Page 369 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
TwistedAndy
159
150
You keep using the term Golden Cove. It's not. Intel slides say different.
That's because I consider Raptor Cove to be a slight refresh of Golden Cove. Yes, technically the cores are different and there's a 1-3% difference in terms of IPC, but it's minimal.
Shifting nodes during a refresh is unlikely afaik.
Intel did that with their Tick-Tock model for years to reduce the risks. Also, I don't think Intel is excited to pay TSMC to produce chips when they will have their good node :)
Reactions: Henry swagger
Geddagod
1,680
1,715
Reactions: Ghostsonplanets
Hulk
4,091
Honestly, if Skymont is Raptor Cove from an IPC point of view, I don't see a lot of applications on the desktop that could use 8+32 (over 8+16) outside of CB benchmarking and DC. With Raptor Lake once all of the Raptor Cove physical threads are occupied there is a significant drop in performance on the Gracemont threads. We're looking at a nearly 50% IPC improvement from Gracemont to Skymont. It's massive.
If Lion Cove is +14% over Raptor Cove and can do 5.4GHz all-core and Skymont is delivered as promised Intel will be fine with ARL. More than fine actually. It looks like Intel and AMD have the tech, they just have to deliver it in a timely manner.
Geddagod
1,680
1,715
Napkin math using 5.5GHz nT and 4.6 Ghz nT for LNC and SKMT suggests a ~20% uplift over RPL for INT workloads.
The Hardcard
352
446
If they get the power and thermals under control, an 8+32 might appeal to the low end workstation market. Especially if they can put it into a Mac Studio type box that is portable and quiet, but with enough power for say video, editors, and audio engineers, as well as others who could use that kind of oomph in an easy to move device.
Put in a 5080 GPU with the easy option of lower clocks so it also doesn’t need fans blasting, it will appeal to some.
Geddagod
1,680
1,715
That napkin math is with SMT enabled on LNC or not?
Not enabled. I don't think we are getting SMT on ARL either...
Power, mem bandwidth, and sheer die size and cost all start becoming bigger and bigger issues...
Elfear
7,169
829
Actually, there were no good leaks regarding ARL-R 8+32 being cancelled. I still think it's a possibility.
Based on @Hitman928's chip area calculations, Skymont is ~40-50% the size of Lion Cove. So an 8+32 would be like 21-24 P-cores on one chip area-wise. Is that feasible? It would certainly be a MT monster.
Hulk
4,091
6+24 would be only slightly larger area-wise than 8+16 and deliver nearly the same ST performance a a significant boost in MT now that the E's are so performant.
Reactions: dullard
dullard
26,192
4,861
I've been calling for that 6+24 solution for many years. One example:
...I think Intel is missing out on a potential multithreaded monster: 6 P cores, 24 E cores. Instead they went with 8 P Cores and 16 E cores. Both would use about the same amount of power and about the same amount of silicon area. But 6+24 would blow these away in multi-threaded applications.
Reactions: SiliconFly
Wolverine2349
534
187
86
Well wouldn't it be just as performant single thread as doesn't single thread mean only 1 core? Or does single thread also mean more than 1 core, but limited amount beyond 1 core for SMT?
dullard
26,192
4,861
Come on guys!!! Please don't give Intel any more ideas on how to span E cores. I could see 8+24, perhaps for (uggh) ARL-R, but I really would hate to see them delete P cores in order to include more E cores.
More performance, less power. Why wouldn't you want that. Unless you fall into the false belief that you want P cores for things like gaming.
Wolverine2349
534
187
86
Well more performant lower power P cores so no hybrid scheduling quirks and yes better for gaming for sure.
Maybe the e-cores become the new P cores anyways if the Austin team, is really doing that well and Israel design center is not sometime in a couple or few years???
Reactions: Tlh97 and Elfear
