Page 420 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
859
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Magio
214
261
Lunar Lake lives and dies by the quantity and quality of its design wins in the premium thin and light segment. LNL should be within expectations in terms of performance (with even decent gaming capabilities) and battery life for that segment but Intel will have to rely on its OEM partners to deliver laptops attractive enough (design, build quality, ...) to make people opt for them over MacBooks which won't be priced that much higher.
The big marketing angle will probably be AI but it's a huge TBD whether consumers actually want Copilot+/NPUs.
FlameTail
4,384
2,763
Serious question;
Do you guys think Lunar Lake could beat the battery life of Snapdragon X Elite?
Magio
214
261
Serious question;
If I had to bet today I'd say it will win on some loads (medium loads and video playback), lose on others (low loads and idle) and be largely equal in a "whole picture" scenario.
Reactions: SiliconFly
GTracing
478
1,114
Serious question;
I think Lunar Lake might match the X Elite in some workloads. I don't think it'll beat it all around.
Intel's QuickSync engine combined with the low power island and better manufacturing nodes should give lunar lake excellent battery life in video playback. I think this is where Lunar Lake will be at its best.
In mixed light/medium usage, they'll be pretty close. I would guess the X Elite will pull ahead. Though as CPUs get more efficient, they become less and less of a factor in the overall battery life of a device in light workloads. If it's 15 hours vs 14 hours then it will only matter for bragging rights.
In heavy single threaded load, the X Elite will win unless Intel puts a sane cap on the single core power draw. If you limit both chips to 8W power draw, then the efficiency will be similar.
In heavy multi threaded benchmarks the X Elite will win hands down, assuming similar power limits. If the X Elite is given an 80W power limit then lunar lake will obviously "win" in efficiency.
dullard
26,200
4,871
Since no one posted it, Intel discussed a little bit about 18A today (Panther Lake and Clearwater Forest).
and
Key takeaways (these are direct quotes from the links above):
  • Both Panther Lake and Clearwater Forest booted without additional configurations
  • Panther Lake DDR memory performance already running at target frequency
  • First external customer is expected to tape out on Intel 18A in the first half of next year.
  • The Panther Lake client processor is powered on and booting Windows, yielding well, in use inside Intel and ahead of schedule on product qualification milestones
  • Clearwater Forest for data center is powered on, booting operating systems, in use inside Intel and performing well
Reading between the two lines above, they did not specifically mention yielding well for Clearwater Forest, nor did they specifically mention performing well for Panther Lake. That doesn't necessarily mean anything. But it is interesting to have those left out.
Ghostsonplanets
774
1,228
and
Good to see that Panther Lake is yielding well and ahead of schedule. I genuinely believe it will be a good product. And the variants of PTL, that will release later, are going to provide Intel much needed competitiveness in some key markets.
DavidC1
2,199
3,358
Meteorlake has a low power island, a "proper" one with it on an entirely different die.* It saves an amazing 150mW in video playback, a whopping 4% increase in battery life.
In Lunarlake, there are other factors that will give it real gains:
-System Cache, which will cut traffic to memory and reduce power. Keeping it as close as possible to the core is touted as being a necessity to lower power in all future compute.
-The Skymont E core actually scales really well. It seems like at least half the battery life improvement will come from having workload reside in Skymont. They claim Skymont's ability to scale is what enables Microsoft Teams to reside entirely on the E core cluster, when Meteorlake LPE was too slow to do more than basic(and don't forget about the 0.15W improvement).
-A more sane 2-tile setup from a 4-tile one in Meteorlake.
-Unlike previous implementation that just has LPDDR support, Lunarlake actually optimizes it to lower power. They say the PHY power is also 40% lower than the predecessor, matching the SoC gains.
*Meteorlake's tile approach and the LPE core may be an example of what sounded good in high level not working in reality. Having it in another tile means it needs to actually hand off workloads between two tiles without both of them being active for a significant amount of time.
Color me skeptical.
-Does Pantherlake have a System Level Cache?
-It has more tiles again.
-Why are they separating E and LPE again? Will LPE be on another tile like Meteorlake? If separation of E and LPE exist, then at least it should be on the same tile. High communication latency is responsible for practical battery life not being high as planned.
-What about a proper low power optimized LPDDRx PHY? I doubt they'll do it for the entire lineup, because it'll likely hurt performance in some way.
Performance-wise it might be fine. What about battery life? Will Lunarlake be a one-hit wonder with no successor like many previous Intel products that was supposed to be great?
Are they so cautious that they can't dedicate a Lunarlake successor? Because without such specialization it will suffer in either market, or be mediocre in both. The cynic in me says there's nothing after Lunarlake because they are confident Lunarlake will render the WoA market dead, and thus a lesser successor will be enough.
Reactions: Ghostsonplanets
DavidC1
2,199
3,358
Intel Foundry needs a big advantage over TSMC in technicals and do it successfully for many years before they'll take any significant amount of share.
How long did AMD successfully execute over Intel until now? Think about why they are saying growth won't come until 2030. This is assuming they execute. Maybe they'll get 5% at best. 10% will be a huge win. 2030 is about 5 years away now. Not a long time.
Having industry standard tools is just a start. You still need to work as a customer to move things from TSMC to Intel, no? Like if you are used to working on Office for many years, would you move to OpenOffice? What about Blender to other 3D design programs? Even if the alternative gave you a real easy way to migrate you still need to take a day or few to migrate them, because it's disruptive to your workflow.
With them saying 14A offers a mere 15% performance and 20% density advantage, this is going to be a painful many years before the Foundry achieves financially material impact.
Relying on Taiwan being taken for Intel Foundry to succeed is the biggest delusion there is. Because if Taiwan is taken, they'll instantly lose 20% of total revenue on China being gone as a customer. And surely a World War 3 is bullish right?
Ghostsonplanets
774
1,228
AFAIK yes
Correct. It needs to cover more markets (U to H) and thus needs more flexible tiles than an ultra-specialized part like LNL. But PTL only has one extra tile than LNL. It's no MTL, be assured.
LPE and E live on the same tile. And they have the new core topology (Which I believe debuts with ARL? Not sure) which allows LPE cores to be used on any workloads. It's a proper, Arm like, multi-cluster scheduler scheme this time. Unlike MTL weird one.
That I do not know.
They're aiming at better than Lunar Lake last I heard. But without any specifics or if it only applies to certain SKUs.
LNL is a new swimlane that has no proper successor so far, yes. PTL-U is the closest thing to a successor due to 4P + 4LPE and >50 TOPs NPU and some SKUs that might feature on-package memory. But the iGP is half the size.
I think, if LNL proves a success, Intel will integrate them into the standard generation product line-up. Maybe we'll see something proper with Nova Lake Mobile or Razor Lake (Lake Next after NVL) Mobile.
As I said, I think it's a matter of new swimlane, different priorities and Intel going on a faster schedule.
Lunar Lake will need to prove it to be popular for Intel to create further iterations. And Intel is on a faster schedule where they're trying to bring new mobile designs faster to compensante for the lethargy of past years. So some SKUs will co-exist.
And by priorities, I mean there's only so much projects they can tackle while there's a lot of markets they need to cover. They're doing Panther Lake U and H. That's already a lot of SKUs that need to be ready.
But they identified a gap into their product line-up that is the fact they have no SKU/Product that can attend the budget market outside of RPL 282. Thus, they choose to do Wildcat Lake, which is a "Panther Lake U Lite" for the budget market. Same technologies/IP (Core, GFX, NPU) as PTL, but in a much smaller configuration.
I'm sure by NVL and/or RZL they'll have everything sorted out to give every segment a new product in the same cadence.
DavidC1
2,199
3,358
Lunarlake is currently the only promising client part for Intel. Arrowlake seems nothing special. 5% ST? We used to get that with Ticks.
Unless Pantherlake has something that covers deficiencies, don't count on it.
Lunarlake proves that they need a separate lineup for low power. They had to do that for server right?
By logic LPE can't be "used on any workloads". It is limited by it's performance. Lunarlake's two core setup can already use the E cores for boosting performance. That means the "LPE" core is going to be low frequency again.
