Page 339 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
gdansk
4,749
8,054
Going by the latest leak from wccftech (i know)
That a 9% or 13% clockspeed deficitt depeding on if you compare aginst 14900K or KS, that you need to overcome with purely IPC
For Intel to reach +20% ST performance over 13900K they need a IPC increase of ~31%
For Intel to reach +20% ST performance over 13900KS they need a IPC increase of ~35%
There was another leak (now deleted) claiming 5.7GHz
Reactions: DavidC1
Wolverine2349
532
185
86
Imagine a hypothetical CPU with only 4 Skymont cores in a budget school laptop. Would run nicely and last forever.
I guess the design of the CPU prevents that but it's an interesting thought experiment.
Or how about a hypothetical 12 core Skymont only desktop CPU. Best option for non hybrid gaming CPU for more than 8 cores in one tile/die/ring? Or does the design of it prevent such a thing even if Skymont IPC really does achieve Golden Cove levels and high 4.XGHz clocks?
Or would real world performance not be that great with the deign by itself and not supplemented by the Lion Cove cores?
Or other weaknesses (latency???) such as latency of Skymont where it would not perform even clock normalized 4.6GHz close across 100% workloads as Golden Cove?
Or would real world performance at 4.6GHz clock normalized by on par across almost all apps as a hypothetical 4.6GHz all 12 P core 12th Gen GLC with HT disabled?
Markfw
May 16, 2002
27,397
16,239
They’re not having issues competing with TSMC leading edge processes. Look at the Sierra Forest benchmarks that uses only Intel silicon taking the lead for x86 efficiency in the 250W TDP range against Bergamo / Genoa on TSMC silicon.
NO, not according to your own link. I did the calculations on perf/watt. lower perf/watt for Xeon = not best efficiency
thats 2 x the reason the power is more than 250 watt, its total lower avg than 500
modelperfavg wattperf/watt
bergamo9754 2p
5609.56​
375.51​
14.93851​
Xeon6780 2p
4233.57​
321.01​
13.18828​
Wolverine2349
532
185
86
Looks like Intel is on track, finally.
Like Intel, can't we have a "small" margin of error... like 10%? 🤔
I too remember seeing 5.7GHz & it looked legit.
I think Skymonts on desktops are a very different beast when compared to the ones in lunar lake. In desktop ARL-S, I think they're directly connected to the ring bus with full access to L3. This provides much better performance, lower latency, at the cost of a little bit of efficiency afaik.
A hypothetical 8+32 ARL-S should be powerful enough to swat top-end Zen5 X3D like a bug.
But would a hypothetical 12 core Skymont clocked 4.6GHz all core perform equally across all apps that don't use AVX512 as a hypothetical 12 p core Rapror Lake HT disabled all core 4.6GHz?
H433x0n
1,224
1,606
bergamo9754 2p
5609.56​
375.51​
14.93851​
Xeon6780 2p
4233.57​
321.01​
13.18828​
you’re selecting the less efficient model and going with a dual socket configuration. I specifically said 250W TDP.
Jun 4, 2024
If you are a CPU enthusiast you should.
I am pretty sure Zen 5 people wanted 20% not 16%. But you are saying 20% and 30% is the same thing.
That makes me doubt your claims.
Here, I will do it for you:
-13 geo mean/watt for Xeon 6780(4233/321)
-15.7 geo mean/watt for EPYC 9754(5905/375)
You claimed 28 for SRF and 21 for EPYC. Again, I doubt your claims, or do a much better job.
What people get up in arms about and what matters is unfortunately orthogonal. But that's an aside, let's focus.
No LOL. 4233/150 = 28.22. Look at the mean not the IQR. Repeat for 9754
Also if we're going to be ants of the peda variety, it's 6780E; non-E reserved for GNR
edit: bah I was looking at 2P: 2855/(~150-170) vs 3944/(~250-270) = ~17 vs ~14 if we use the rough upper end of both, or using the most conservative numbers 2855/170 vs 3944/250, 17 vs 16
You don't seem to not understand how it work.
"The dual Xeon 6780E configuration was at 85% the power consumption on average as AMD's flagship Bergamo processor, the EPYC 9754"
While the performance is only 73% as much as the EPYC 9754:
Like how do you mess up this hard? Just look at the chart ffs.
Repeat after me:
mean performance/mean_power = ppw
4233/(2* ~150-170) vs 5905/(2 * ~250-270)
Markfw
May 16, 2002
27,397
16,239
Added single chip from the same source. and fixed typo 5609 to 5906. Xeon still lower perf/watt I believe I am using exactly what @invisible_city is suggesting
bergamo9754 2p
5905.56​
375.51​
15.72677​
Xeon6780 2p
4233.57​
321.01​
13.18828​
bergamo
9754​
3944.38​
225.05​
17.52668​
Xeon6780
2865.8​
169.1​
16.94737​
H433x0n
1,224
1,606
bergamo9754 2p
5905.56​
375.51​
15.72677​
Xeon6780 2p
4233.57​
321.01​
13.18828​
bergamo
9754​
3944.38​
225.05​
17.52668​
Xeon6780
2865.8​
169.1​
16.94737​
You're conveniently ignoring the 6766E
Markfw
May 16, 2002
27,397
16,239
bergamo9754 2p
5905.56​
375.51​
15.72677​
Xeon6780 2p
4233.57​
321.01​
13.18828​
bergamo9754
3944.38​
225.05​
17.52668​
Xeon6780
2865.8​
169.1​
16.94737​
Xeon6766e
2616.12​
142.1​
18.41042​
It is better on that one. I think the point is that your statement is a little exagaerated I did not check every CPU, One other could even beat that. Could be Genoa, Xeon or Bergamo.
