Page 393 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Fjodor2001
4,637
748
I mean they are literally desktop silicon. There is a possibility ARL-HX could be the desktop CPU tile with the mobile SOC tile and iGPU tile, but I would be pretty surprised if that was the case, I doubt it.
But I feel like this is just being pedantic lol.
I for one, think the rumor that the 8+32 desktop sku for ARL-R being canned, is very believable. And the focus on the NPU being improved on ARL-R also makes sense, I suppose they would try to improve it to the point it can hit the 40 TOPs requirement Microsoft wants?
I meant HX has different iGPU and NPU at least, plus different clocks, compared to the similar desktop CPUs. Then there is H series too. And both H and HX are mobile SKUs, and they'll have Arrow Lake Refresh.
Also, to not lose track of the background, the original claim which I commented on was "Arrow Lake refresh is just for desktop", which is simply not correct, if we are to believe the leaked Intel Mobile roadmap that I linked to previously.
cannedlake240
247
138
I've always wondered why Intel has always dedicated so much area (and presumably a decent amount of power) towards core private caches (or even cache available to the core in general) compared to the competition
Presumably to drive high clocks and as C&C says, 'insulate' the cores from slow L3. Even Apple, known for bring generous with caches among mobile soc designers, is using smaller LLC compared to Intel(4mb L2 per core vs 6mb L2 + L3 on ARL).
ARL igp with XMX should have enough tops for Copilot features
TwistedAndy
159
150
So 8P+32E+iGPU+Big NPU. Sounds nice. Would be lots of compute perf.
I do not think there will be any significant changes to the compute tile. It will still have an 8+16 configuration in the top desktop SKU.
The Arrow Lake Refresh will bring the updated SoC tile. It will probably have a bigger NPU and some changes to the memory controller and media engine.
Agreed. But ST perf is still a function of IPC. A 14% IPC uplift can't translate to just 3% ST perf even after factoring in all assumed limitations (like some tile penalty, some clock regression, etc). Also, that 14% is LNL. ARL should be higher. ARL with just 3% overall ST perf increase is just plain wrong imho. Looks like he has a bad sample.
Probably, it was the engineering sample with much lower clocks.
mikk
4,333
2,414
Royal core is probably still a thing, just might not be ready for NVL launch timeframe and will arrive in the generation after nvl. LNC, while an improvement over Golden cove, is still behind Z5 and M4 P cores in area, power. Caches for example, LNC has the largest amount of combined core private and LLC among general purpose high performance cores, while being at PPC parity. Royal core or not they could definitely benefit from a "ground up" core
I'm not so sure about it anymore.
Maybe another Ocean Cove repeat.
Geddagod
1,683
1,720
Lmfao I went back to the tweet you linked and saw this:
@SiliconFly what changed?
Their cache density is fine tbh
They would presumably want to use the NPU for that though, for lower power. If they really were fine with just using an iGPU, it would make no sense that LNL got a beefy NPU, nor would it make sense why other companies are also featuring so much silicon area, as well as marketing, on NPUs.
I wouldn't be sure about that. I always assumed ARL-HX will still have the same SOC and iGPU tile as its desktop brethren.
cannedlake240
247
138
Process difference is huge though, N6 soc and N4P for the new gpu tile. Add to that the xmx capability and the graphics tile might be more efficient, with exception of very light workloads. Maybe 10tops isn't enough even for that, which could explain the larger NPU on the refresh
DrMrLordX
23,227
13,308
A 14% IPC uplift can easily translate over to just 3% ST perf. It would just mean ARL is clocking at the low 5GHz range, rather than the rumored 5.7GHz. And the final version could end up being 5.7GHz, since he even says he has an ES2, but the final ST perf uplift is still likely to be pretty low, as in like 10% perhaps, at best.
There's still that leaked Intel slide from last year showing +5% ST and +20% MT over Raptor Lake at the same core count and PL value. Take out HT from the Arrow Lake P-cores and then use the perf numbers from the 14900k/ks before Intel implemented their stability fixes for UE5 (and other software) and that could still bear out. By the time Arrow Lake comes out it will look like a big uplift over Raptor Lake because of the new microcode updates and performance profiles gimping Raptor Lake performance, but that's not the only comparison that will matter . . .
Reactions: Tlh97 and KompuKare
Hulk
4,120
Could AMD or Intel develop a compiler specifically designed to work optimally with their specific CPU's? If so could such a compiler be used to compile compute heavy applications so that the OS would "pick" the correct version of the software upon installation?
The reason I ask is that it seems we are approaching a point where to optimize hardware, software might have to be compiled with the hardware architecture taken into account.
DavidC1
2,187
3,340
So it was showing those gains against 13900K.
RPL: 8x1.3 + 8 = 18.4
ARL Int: 8x1.14 + 8x1.3 = 19.52(6%)
ARL FP: 8x1.14 + 8x1.6 = 21.92(19%)
Those calculated gains seem to be not far off from Igorlabs leak. We really should not expect LNC in ARL to be higher than 14%. Nothing beside hopeful guesses seem to point ARL to be a monster.
I think when they are saying the design is now more flexible thus faster iterations can happen they are talking about primarily regarding server vs client. Remember the 8-wide decode for Granite Rapids?
Reactions: Tlh97 and Geddagod
Geddagod
1,683
1,720
Well, you answered your own question at the end there...
Pretty sure it got renamed.
I'm sure Panther Cove being in Nova Lake rather than Panther Lake wasn't confusing at all
DavidC1
2,187
3,340
And one more thing...
This one is from the Intel P core team engineer. Lion Cove version that goes into Lunar Lake is different in several aspects compared to the version that goes into Arrow Lake later this year.
They may not even be close! That >20% uplift is still very much a possibility.
Yea you are likely way overestimating the impact. I made such mistakes before when they talked about Sandy Bridge's ring bus allowing much faster iterations. They had more versions for sure, but it didn't come faster. The rate of increase in complexity is so steep that they need such drastic design approach changes just so it doesn't take longer and longer to come out.
This time is different folks. It's not just Intel starting to lose steam this time. It's both Intel and AMD. AMD followed Intel to the crazy clock focus and they are following Intel with the disappointing 16% gain. They are going to need radical overhaul of designs/design teams to counterract ARM.
Looks like Intel has a path forward with the Austin team.
poke01
4,881
6,223
And what's the significance of 422 10-bit HEVC?
Its for videographers. Canon, Fujifilm cameras have the ability to shoot this
You got a RTX 4090 and a 7950x and still you won't be able to smoothly playback 422 without the media engine supporting these codecs.
Reactions: lightisgood
Hitman928
6,755
12,500
They can do 444 and 420 playback, just not 422. I don’t know how big a deal that is for creators outside of some professional cameras that use 422 (can they use 444? No idea).
Hulk
4,120
422/444 are editing formats, 420 is a delivery format.
I would characterize 422 as semi-pro and 444 as pro.
422 holds up much better in post than 420.
poke01
4,881
6,223
Who says power consumption went down?
there has to be some performance per watt improvement right?
I mean they’re jumping from Intel 7 to N3B.
Edit: Those numbers are at 250w, crazy. Wtf, is Intel doing?