Also 4+8+4LPE isn't gonna be a performance leader, similar to not counting Meteorlake as 6+8+2. 6+8 is already low. How will they cover the -H market in 2026?
I hoped they would continue the excellent battery life that Cherry Trail Tablets had. In Braswell they completely gave that up. Why? Because by eliminating that lineup they could save extra few hundred million. They need a specialized lineup again not a generic one.
SoCs aimed at respective markets
-Server P
-Server E for Cloud/VM
-Client High end mobile to Client Desktop: 45W-125W
-Client ultra battery life<--9W to 35W
5,565
4,967
Color me skeptical.
Meteor Lake is way efficient than the Intel 7 RPL-H the battery life advantage is really nice but that doesn't come from LP-E as most workload go to the normal E cores and are kept there for the most part
As for PTL tiles i think the LPE and E exists on the same die 18A for PTL it is NPU+CPU+Media IP+IMC on 18A GPU on N3E/I3 misc on N6
Reactions: hemedans
511
5,565
4,967
For this part sadly it is the truth from TSMC as well node shrinks will be limited to 20% and PPW by 10-15% this is true to industry you can look at N2/A16
Reactions: hemedans
Doug S
3,867
6,840
Maybe you need to take a look at what TSMC is promising for upcoming shrinks before using "mere" to describe what 14A is offering. That's pretty much par for the course for now on unless/until we figure out how to shrink SRAM cells or replace them with something that will shrink.
Henry swagger
514
314
Well said
coercitiv
7,519
17,992
David's argument was that Intel needs to be significantly better than TSMC to steal business from them. The fact that laws of physics seem to deny us progress on further nodes does not change the sales and marketing conundrum for Intel when competing with TSMC.
Just as he said, AMD executed very well for many years before they started getting more customers in servers and mobile, and they're still facing a head wind. Inertia is huge in this field.
Ghostsonplanets
774
1,228
I do agree it's unlikely. Specially as LNL had to be pretty specialized to get the battery life gains it had. I can only assume they're banking on further improved fabrics, idle and better tuned load consumption due to BSPDN and RibbonFET
Yes. What I meant is that it can be leveraged on MT workloads and work as an proper core. Rather than MTL P + E -> LPE
That honestly I don't know. Maybe Desktop 35W silicon will be brought to Laptops to cover the 45W/55W luggable/High-end Gaming Laptops markets.
I do agree with you. Been saying for years that the killing of Atom and Core M is one of the reasons Intel got so behind in power efficiency. Short-sighted gains back them translated into a struggling future currently.
-Server P
- Agreed. Intel will need to be very agressive here
- According to Exist, that's dead after CWF. Dunno how Intel will handle the server many cores after the merging of E into P. Maybe Zen C like but for Intel P core?
- Agreed
- Agreed. Though there's need to many SoCs/dies/tiles in this specific segment as there's varying levels of performance requirements but also pricing. WCL, for example, is basically due to Intel tiled + advanced packaging approach being expensive and thus they needed a different approach to provide budget markets a successor (I believe AMD will also struggle here with Zen 6).
FlameTail
4,384
2,763
Considering how strong Skymont E-core is, I'd guess 8E+4LPE = 8P.
Then 4P+8P+4LPE = 12P
FlameTail
4,384
2,763
How is P-core and E-core team merged, if they are based in different countries?
Ghostsonplanets
774
1,228
? You're aware core design is made on multiple countries, right? And also remote work.
Besides, what Exist (and others) were trying to say is that both teams will be merged into one to develop a single core design with influences from both + Royal leftover work (supposedly). To be fair, he also did say it's not 100% certain that E Team will be under P Team. Could be the opposite. But it's very likely that P Team wins the politics at Intel.
dttprofessor
166
45
Intel must increase more profits first through LNL/ARL/SRF/CWF/PTL(maybe 10-20B$),whatever products on TSMC or internal fab or any other fab,before the next Grand Strateg。 Pat must buy time for intel & himself.
511
5,565
4,967
Apparently darkmont is to skymont what Crestmont was to Gracemont also at lower Power i bet E core wins vs P core as evident with Crestmont Redwood Cove they need to bring Quite better PPA than Strix Point 12/24T
