Page 400 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
858
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
DavidC1
2,187
3,340
Otherwise they would say that the PBU is completely new with new algorithms or something like that and not that the PBU block is 8 times larger.
Sure it is! It's logical analysis. Enlarging the entire BPU block by 8x is prohibitive, just based on your pictures you had a while ago.
And it's not supported by performance, which means either A) the increase is nowhere near you are expecting. B) The team, not just the design needs to be replaced with such unbalanced design choices.
Like I said, enlarging entire BPU would mean ridiculous sizes such as a 60K BTB, which is unprecedented in the history of CPUs, and we aren't in the golden days of scaling anymore where they can afford such braindead decisions. We've been talking about them bloating ROB sizes, but now you are saying they'll do even worse but with the branch predictor?
They would have said "8x Branch prediction capability/BTB sizes". Instead they said prediction block. It means it's a subset. Do you expect that it'll suddenly go from 14% to say 30% or something? It's Zen 5 level hopium. What would justify them increasing one significant block that much? If instead they moved to 8x decoder width or ROB size, would you still think it's a sane decision? Even if they did go to 48-wide decoder or 4,000 entry ROB the best they would have got from that waste is 5-10% at most.
Reactions: inf64
DrMrLordX
23,229
13,312
TSMC's N3B capacity is limited, N3E is where the volume is. For either issue the solution would have been for Intel to port to N3E, but for whatever reason they chose not to. So if that means RPL has to continue on longer as a result that's kind of their fault, since I doubt TSMC was forcing them to choose/stick with N3B.
Intel has as much N3B as $10 billion would buy them. If they're wafer-limited for Arrow Lake, it's because Intel couldn't afford to buy more (and/or TSMC put limits on how many fabs they could convert to fill Intel's order; they had to convert a research fab to full production, allegedly).
DavidC1
2,187
3,340
Lol, Bionic Squash says only cache changes for Arrowlake's Lion Cove.
It won't be anything worth noting folks. I keep telling everyone, in the world of semis, you have to be prepared to be disappointed. 1-2% gains do NOT come easy.
dttprofessor
165
45
Intel foreveo volume is limited till late 2025.5m per month about.
DavidC1
2,187
3,340
According to AMD, the 16% gains for Zen 5 is split between:
-Data Bandwidth
-Execution/Retire
-Decode/Opcache
-Fetch/Branch Prediction
Eyeballing it in order I would say, 5%, 5%, 4%, 2%.
This is the reality folks. Each gains are responsible for mere few % gains. In a general purpose CPU, the gains come from a balanced increase of ALL parts of the CPU.
DavidC1
2,187
3,340
2 passive dies for PTL. Looks like Intel is converging on a typical configuration for their tiled architectures now, where one die is for CPU compute, another die is for the GPU, and the last die is basically IO and everything else. Oh, and a base tile.
Lol, not expecting too much from the LP E cores again.
DavidC1
2,187
3,340
Lunar Lake has 4 Skymont LPE cores. And it seems to be pretty much perfect.
Because Lunarlake actually has a sane implementation of having only two clusters, and the E core has high dynamic range to address all the way from nearly idle workloads to quite high ones, and unlike MTL it doesn't need to skip to another tile to have it on.
Meteorlake is a complete and utter fail for example. 150mW savings in the Intel demo scenario, so that's like fly on an elephant's butt, and other times it doesn't work. So with Pantherlake they want to adopt MTL's approach again?
mikk
4,333
2,414
Who says they will adopt the same MTL style? Intel clearly didn't. It doesn't even use the same amount of tiles. You think they will adopt it which is probably just nonsense.
Reactions: SiliconFly
mikk
4,333
2,414
True. PTL tile setup is surely gonna be very different from MTL. I don't think Intel's design team is stupid enough to repeat the same mistake again after two years.
LPE cores and IMC also goes into the compute tile, that alone will make a big difference. So for light load they can still disable the Ringbus like on LNL for a much improved battery life. Same MTL style lol.
dullard
26,196
4,869
Let me get this straight. Is it your theory is that:
1) Meteor Lake's implementation is bad,
2) Intel fixed it with Lunar Lake,
Therefore,
3) Intel will break it again and go back to the old implementation for Panther Lake?
If I understand you correctly, what do you base #3 on? They already combined the SOC and Compute tiles to eliminate the complaint you have about skipping to other tiles.
DavidC1
2,187
3,340
If they have it on one die, it's better.
But we should question why the successor of a product that is very low power is suddenly going back to a setup similar to the predecessor - one that did not work very well. By having the third cluster you add additional complexities that they have to make up such as dealing with switching latencies and scheduler complexity.
dullard
26,196
4,869
They already reduced complexity by getting rid of the 4th thread type (the hyperthread). They reduced the performance gaps between cores, meaning less reason to switch cores. Plus by then, more and more software will be programmed to prefer or to avoid specific types of cores.
Bouowmx
1,150
553
To confirm my understanding:
Given the similarity of the platform controller to Lunar Lake's, the compute tile has the LP E cores (software can directly use them?) and memory controller, not like in Meteor Lake. But, Arrow Lake still has the old style.
511
5,516
4,908
This is for one reason going back to inhouse manufacturing also they don't want to fab for bigger GPUs on Intel Node for now so N3E for that IO is just cheap silicon also i guess they will just add 8E to the LNL Design and make other enhancement while keeping off ring LPE seperate in the same compute tile it will not be worse than MTL
Gideon
2,044
5,103
Interesting, where is this info from?
Goop_reformed
316
341
W1zzard from TPU said Arrowlake will be faster than both zen 5 and Zen 4x3d:
