Page 334 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
H433x0n
1,224
1,606
Watch me I can grab a screen shot from TechPowerUp review too
Looks like Arrow Lake with 15% more IPC at 5.7GHz will still be behind the 7950X that's weird...
That’s multicore performance. Not the topic of conversation.
coercitiv
7,478
17,870
That doesn’t affect 1T performance.
1T performance can be affected in non-Intel defaults BIOS by disabling TVB and undervolting, allowing max boost even when a core is past the temperature threshold (and using lower voltage)
Let's not derail this thread right after we got juicy info on both Lion Cove and Skymont please.
HurleyBird
2,818
1,553
Skymont looks awesome. But for Lion Cove, Intel's SMT yield was, what, ~25% or so? Maybe a bit less? Still, unless there's a big improvement somewhere else like area, seems a bit "one step forward, two steps back," does it not?
H433x0n
1,224
1,606
Huh? That’s jumping through quite a few hoops there.
If the last gen part has to have TVB disabled for AMD’s next gen Zen 5 to get a win in 1T performance that’s not really a gotcha.
tamz_msc
3,865
3,730
And Intel's aren't?
Smart money is that a small fudge factor exists for both.
Which means IPC is likely to be close enough that the winner comes down to benchmark selection more than anything.
AMD of course should win by a significant margin if we shift from 1t IPC to 1c IPC, with the deletion of hyperthreading.
The two big questions are how badly that deletion hurts Intel, and how well Lion Cove clocks.
Since I haven't seen any mention of AVX512 yet, I'm assuming it's still a no show for consumer chips?
Intel's are less likely to be fudged because they are transparent on the OS, compiler, and benchmark used, while mentioning them in the slide, and not in the end-notes.
As for SMT or lack thereof, it's insignificant.
vanplayer
78
121
66
Lunar Lake is the only one rumored to have a fanless option so the choice is pretty much made for me. I think it'll be good enough to replace my M1 MBA (if it exists).
You mentioned fan/fanless.
From all what I know, fanless option would be hard to clock as high as M4. It's either x86 or N3B problem, maybe both.
gdansk
4,764
8,058
It just needs to clock higher for long enough to run Speedometer 3.0 without throttling :)
HurleyBird
2,818
1,553
Literal cheating isn't the issue. There's no need for it. You fudge by being selective with the tests that contribute to the geomean.
And those charts support that assertion... how?
HurleyBird
2,818
1,553
It doesn’t appear that the LNC in ARL-S will be the variant that has HT support physically removed from the core. Whether or not it gets toggled on before release remains to be seen.
But what's the source/s for all this?
ondma
3,320
1,709
How the tables have turned. If those clocks are real Zen 5 is cooked in 1T and nT performance. It’s best bet is gaming assuming IOSF latency is as bad as predicted.
GG, better luck next time.
Seriously? This thread is getting way ahead of itself. I thought I saw leaks that Zen 5 will have similar clocks, and dont forget ARL is giving up hyperthreading, so the E cores better be really good. ARL will still have to have a really good IPC increase for the P cores to beat Zen 5.
tamz_msc
3,865
3,730
SMT is irrelevant for ST, only relevant for MT in workloads like rendering which aren't done on the CPU anyways.
HurleyBird
2,818
1,553
Using random GB5 sub tests isn’t being selective to fudge the geomean?
I told you, smart money is that both are fudging a bit. I'm not saying that AMD isn't fudging. But AMD obviously could have picked tasks that looked less suspicious and still ended up with a higher IPC if they wanted to. For whatever reason, they didn't.
Reactions: Elfear
tamz_msc
3,865
3,730
Of course it's irrelevant for ST. As far as only being relevant for tasks that are done on GPUs, lol.
Ian's 3DPM is weird code - for every workload that scales like 3DPM does with SMT, I can find another scientific workload that scales in the opposite direction.
4-5 of those are renderers. Who uses the CPU for rendering?
That leaves us with 7-zip. The only relevant consumer workload that shows some benefit from SMT.
Reactions: carancho
H433x0n
1,224
1,606
The Lion Cove IPC figure was pulled directly from Specint 1-copy, GB5, GB6, CB R23 & CB R24.
As far as I can tell AMD didn’t provide a Specint 1-copy number. They didn’t provide a GB5, GB6 or CB R24 number either.
Completely different method of calculating IPC. In comparison, it’s not even close to being as transparent.
majord
509
711
Because they’re not doing anything new and afraid to take risks. They’ve succumbed to incumbent inertia. Skymont laps them in mobile, and Zen 5 desktop parts are meh. Not pushing core counts, efficiency still way behind Apple/Qualcomm/ and now Intel, despite having access to TSMC. GPUs suck. And this is with a nearly dead Intel.
AMD will continue to dominate servers, but pace of innovations has slowed and that will come down too if something doesn’t change. Competition tends to motivate though.
while it may be the case , not making claims either way, but why are you so confident they're "lapped" in mobile by skymont?
20% is insignificant?
DrMrLordX
23,209
13,296
There is also 3DPM v2 which corrects the cache thrashing issue and has some other nice upgrades. It probably doesn't scale so well with SMT.
Also kudos to Intel for Skymont. It'll be interesting to see how Arrow Lake-S shapes up. The ST predictions for Arrow Lake-S may still come true, but I think +20% MT for Arrow Lake-S vs Raptor Lake-S @ PL2=253W is overly conservative.
Henry swagger
513
313
Dnt worry 8+32 model should take care of zen 5 and zen6
coercitiv
7,478
17,870
Lunar Lake vs. Meteor - Lion Cove performance uplift over Redwood Cove drops to around 10% near the end of the power curve. Against Raptor Cove it would a bit lower still, not at the same power though. The main benefits are at lower clocks, where we get 18%+ performance, Raptor Cove would probably look silly here.
Looks to me like we're finally going to get a chip optimized for low power. I wonder how much of this is influenced by the TSMC node.
