Page 376 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
poke01
4,867
6,194
Lunar Lake GB6 results. Never mind MT scores, but ST scores are ... nothing to be exciting about. I expected a lot more: I expected way over 3000.
https://browser.geekbench.com/v6/cpu/6678431 (ST: 2739)
https://browser.geekbench.com/v6/cpu/6678564 (ST: 2713)
That's slower than Ryzen 9 7945HX in ST mode. Darn. Could be engineering samples but clock speeds (add .gb6 to the URL) are perfectly fine.
I very much disagree. The 7945HX needs to boost to 5.3GHz to achieve 2700.
Lunar achieves 2700 using 4.8GHz, this is not poor relative to AMD.
I would also bet that Lunar’s lion cove is also not as power hungry in 1t.
What we see here M2 like performance and efficiency but for the x86 platform with eGPU support a much better software compatibility. This is good. The GPU should be good as well.
poke01
4,867
6,194
@poke01
I've completely rewritten my message. Yeah, it's not that bad but it's not terribly exciting either. Alder Lake is more than 2 years old at this point, I expected more from a new uArch.
At this point I’m glad Intel is focusing on efficiency but you are right in saying they need major leaps in IPC in future generations.
Hitman928
6,754
12,500
Lunar Lake GB6 results running at roughly 4.9GHz:
An IPC increase is there but I expected more.
At 6GHz that would be 3,353 which is just 8% faster than 14900K Raptor Lake. Not really exciting but then it's a mobile platform, so Arrow Lake should fare better.
The clocks don't appear to be very stable so it's hard to say for sure, but it appears to be ~10% higher performance per clock than MTL in GB6.
Hitman928
6,754
12,500
LNL won't be competing against Zen 4, it's Zen 5 that it will be compared with.
I don't think they'll be competing with M2 in efficiency either, at least not single and low threaded situations. LNL will still take way more power to get clocks up to ~5 GHz.
DavidC1
2,182
3,329
You can't compare an ultra power efficiency optimized platform with similar RAM, and Drive configurations with a essentially unlimited power on desktop. Generally the desktop chips are 5-7% faster than laptop chips of the same uarch.
Battery life, which is defined as bursty workloads is the bigger deal. Getting that will be a big thing, as currently they are very far behind.
Ghostsonplanets
774
1,228
Good scores for Lunar Lake. And that's the 17W SKU rather than the Core Ultra 9 30W.
Gideon
2,044
5,103
Sigh, I really wish Geekbench 6 would have kept the Crypto, FP and Int total scores. The perf per clock is so similar to Zen 5 mobile at similar GHz (which also isn't quite the desktop Zen 5 as it has halved it's FP structures and L3 cache), that separating these score would give a much more thorough overview.
I know this separation can be done manually but i'm too lazy. And the clocks (and reporting) are still all over the place as well. A bit too much to draw any conclusions.
Still I hope Arrow Lake has some surprises in store IPC-wise. Lunar Lake looks to be an excellent SKU overall but the IPC uplift from Raptor Cove (to me) looks a tad dissapointing
~4.8 Ghz 1360P vs ~4.8Ghz Lunar Lake
Well actually 1360P clocked slightly slower:
Lunar Lake:
Mean: 4825.04 MHz
Median: 4874.0 MHz
Core i7-1360P:
Mean: 4723.42 MHz
Median: 4824.0 MHz
The ST difference is 12,2% but taking the mean clock speed into account it's only 9.8%
Then again, comparing to a similarily clocked Meteor Lake U, taking the "chiplet tax" into equation it's actually quite good:
Reactions: Tlh97 and Elfear
AcrosTinus
221
226
Lunar Lake:
Mean: 4825.04 MHz
Median: 4874.0 MHz
Core i7-1360P:
Mean: 4723.42 MHz
Median: 4824.0 MHz
I don't trust geekbench one single bit. I have two systems A: 13700K and B:14900K, both score almost the same -> A: 3000ST and 20000MT and B:3100 and 21700MT. This cannot be this close...
Reactions: Henry swagger
DavidC1
2,182
3,329
The faster 165U results are much closer than that. There's something wrong with that result.
With Geekbench you need to take top scores for that very reason.
Geekbench did two fatal mistakes, one not separating the Int/FP results and the other taking out the ability to sort by lowest/highest scores.
User-submitted results like GB is the worst way to isolate pure uarch differences when we care about 1%.
dullard
26,196
4,868
Yea, we never heard anybody speculating how great it would be to remove HT until it came out that newer Intel designs would not have it. Now it is being proclaimed as the greatest thing since sliced bread. A classical case of rationalization, IMO.
It is nice to see how things have come full circle now. 2 decades ago the argument was all about how hyperthreading REDUCED performance on many programs. Then it slowly got better, to the point that you no longer had to turn off hyperthreading at it was on average roughly the same performance ( https://www.anandtech.com/show/1031/6 ). You would see some software improve and some get worse at that point in time. Then as software got more multithreaded, hyperthreading got better and better. But now as CPUs get more cores, the hyperthreading gets worse and worse.
I do like how you claim that no one speculated on removing HT, when it is easy to prove otherwise. From 2021:
30% boost from Hyperthreading is only in the very best case scenario. Lots of uses see closer to a 10% to 20% gain, some uses have performance losses with hyperthreading turned on (HPC for a notable example where benchmarks run weeks at a time, not seconds). Hyperthreading adds a lot of power and heat, but it gives more threads. So there is a balance between needing to throttle down frequencies vs having more threads running. On a whole, most software gets a small boost. But, only a few programs get 30% boost.
