Page 965 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
regen1
359
441
Now some cross-comparison from this(for X7 358H v U7 255H) would imply SPEC INT Rate per GHz gains a bit higher than 8%(~8.35) but has caveats of different GCC versions, Kernel versions, etc.
Geekerwan and Bibalaptop got slightly under 10% and 6.7% respectively for their reference system configurations of U9 X388H v U9 285H.
Reactions: 511
511
5,424
4,843
I was equalizing it from ARL iso core count (4x vs 4x), but this works too.
Also SLC is slow as fk and pretty much every company that has a SLC (Qcomm + Intel) says it's not mainly about the CPU.
Uh the calculations are wrong no? It's around 16MB L2 for 2 Cores so for 4 won't it be 32.512 MB for Apple? and also we have SLC as well we are forgetting that in this equation Intel has 8MB SLC ARM vendors as well
Reactions: MoogleW
MoogleW
103
48
Yea, based on the Novalake desktop leak of what being little over 10% faster than Arrowlake is not convincing.
Does that rumor still make sense?
Pantherlake IPC alone is one clue. Unless NovaLake has 2% IPC gain on a simultaneous tick and tock after achieving 5% on a tick. Especially on TSMC so there should not be a further regression in clock speeds
We also know NovaLake BLLC exists. Why would they bother if it makes no real difference in performance?
poke01
4,818
6,144
oh no M5 is uh, different.
It has a private L2 now
news to me. interesting, it hasn't been publicly reported.
You are missing E cores as well cause the 8E also have access to 18M L3 it's not for P core alone for 4 P core it would be 3 MB/core
i'm just focusing on P cores for now but yeah makes sense.
it would be 16MB L2 for 4 cores
Geddagod
1,680
1,709
The Apple M4 has 16MB L2 for 4 cores. I think the problem with Apple's and Qcomm's config is that you have to have an acceptable amount of minimum L2.
Multiple vendors have stated that the SLC doesn't really exist for the CPU side. Doesn't matter too much.
Geddagod
1,680
1,709
are we sure though cause on Apple platform i know who to ask though
I'm sure it can be accessed, just like it can be accessed for Qcomm's CPUs, it just doesn't impact perf much.
I mean, the X elite's SLC is only 6MB for example too, and they use a very similar caching hierarchy as Apple.
Reactions: 511
511
5,424
4,843
Same Architect 🤣 🤣 also it is indeed 16MB l2 for 4 Cores very weird that it remains the same regardless of 2/4 Cores
hemedans
305
177
Really? So I guess you didn’t buy any Coffelake, Ice lake, Tiger Lake, Arrow Lake, Raptor lake, Meteor Lake laptops right?
Cause those above architectures sucked at battery life, temps etc and were horrible to use in laptops.
Tiger Lake and below those U and Y tier CPU they had good battery life, you had to choose though either low perfomance and good battery life or more perfomance and less battery life.
Nowadays modern Cpu offer both, you can play AAA games while using 15W or less.
511
5,424
4,843
So what does all the non-English stuff say?
P-Core Comparison: UX9-388H vs. U7-258V​
SPECint Power Consumption Comparison at the Same FrequencyBoth have a maximum frequency of 4.8 GHz.
  • 388H Group: Average IA (Instruction Architecture) power consumption for SPECint is 9.18W.
  • 258V Group: Average power consumption for SPECint is 10.24W.
Performance and Efficiency:At 4.8 GHz, the performance (Perf) of the 388H is approximately 104% of the latter. Calculated out, the efficiency of the former is roughly 16% higher than the latter.
Translation from gemini
Fjodor2001
4,598
739
Perhaps they are talking about efficiency at different frequency, which accounts for the 16% vs 25%. Unclear what frequency was referred to for the 25%.
OneEng2
999
1,200
The average people can also be quite ignorant. There needs to be more of a middle ground. OLEDs are ticking time bomb consumables with their burn in.
I also realized how vapid we can be. My Dell XPS 12 screen was BEAUTIFUL. It all lasted 1 month. After that I didn't think it was anything special at all. While you will notice your battery life, and the fan noise.
We have had this since Nov 2025 and no burn in so far. Seems like its safe for a while. I might just get on it and hide the task bar though.... just in case.
Fjodor2001
4,598
739
The biggest pro
Zen 4 -> 5 was like 16% IPC improvements but this is still decent
Right. Mixed up IPC with the gaming perf improvements for Zen5.
Anyway, Zen4->Zen5 was almost 2 years. So 16% in 2 years is about the same or actually less per year, since PTL got 8-10% in one year.