I will not bother to spend the time further.
Edit: and that is one review, chosen by you. Others could be different. I will grant you this is much better than previous Xeons. But Turin is coming. And Intel Xeon Gen 6 I think.
H433x0n
1,224
1,606
bergamo9754 2p
5905.56​
375.51​
15.72677​
Xeon6780 2p
4233.57​
321.01​
13.18828​
bergamo9754
3944.38​
225.05​
17.52668​
Xeon6780
2865.8​
169.1​
16.94737​
Xeon6766e
2616.12​
142.1​
18.41042​
How is it exaggerated if it is correct? Am I supposed to say it's 2nd best to not exaggerate.. wouldn't that be lying?
I personally think this is good news for both Intel & AMD. This is exactly what was needed to fend off further losses to ARM in the data center.
Reactions: pcp7 and Racan
del42sa
191
365
They have provided ample comparisons for both mobile and desktop implementations:
  • on mobile they're comparing with LP-E cores because the Skymont cluster is taking over their role as well
  • for the desktop, they provide an IPC comparison with Raptor Cove, in a simulation where they both have access to the same fabric and memory performance
yes but there is a small diference , the slide where they compare it with Crestmont is Skymont LPE with 4MB L2 + 8MB SLC vs Crestmont LPE 2MB L2 with no L3/SLC cache because in Lunar Lake implementation E-core cluster are isolated from P-core cluster, so they can be switched off and save power.
While slide where they compare it to Raptor Cove is clearly not taken from Lunar Lake, but from comparison with Arrow Lake, where Skymont cores has acces to big L3 cache through P-Core cluster, which affect performance significantly.
from chipsandcheese : "Meteor Lake’s L3 cache may not be the biggest or fastest around, but even a mediocre L3 is miles better than nothing at all. Despite using the same core architecture, Meteor Lake’s E-Cores achieved over 30% better IPC than the LPE-Cores."
https://chipsandcheese.com/2024/05/20/comparing-crestmonts-no-l3-hurts/
Markfw
May 16, 2002
27,397
16,239
First, look at my edit. Second, to evaluate ALL CPUs of both and then says they are king is what is needed before you claim 1st place.
But I do agree it is looking better for both.
Jun 4, 2024
bergamo9754 2p
5905.56​
375.51​
15.72677​
Xeon6780 2p
4233.57​
321.01​
13.18828​
bergamo
9754​
3944.38​
225.05​
17.52668​
Xeon6780
2865.8​
169.1​
16.94737​
Ah, maybe I missed where they stated the avg watt in number, was eyeballing, thanks for summarizing.
  • Love
Reactions: Markfw
gdansk
4,749
8,054
For it to be an effective comparison of efficiency it should be a chart across multiple core power limits. And it doesn't look like we have that from anyone 3rd party. I bet we would if Geekerwan cared about hyperscaler cores.
But in any case it's pretty good for Intel 3 to be competitive with TSMC N5.
Reactions: carancho
H433x0n
1,224
1,606
EPYC 9734 would be the comparison point for the Xeon 6766E. Unfortunately it’s not in the review but should be a bit more efficient than the 9734 in their testing.
Why would it be more efficient? If anything that SKU would be *less* efficient than the 9754.. It's got a larger power budget per core.
Hitman928
6,753
12,492
Lower TDP, lower frequency, less idling cores. The majority of the Phoronix tests don’t max out the cores anyway so having less cores won’t hurt very much but the lower TDP and less idle draw will help efficiency.
Jun 4, 2024
"The dual Xeon 6780E configuration was at 85% the power consumption on average as AMD's flagship Bergamo processor, the EPYC 9754. Or in single socket configurations, the Xeon 6780E was around 66% the power consumption of one EPYC 9754."
edit: Recalculating using the actual average numbers, which I see now, thanks @Markfw
(4233/5905)/(291/375) = .91 for 2P using the average power consumption
(2855/3944)/(169/225) = .96 for 1P using the average power consumption
(4233/5905)/(.85) = .85 for 2P using the stated power consumption
(2855/3944)/(.66) = 1.09 for 1P using the stated power consumption
Not sure where .66 power consumption number comes from for 1P, or .85 for 2P, but whatever.
So it's treading water relative to Bergamo, but much better than Emerald Rapids. Nice step, let's see CWF.
HoveringStyle
22
26
51
It's higher than 21% in Int, but lower than 71% in FP. You got the calculations wrong.
I didn't, check the graphs at 8:35 and 9:40:
Skymont est. (MTL LPE + 38% INT +68% FP) = 1.90 INT 2.86 FP
Ultra 5 125H E 5.66 INT 6.44 FP @ 3.6GHz = 1.57 INT 1.79 FP
i9 14900K E 5.64 INT 6.01 FP @ 3.6GHz = 1.57 INT 1.67 FP
i5 13500H E 5.11 INT 5.79 FP @ 3.5GHz = 1.46 INT 1.65 FP
Ultra 5 125H LPE 3.44 INT 4.26 FP @ 2.5GHz = 1.38 INT 1.70 FP
Reactions: DavidC1
Jun 4, 2024
The Xeon 6780E had an average of 1.17 Watts per core and a peak of 2.47 Watts per core. Meanwhile the AMD EPYC 9754 had a 1.75 Watts per core and a peak of 3.1 Watts per core. The Xeon Platinum 8592+ Emerald Rapids CPU meanwhile equated to an average of 4 Watts per core and a peak of 6.3 Watts per core.
We’re getting some oddities with the reporting, maybe uncore contributing. 6780E is per core half the power use of bergamo (.57 for David :))
Reactions: Henry swagger
