Page 419 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
922
840
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
Hitman928
6,749
12,477
I use 125H with 4.4GHz because it has a lower PL1 (28W). Even in this case, a single P-core uses nearly half of the PL1 limit. That was the initial point.
Obviously, power limits and the power configuration depend on the OEM and can even be dynamically adjusted by the system.
Returning to Lunar Lake, we don't know how much power it can consume under full ST load. I expect to see something around 10W for 5.0GHz.
There really isn't correlation between PL1 value and ST power consumption on MTL. 155H also has a specified PL1 of 28W. Additionally, the PL1 value is adjustable by the laptop maker, so it's not relevant unless the ST boost uses that much (which the 155H just about does) and you want to sustain that power level past the PL2 duration. What is relevant is how much power it actually uses to reach boost frequencies as that will tell you if it can sustain that frequency or not given the PL1 values. Even if it can't, it will still boost past the PL1 value, it just won't be able to sustain it once the PL2 duration time ends.
I think LNL going from > 30 W to reach 5.1 GHz to 10 W is extremely unlikely, even with the better node. Most likely, LNL won't be able to sustain 5 GHz or above at 17 W. Reducing the tile count to 2 and being on a better node will certainly give it a chance, but I still think it's unlikely. I think that either it will have to lower clocks once the PL2 runs out (except the top SKU which has a PL1 of 30 W), or it will need to be configured for higher PL1.
DavidC1
2,023
3,161
Why does that matter in this argument? If they lower the power limit then Meteorlake won't hit 5.1GHz and will perform worse. It shows it needs 30W to just have 1 core active.
I doubt the process itself will do much. According to Intel data it's anywhere from little over 10% to close to 20% gain in performance per clock over Redwood Cove. Since the top Lunarlake clocks the same 5.1GHz, that means the P core will be 10-20% faster in ST but use similar >25W as Meteorlake does.
Of course, using the same data you can clock it down to 4.5GHz for the same performance and probably use 20W, but that rarely works out.
Here is the difference tho, an M4 using 16-20 watts at 5.1GHz will still run circles around a Zen 5/lion cove mobile core.
The 4.4GHz M4 runs circles around Zen 5/LNC.
DavidC1
2,023
3,161
I'd also argue area doesn't matter NEARLY as much as people here seem to want to believe.
Area matters in terms of the quality of the engineering of the core, which is the most important part of the CPU.
Area also shows roughly the amount of transistors(thus power) it took to create the said core. Apple beats the competition to a pulp while the core area is smaller. It has both exceptional perf/watt and perf/mm2, and even absolute performance.
And that's why I'm disappointed with Strix. Only good looking results is at Phoronix, in rest of the Tests it's about 20% faster than Phoenix at same TDP, despite having 50% more Cores/Threads. 7900X is 32% faster than 7700X at same TDP.
Yea, because Strix has E cores, which are slower. And despite the argument that it's superior because of the same core arrangement, in the big picture the differences are really small. Reviews show scheduler issues, and tests show Zen 5 is actually 6% faster than Zen 5c.
TwistedAndy
159
150
Because the CPU power characteristics depend on a lot of settings and microcode optimization.
My favorite examples are Dell Precision 7670 and 7770, which suffered severe performance issues because of the incorrect IA AC/DC Loadline values. This issue was fixed 6-7 months after release.
Another example is the incorrect EPP values for Meteor Lake and some other platforms: Updated Intel Meteor Lake Tuning For Linux Shows Huge Performance/Power Improvements or Tiny Linux Patch Up To 32% Faster, Up To 18% Less Energy For Intel Xeon Emerald Rapids.
Also, there are great and very useful features like Intel DTT and IPF (no), which often manipulate power limits in a very strange way.
I won't mention various issues with voltage offsets, which literally move the V/f curve up or down, making all our speculations pointless.
I hope we will get more details on Hot Chips in a few weeks.
Doug S
3,751
6,633
The "quality of engineering"? You can tell that based on overall performance and performance/watt. I'd say the quality of engineering is pretty poor if someone managed to make a core that does poorly on both those metrics that actually matter, but somehow manages to do well on the totally irrelevant metric performance/mm^2. That's like winning best personality in a beauty contest. Its nice, but its not what you were shooting for.
poke01
4,611
5,919
The Lion Cove core in Arrow Lake will show a similar performance to the Apple M4 P-core.
I’m sure it will but at vastly higher frequencies and power consumption.
