Page 378 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
DavidC1
2,184
3,331
Ghostsonplanets
774
1,228
Why is discrete battlemage coming next year? Or is late Q4? Issues with scaling?
It was supposed to come out later this year. As for the delay, it was due to a supposed new die above G21 that they were working on. Who knows if it will still come to market though.
Supposedly G21 is ready to go though.
Reactions: Tlh97 and poke01
DavidC1
2,184
3,331
The only thing we know about Battlemage discrete release date is rumors and the leaked roadmap a while ago.
Considering how much more efficient Xe2 is, it would be a shame not to have the dGPU version that clearly outclasses A770.
DavidC1
2,184
3,331
LNL 16GB is a single rank memory configuration. Dual rank memory can be up to 10% faster for faster iGPUs. It's certainly not a best case there. 50% over MTL-U 15W was a little off.
So they were sandbagging.
Looks like it's almost 50% faster at the same power compared to Meteorlake's Alchemist and 2x faster than the 15W Alchemist.
Reactions: Tlh97
TESKATLIPOKA
2,696
3,260
IGP looks pretty good, but CB nT is weaker than 7840U at comparable TDPs.
7840U manages ~12,385 pts at 30 W PL2 / Short Burst, 25 W PL1 / Sustained. Link
LNL manages 10,212? pts at 30W.
That's not a good result.
Reactions: Tlh97
uzzi38
2,747
6,657
Not always. 7840U scores around 8K at 15W too, and LNL is competitive there. But yeah, by 20W 7840U jumps to around 10K already, so LNL does definitely fall off at higher TDPs, but for a 4+4 part with no HT, that's a really good result still.
(Numbers are from my own testing on my GPD Win Mini).
Abwx
12,024
4,986
At 30W the 6C/12T 7540U score 10k, while at 15W the 2C + 4c 7545U score about 7.5k, that s the only chips LNL is competititive with CPU wise, 7840U is in another category, and so will be KRK to an even bigger extent.
Reactions: Io Magnesso
TESKATLIPOKA
2,696
3,260
Don't forget 7840U is the previous gen and the missing HT was Intel's choice, which they didn't compensate by using more E-cores.
Kraken 4+4 would offer even better performance in comparison.
If you want high nT performance at low TDP, then LNL doesn't look very competitive.
dullard
26,196
4,868
You are looking at a pre-production chip, with single rank memory, and preliminary drivers. So take things with a little grain of salt. But, that said, I want to know more about this use case where people want to do workstation tasks (such as 3D rendering and modeling) on an ultraportable laptop. All while using a mid-range Lunar Lake pushed to it's power limit. Why is it that this is the specific use case that you point out as important to know about?
TESKATLIPOKA
2,696
3,260
You are looking at a pre-production chip, with single channel memory, and preliminary drivers. So take things with a little grain of salt.
How much does single channel affect CB score? 1%, 3%, 5%, 10%, 20% or more?
Then I can argue why would anyone buy an 8-core LNL, If they will only use It for web and video, never fully loading the CPU.
edit:
If you didn't notice I am talking about nT performance. I hope you don't want to say that's not important.
Reactions: Tlh97 and dr1337
mikk
4,333
2,413
16 threads vs 8 threads? 30W is too high for LNL with 8 cores/8 threads, 17W is a much better sweetspot which is why only 1 SKU is rated with 30W. And by the way he tested a Pre-QS, we have to be careful with these results.
You are looking at a pre-production chip, with single channel memory, and preliminary drivers. So take things with a little grain of salt. But, that said, I want to know more about this use case where people want to do workstation tasks (such as 3D rendering and modeling) on an ultraportable laptop. All while using a mid-range Lunar Lake pushed to it's power limit. Why is it that this is the specific use case that you point out as important to know about?
Single rank not single channel.
TESKATLIPOKA
2,696
3,260
It was Intel's decision. Without using HT for all cores, It would still result in lower score.
I will have to check, If I can't deactivate SMT on my 7840HS and test CB with and without SMT at 30W.
You still see 25% higher CB score from 30W TDP, that is not such a bad result.
