Page 338 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
ondma
3,320
1,709
P cores do well when fed massive amounts of power. If you just keep adding P cores, then within a given power budget, each subsequent P core gets less and less power. Meaning, very soon you get P cores with not enough power to work well. It could actually perform worse in games unless you get a CPU with a pitiful base clock and a massive power hungry turbo clock--but only turbo for the right number of cores to match your game.
If power use and heat dissipation weren't issues, then your desire would be great. But, in a real world situation, no chip can follow your dream path.
Huh?? AMD puts 16 "P" cores in 7950x and they seem to work just fine, and at much lower power than Intel 8+16 which is required to give similar MT performance.
dullard
26,192
4,860
AMD has a more power efficient big core, and a different TDP, so their optimum number of big cores is different than Intel. But even AMD doesn't gain and might lose performance from adding more. Heck, you won't find the 7950X in the leadership position on very many games (if any). It is close, but usually loses out to CPUs with more power per core, bigger cache, etc.
If you want Intel to have more cores, which are efficient at lower power each, well that is their E core.
Reactions: pcp7
HoveringStyle
22
26
51
My point is that the the uplift over non-LP gracemont must be on the order of 20% for int and 50% for fp in Specint, adroc's fud notwithstanding.
Forgot to mention that intel state's on average LP gracemont IPC is down only ~5% with non-LP.
Using the SPEC2017 results in this Geekerwan video (8:15-9:40) and Intel's claimed increases, Skymont's IPC in LNL is 21% and 71% higher in int and fp respectively than RPL-S Gracemont and 30% and 73% higher than RPL-H Gracemont.
Mobile skus have lower IPC, for example, when compared to its appropriate mobile counterpart, RWC saw no IPC regression.
TESKATLIPOKA
2,696
3,260
Intel Lunar Lake Technical Deep Dive - So many Revolutions in One Chip
E-core looks great on paper.
Even a CPU with only Skymont cores would be strong.
P.S. I am kinda more excited about Lunar Lake than Strix.
ondma
3,320
1,709
I thought that was supposed to be Arrow Lake/Lion Cove (new architecture on leading edge process (which turned out to be TSMC!!))
Note: I dont mean to sound like an intel hater, there are plenty of those in this forum already. I would love to see ARL kick butt vs Zen 5. I am somewhat hopeful after these latest leaks that it will at least be competitive (if late vs Zen 5), but remain skeptical since early leaks were so pessimistic. I just get tired of Intel proclaiming all these gains when they cant seem to catch up to AMD in core design and efficiency.
H433x0n
1,224
1,606
They’re not having issues competing with TSMC leading edge processes. Look at the Sierra Forest benchmarks that uses only Intel silicon taking the lead for x86 efficiency in the 250W TDP range against Bergamo / Genoa on TSMC silicon.
Reactions: DavidC1
CouncilorIrissa
786
2,854
AMD's "P" cores are somewhere in-between Golden Cove and Gracemont. Skymont is straight up larger than Z4 is a number of aspects.
Reactions: Tlh97
Jun 4, 2024
In two years,
-P core Intel got 14% gains
-P core AMD got 16% gains
-E core Intel got 50% gains
Three years of 14%: 48%
Three years of 16%: 56%
Skylake was late 2015. So it took the Intel P core team 9 years to deliver 60% gains. E core team did it in two.
Conclusion 1: Three times two year gains of P cores delivered in 2 years. Feast on that. I had a good feeling the E core team will make a breakout someday.
Conclulsion 2: 50% is Bulldozer to Zen level gains. Unlike Bulldozer though Gracemont was pretty good already.
Yeah skymont is wild and the biggest sign that Intel is alive and going to make a comeback. May the tendies print
eek2121
3,473
5,150
This generation x86 was kinda disappointing, eh?
Zen5 = 16% IPC, iso clock
LNL P-core = 14% IPC, clock regression (?)
1. Wait for reviews. The situation with Zen 5 is a lot more interesting than an average. Front end changes are always fun. Some applications aren’t much faster, if at all, others get completely blown up. Don’t misunderstand, if AMD says 16%, that is the average, but there are going to be some inter things north of that average. wait for reviews.
2. Arrow Lake will have a different performance profile from Lunar Lake. so comparisons are meaningless. Skymont is definitely steeling the show, however.
Hero is here lol
similar conclusion. FSP too low for FrameGen on, but too high for FG off
13700k@5.6g, avg 181fps
9900x , avg 229fps
See above.
Back in Gracemont days, Intel said it was approximately like Skylake without giving explicit figures. We found out that the FP is substantially slower(66% advantage for Golden Cove, meaning Skylake is likely 20% or so faster), and even in Integer it wasn't fully up to par.
Now they are saying it'll outright outperform Raptor Cove.
Yes, it is a beast.
Not anymore, things are changing. AMD will have to figure it out because they are going to get clobbered in terms of performance. I figured Intel was going to over perform with skymont based on what was leaked. Now I wonder if they will even lead single core performance.
I am expecting a good 15-20% total single core uplift (ipc + clocks) over Raptor Lake. Multicore is going to come down to what process gets used due to power limits. The more power efficient the process is, the better the performance. We could see Intel lead AMD by a substantial amount here, but they are also (allegedly) pulling back power limits to be similar to AMD’s limits, so who knows?
poke01
4,814
6,140
Those applications that are faster make use of AVX-512. It’s not hard to get. Wasn’t Zen5 supposed to the core everyone was supposed to catch up to…
Hitman928
6,753
12,492
You’re expecting ARL to clock higher than RPL-R?
dullard
26,192
4,860
That isn't the goal with the P cores, and likely never will be. The P cores are to have a single task done ASAP at the cost of high power. Move to a new architecture, or process and the goal is still the same: complete a single task ASAP at the cost of high power. The P cores are for when you want something very responsive and fluid. But, you can't have large numbers of cores all doing tasks at the cost of high power. There is no free lunch. With 8 P cores, running at 125 W, each gets ~15.6 W. Those P cores can clock a lot faster than 16 P cores each with only ~7.8 W. No matter the architecture or process, when you split your power budget up amongst more and more cores, each core gets less and less to work with.
The E cores are designed to be the workhorses that you can spam in large numbers to do grunt work. The real issue was when the P/E core was first released, the E cores were clocked too high and there were too few of them. The result was that the first E cores were neither that efficient nor that good at grunt work. So, people got the whole idea of P and E cores backwards in their mind thinking that P cores were for the grunt work. You have to switch your mindset. You want more E cores for more work done.
desrever
339
831
DavidC1
2,157
3,298
It's higher than 21% in Int, but lower than 71% in FP. You got the calculations wrong.
They are still 19% behind on perf/watt using Intel 3 vs Bergamo using TSMC N5:
Take Skymont, add a few % because it'll be Darkmont, on 18A and 176 cores for -SP and 288 cores for -AP, on Foveros Omni interconnect. Make conclusions.
"Undisputed performance leadership by 2025"
Reactions: Henry swagger
eek2121
3,473
5,150
No, but I am expecting single core clocks to be nearly the same. Multicore clocks may regress, but going from Intel 7 to N3 or Intel 20A will be a substantial improvement.
Jun 4, 2024
You don’t understand what perf/watt means. They are far ahead of bergamo in terms of perf/watt, just behind by 20% in performance.
Around 28 geo mean/watt for SRF, 24 for Bergamo, eyeballing mean power use at 150 for SRF and 250 for bergamo, top parts each.
“The power efficiency story of the Xeon 6700E series is a great one and allows Intel to regain competitiveness on that front and in a number of cases outperforming 4th Gen EPYC in performance-per-Watt for both Genoa(X) and Bergamo”
This is with Crestmont which is slow and hot compared to Skymont, and with a mixture of HPC workloads which Zen5 is optimized for and Crestmont is not
DavidC1
2,157
3,298
Around 28 geo mean/watt for SRF, 21 for Bergamo, eyeballing mean power use at 150 for SRF and 250 for bergamo, top parts each.
You are on a computer, desktop/laptop or smartphone. Use a calculator. Did you not read cutting edge research goes through heroic efforts for 0.5-1% now? Getting 35% when it's 40% is not a small difference.
Here, I will do it for you:
-13 geo mean/watt for Xeon 6780(4233/321)
-15.7 geo mean/watt for EPYC 9754(5905/375)
StinkyPinky
6,991
1,284
DavidC1
2,157
3,298
I’m a scientist, we round to the nearest order of magnitude :D. I don’t care about 1%.
If you are a CPU enthusiast you should.
I am pretty sure Zen 5 people wanted 20% not 16%. But you are saying 20% and 30% is the same thing.
That makes me doubt your claims.
You claimed 28 for SRF and 21 for EPYC. Again, I doubt your claims, or do a much better job.
desrever
339
831
You don't seem to not understand how it work.
"The dual Xeon 6780E configuration was at 85% the power consumption on average as AMD's flagship Bergamo processor, the EPYC 9754"
While the performance is only 73% as much as the EPYC 9754:
Like how do you mess up this hard? Just look at the chart ffs.
Det0x
1,488
5,109
Going by the latest leak from wccftech (i know)
Intel Core Ultra 9 285K “Arrow Lake” Desktop CPU Rumored To Clock Around 5.5 GHz​
Thats a 9% or 13% clockspeed deficit depending on if you compare against 14900K or the KS, that you need to overcome with purely IPC
  • For the 285K to reach +20% ST performance over 13900K they need a IPC increase of ~31%
  • For the 285k to reach +20% ST performance over 13900KS they need a IPC increase of ~35%
*edit*
If the 285k runs at 5.7ghz ST:
  • ..then it need a IPC increase of ~26% to reach the 14900K +20%
  • ...then it need a IPC increase of ~30% to reach the 14900KS +20%
