't need to be better than TSMC, you just have to be competitive.
Intel 3 is good, 20A is internal and cancelled and 18A if the specs are to be believed, is great as well.
Reactions: 511 and cebri1
511
5,340
4,754
Intel for it's Intent never uses HD they need to for their fab buisness but HPC is Intel's speciality also part of TSMC density is due to finflex allowing you to mix and match 2-2 2-1 fins that is what gives the density boost with tighter pitches 18 AP exists for this
Rumours yeah sure i can get part of it is TSMC but not 100%
Btw Falcon shores is N3E their GPU is at TSMC with PTL they will bring some part of it to Intel 3
Josh128
1,508
2,260
Source
So who is lying?
controlflow
198
348
That was a bit of a surprise to me too when Intel said 18A will be cheaper than N2! Considering the all new transistor with BSPDN, I'm not sure how it works cos the R&D cost itself will be thru the roof!
"You might expect that having to build interconnects on both sides of the silicon would make the cost of the chip shoot up. But early on, Intel saw a reason why that would not be the case, says Sell. The smallest, most tightly packed layer of interconnects, called M0, are also the costliest to produce. They can require more than one pass through chipmaking’s most expensive step, extreme ultraviolet lithography. But with no power interconnects to get in the way, the lines in the M0 layer could be six nanometers further apart than they are today. That may not seem like much, but it means it takes less EUV effort to make them. For the process to be introduced next year and for its successor, “the cost savings we get from not scaling so aggressively more than offsets the additional cost from the backside power-delivery process,” Sell says."
511
5,340
4,754
Yup they reduced the pitches i don't know about EUV layers affect cost More layers means increasing cost that is why Intel 7 is a disaster it uses SAQP basically 4 time scanning and etching with DUV with EUV they would have gotten by single layer saving cost here is a good article
Magio
205
242
I'm thinking the cost will be lower than N2 to the customers because Intel will set it as low as possible to attract them. TSMC doesn't really have to do that because they have clients to spare and Apple will buy up the entire N2 production for a year anyway. So the node isn't cheaper (don't see how it could be with GAAFETs, BSPDN and with US manufacturing), but Intel will not be seeking high margins to start getting contracts.
desrever
335
824
Pricing it low will just bankrupt Intel.
maddie
5,203
5,612
Not gaining market share will also bankrupt intel. Some revenue to cover fixed costs is better than no revenue...
And, Intel has to price it lower than the competitor in order to survive. Doesn't mean they have to do it at a loss. More like they have go with reduced margins or a loss in profit if you prefer (or maybe even a slight loss). Far from bankruptcy.
Regarding the last few comments, what is the relative cost of an Intel versus a TSMC wafer for a comparable node? Unless this is known all these arguments are totally useless.