From 2018:
At least they did one thing right, which was to turn off hyperthreading which often destroys CFD performance.
From 2017:
The 7600 was quite an under-appreciated value in chips, especially for those of us that don't get much if any benefit from hyperthreading (meaning the i7 line isn't a good choice).
You could argue that I didn't clearly say "remove HT". I was arguing that HT isn't that great in many cases though.
Hitman928
6,754
12,500
Battery life is also very dependent on SOC/fabric power. I don't expect Intel to catch up with M2's efficiency in either of these aspects. I do think they'll do much better than their current offerings, but M2 is just so far ahead on these that I don't see LNL closing the gap completely.
Hitman928
6,754
12,500
20% plus over meteor lake at 17 watts.. arrow lake hx should be even better 🥇
That's just WFFCtech doing WFFCtech things. Their 185H score is not accurate. That LNL result is only 3% higher than the 185H when it's holding its boost clock. The LNL is clocking lower, so we are again back to LNL being ~10% faster per clock than MTL (actually 7.5% in this case).
Abwx
12,019
4,981
Just like Intel demonstrated, they have 115% single-thread performance at same power with their single-thread optimzed core as SMT-core running one thread.
That s not 15% better ST perf but 15% better perf/watt/area, good luck dealing with obscured metrics.
Gideon
2,044
5,103
That's a linux score (which runs better than windows and seems too high)
But I do agree the WFFC sample is too slow. This one is more representative:
Hitman928
6,754
12,500
That's a 165U, not a 185H. Intel CPUs typically don't benefit from Linux like AMD chips do. Maybe a slight bump. There are plenty of Windows examples scoring very nearly the same. I chose the one I did because it actually maintained its boost clock which made it easier to compare in terms of ppc. We can pick a Windows example though and calculate the average clocks and compare.
This would put LNL at 9% faster clock for clock when taking the average reported clocks. Conclusion is still the same (caveats of the LNL still being pre-release, GB clock reporting errors, and variability in testing still apply).
DavidC1
2,182
3,329
Not having it on client but on server makes lot more sense. With Skymont even more of the MT performance comes from the E cores, meaning taking out HT on just the 8 P cores is even a smaller impact.
And what happens in the future when the gap closes even further? Let's say the P cores lose the 10-12% per clock advantage?
Wolverine2349
538
188
86
Beating a X3D part is gonna be a bit difficult I think. But if ARL top part even comes close to a X3D, I'd consider it a big achievement. At best, we shouldn't expect more than a marginal win. For all practical purposes, they're gonna be more or less equal this year I think.
Beating any X3D part even 8 core one 9800X3D? What about games that scale to more than 8 cores well? Are there any such games?
Cause Intel has good core to core latency beyond 8. AMD beyond 8 dual CCX/CCD and bad latency penalty.
Or do no games have any benefit from more than 8 cores and will not for a long time thus 9800X3D will be all that is needed and best?
SarahKerrigan
735
2,036
Spec dot org has results for the E1050 96 core. Just do a search on google for spec results for ibm power processors and it's one of the first entries.
To give you some perspective:
IBM Power E1050 (2.95 - 3.90 GHz, 96 core, AIX) - [768 instances, 4 chips, SMT8, only 2 threads per core in use) SpecRate2017IntBase=1220 , Peak=1580
IBM Power E1080 (3.55 - 4 GHz, 120 core, AIX) - [120 cores, 8 chips, 960 instances] = SpecRate2017IntBase=1700 , Peak=2170
Kaytus KR1280E2 (AMD EPYC 9754) (256 cores/512 instances) - SpecRate2017IntBase=1930 , Peak=2100
Kaytus KR1280E2 (AMD EPYC 9654) (192 cores/384 instances) - SpecRate2017IntBase=1800 , Peak=1920
Dell PowerEdge R6625 (AMD EPYC 9754 128-Core Processor)- (256 cores/512 instances) = SpecRate2017IntBase=1820 , Peak=1980
Dell PowerEdge R6625 (AMD EPYC 9684X 96-Core Processor) - (192 cores/384 instances) = SpecRate2017IntBase=1790 , Peak=1870
ZTE R8500G5 Server System (1.90 GHz, Intel Xeon Platinum 8490H) - (240 cores/480 instances) = SpecRate2017IntBase=2000 , Peak=2050
HPE Compute Scale-up Server 3200 (1.90 GHz, Intel Xeon Platinum 8490H) - (960 cores/1920 instances) - SpecRate2017IntBase=7310 , Peak=[Not submitted]
IBM Power10 can be configured in a performance competitive manner, but, it doesn't look like they are competitive on a "per-core-throughput" basis.
Sure they are, if you buy IBM's definition of "core", which you shouldn't. (An "SMT8 core" is two cores.)
If one believes in "SMT8 cores" there's a solid advantage over everything else on that list, as best as I can tell. (That being said, the real app for large Power is scale-up HANA, at which it does... fine.)
As already mentioned, Power is not Z. Z single-thread performance is drastically higher.
Gideon
2,044
5,103
Yeah, my bad you compared absolute perf (as did WFFC)
I chose 165U / 1360P particularily as they clock very close to the Lunar Lake sample (on average) and are lower TDP parts.
Reactions: Elfear