Unless they are fake, I don't expect more than 5% gain.
dullard
26,196
4,868
I didn't quickly find a benchmark on Cinebench with single vs. dual rank memory. Igor's Lab has some testing on other software that ranges from 2% to 18% difference and average of 5.4% boost: https://www.igorslab.de/en/performa...in-theory-and-practice-with-cyberpunk-2077/3/
I did notice about the performance you are talking about. The very case that is probably the least likely to be used on an ultraportable laptop CPU. Had this been Arrow Lake then I could almost see someone caring about that, even though a workstation is still the right product for that person. That is why I am asking what use cases that you foresee where will this be important. What 3D modeler gets an ultralight laptop to do intensive 3D modeling work (you know, the reason that you are talking about Cinebench)?
Philste
308
486
But we also shouldn't forget that the 30W Spec was made because OEMs wanted it, Lunar Lake was meant to be 9-17W.
TESKATLIPOKA
2,696
3,260
This is no longer important, as @mikk already pointed out, It is dual-channel.
If I want an ultrabook with <=30W TDP, then unless there is a big difference in price I would choose the one with higher nT performance.
It's not important If I have a use case for It or not.
Simply put, I won't buy a weaker SoC(APU) for the same price just because I can't use all the cores.
dullard
26,196
4,868
Yes, mikk corrected my error. I have edited my post above, I meant to type single-rank not single-channel. It still matters, since this is the slowest memory configuration that you are looking at. The link I provided shows an average of 5.4% gain when going to dual-rank memory.
So you have no use case, can't think of one, yet you specifically pick out one and only one of the multithreaded benchmarks in the leak to talk about? It just isn't a very relevant benchmark for this CPU's target market. I can't wait to play Cinebench on a MSI Claw! https://videocardz.com/newz/msi-con...graded-to-lunar-lake-no-plans-for-amd-version
uzzi38
2,747
6,657
I'll be honest, I don't think the CPU benchmarks are gonna get much better from here. Especially not something like R23 which sits almost entirely in cache anyway.
Hitman928
6,754
12,500
I kind of agree with you, but to be fair, MacBook Airs get compared with Cinebench, Blender, etc., so I don’t see why LNL shouldn’t be compared with these as well.
dullard
26,196
4,868
They might not. So, here is a comparison as close as I could find with the CPU that TESKATLIPOKA suggested (same base frequency, both Windows 11--albeit different versions, same memory size):
Of course, power consumed isn't listed, but at least we can get rough performance guesses.
dullard
26,196
4,868
Yes, there is value to Cinebench data. It is just of less importance to other benchmarks. I'm mostly wondering why he picked the one benchmark of all leaks that shows Lunar Lake in the worst light with the least likely use case to make his conclusion.
I would have used multiple benchmarks and multiple chips at the very least before concluding here (even if just based on preliminary data).
Magio
207
246
If these are the final benchmark results (or close to), I just don't know what the point of LNL is besides making for a good handheld gaming PC chip (but likely an expensive one).
You want something that's good at low power? M series chips destroy it even fanless, and first gen Snapdragon X Elite handily beats it when thermally limited to 20W. Even power limiting Strix to 15W or around there is likely to run circles around it.
And this isn't gonna be a cheap chip, the packaging is advanced, it's N3B, ... So who is this for? Is the entire pitch the fact that it targets 17W on x86 and isn't completely terrible?
Reactions: TESKATLIPOKA
H433x0n
1,224
1,606
We don’t know how Strix performs at <20W, I’m also not sure if SDXE would outperform it under 20W either.
Why not wait until we get a bit more info before declaring anything dead? It’s a different segment than both Strix and SDXE. This is designed to compete with M2 or M3 in MacBook Air with both of them being 8C/8T designs. For chips that have more multicore performance that scales with power there’s ARL-U (MTL on Intel 3) and ARL-H.
Magio
207
246
But based on this, it doesn't really do that. It barely competes with M2, doesn't get anywhere close to M3, and it will launch against M4. I'm not even saying it has to be as good as M4, but be less than 2 gens behind when it launches should have been an attainable goal.
So if the goal was to send the message that they can't compete with Apple Silicon at all but can make a product that's sorta OK in the segment, then those scores are fine but if not they're worrying.