Currently, the P-core in Apple M4 is 14.4% faster than Raptor Cove in mobile 14900HX in Geekbench 5:
This doesn’t mean much, you are comparing a fanless chip to a big giant laptop and even then the 14900HX loses. Do you have any idea the amount of watts that 14900hx used to reach 5.8GHz and to deliver that ST score?
Look, lunar lake will be a great product and it will live up to what Intel claimed. Like you said no point bickering and best to wait for benchmarks so let’s leave it there.
DavidC1
2,023
3,161
What do you think those settings and ucode do? Especially in ST. You won't get a 30W core to magically go down to 15W with BIOS settings. At 4.4GHz or so where Meteorlake needs to get the power level you wish for, the Apple core will outperform it by 60%, while consuming almost 40% less power.
Please tell me in what area the Apple cores are inferior in?
It absolutely curb stomps both P cores, to the point where it makes Conroe vs Netburst an embarassment. At least in the previous years it was able to keep ST lead with near 6GHz clocks. M4 proves that's not even true anymore.
Both of the x86 E cores are superior in the perf/W metric to their P core counterparts too. Need I also remind you that AMD is significantly better than Intel in that regard? Smaller core and happens to be much better in perf/W. Sunny/Golden/Lion are all disappointments. Conroe was also a smaller core to Netburst too.
While there are other factors that determine the size of the core, at such levels of difference, yes it indeed determines how good it is engineered.
Doug S
3,751
6,633
Where did I say Apple's cores were inferior? I wasn't talking about a specific architecture at all in the post you quoted. If you think I did, you're inferring something out of thin air that I didn't state or imply.
Yes M4 dominates in both absolute perf and perf/watt, so I don't see what would be the point of tossing in a perf/mm^2 comparison. That's pretty meaningless, especially if you're only considering the size of the cores themselves and not including higher levels of cache, the memory controllers, or the intercore and interchip communication (ring bus, IOD or AS Ultra's "10,000 I/Os")
And yes it is pretty obvious that everyone's E cores beat their respective P cores in perf/watt. Otherwise what reason would they have for existing? As you say AMD is better in perf/watt so what difference does it make if it is a smaller core? Yeah when you want hundreds of cores its nice to fit more of them in a given silicon area, but in the age of chiplets that doesn't really matter or limit you the way it did when server chips were on a single piece of silicon limited by yield (or failing that, the reticle)
TwistedAndy
159
150
Unfortunately, I don't have accurate data for 14th-gen ST power consumption. We need to keep in mind that 14900HX is three major nodes behind (10nm vs. 3nm), not to mention sub-nodes like N3B and N3E. Arrow Lake is expected to be much more representative here.
Those settings (AC/DC Loadline, voltage offsets, and the microcode defaults) adjust the position of V/f curve. As a result, a 12950HX CPU can, for example, run at low 2.6/2.0GHz frequencies and consume ~75W of power under MT load. That's exactly what happened with Dell Precision 7670 and 7770 (link).
It's worth mentioning that in late 2022, Intel released the microcode update, slightly increasing the voltages and introducing useless features like "Undervolt Protection" to "improve the system security and stability".
As a result, some of the 13th and 14th-gen SKUs are now having stability issues because of the voltages being too high. What a surprise!
Reactions: SiliconFly
Magio
198
239
Around 14-15W i guess
I can't imagine it being much higher than that indeed, these benchmarks were made at 17W PL1/PL2 and 30W PL1/PL2 and, while the 30W results are kinda borked, the 17W seem in line with expectations in ST perf (roughly 10% behind M3):
Since LNL at 17W includes 2W for memory, this should mean a Lion Cove thread with a 15W power limit can do that score. It may even consume a bit less, but in theory it shouldn't pull more.
DavidC1
2,023
3,161
Not only that david Huan on twitter said Intel's marketing slide can be taken at face value with the caveats of the testing
At least Intel is winning on something. :p
The early leaks need to be taken with a grain of salt because especially in that score, as you said the MT results are wonky. True it could be that it's excellent at 17W, but the just released 228V score outperforms the 30W in MT and not by a small amount.
Magio
198
239
The 228V score we have is in Geekbench 6, this is Geekbench 5.4.
I do agree we shouldn't take those early scores entirely at face value, the 30W is clearly weird and MT in general seems a bit disappointing. But my point is purely that a single Lion Cove thread seems capable of 2000+ on Geekbench 5 at a 15W power limit, which should mean that in LNL there's not much reason to push that thread beyond 15W.
Reactions: 511
511
5,143
4,614
There is only one issue with Lunar lake it is not cheap it is even more expensive than Strix Point
