Page 321 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
19,217
Israel Design Center, the guys who have been doing P-core design for many years.
They have this stupid brute-force mindset because they've never had to compromise on availability of resources. It's like a bodybuilder hoarding and using up the food in the common room fridge and claiming he can pound anyone to bits and pieces and then getting his ass spanked when someone agile strategically tires him out.
19,217
Is there any technical limitation to it or is it artificial from Intel and mobo makers that require at least one P core active form BIOS settings to POST and boot PC to an OS.
Most likely artificial, just like disabling AVX-512 in Alder Lake. Core i3-N305 is all E-cores.
Wolverine2349
535
187
86
I've said it many times before that Gracemont was already at Sunny Cove/Cypress Cove-level IPC, at least for integer.
I had no doubt in my mind that the initial claims where it was said that Skymont is targeting ADL level performance would be true in the end.
For integer though for FP, wasn't Gracemont even behind Skylake by like a lot which is not good.
If Skymont really has equal or slight better FP and better Integer than Golden Cove and it can clock decently we already have a non hybrid Golden Cove based option with more than 8 cores (could maybe disable the P cores and non hybrid Skymont arch and the dream of a 10-12 P core or more Golden Cove cores like IPC chip on same die) maybe assuming they have good cache and latency levels. Though reports indicate final Skymont will be closer to Tiger Lake than Golden Cove but future Conroe moment looks promising though unlikely this Fall we even have Golden Cove IPC non hybrid good latency high clocked option unfortunately.
Henry swagger
513
313
You will get 12p and 16 p cores from intel on with nova lake and beast lake
jur
47
37
Imo, there's no way Skymont has better fp than GLC. Maybe for scalar and 128 bit vector. GLC has 2x256 bit fma, new adders, 3X256bit load / cycle. Maybe it'll be close in everyday apps with limited amount of vector code. See chipsandcheese golden cove analysis; Golden cove core has huge throughput, but it's ineffective / hard to access these resources, not to mention, they disabled AVX512. Skymont seems to be designed with less raw horsepower in mind, but more effectively with improvements that affect greater amount of code base.
Wolverine2349
535
187
86
On the same die so no cross die severe latency penalty unlike with AMD dual CCD/CCX?
Though looks like at least 2.5 year wait for Nova Lake as late 2026 release date with vache in early 2027 per MLID.
Wish there was a more than 8 P core option much sooner or almost now with Golden Cove or better latency and IPC and clocks on same die/ring/CCD/CCX/tile/whatever.
Elfear
7,169
829
If the 38%/68% gains are against Crestmont:
It'll be 18% faster than Golden Cove in Integer and 6% faster in FP.
It's near Cortex X4 level, not X2.
We don't know.
Just to make sure I'm picking up what you're putting down, are you saying Skymont will be outright 18%/6% faster than Golden Cove in INT/FP or have 18%/6% better IPC?
DavidC1
2,178
3,328
Those same "reports" are basing it on the "double-digit" claim, not that the double digit might be more than 30%.
Henry swagger
513
313
I think they.ll use fevoros omni on nova lake or use tsmc technology.. for better tile communication if its 16+ 32 tiles
Mahboi
1,058
1,969
Frankly with "double digit" meaning anything between 10% and 99%, I always consider it to be the worst way to present any increase.
It's basically admitting that you don't have that much.
Reactions: Tlh97 and inf64
DavidC1
2,178
3,328
Like the results for SpecCPU shows, Golden Cove is 23%/66% faster in Int and FP respectively.
If you take 5% for Crestmont and add 38% for Int and 68% for FP, you get my figure.
Of course for real world applications it will vary, and Spec is also a composite benchmark so some tests will do better than others. I'm talking about overall. "Outright" of course depends on the context. If they are clocked the same it should be in the ballpark I said.
Think of Nehalem vs Penryn. Nehalem is basically Penryn with a vastly improved memory and communications system. Nearly the same core, but greatly enhanced uncore.
So as a core Skymont is very competent just like Gracemont was. Darkmont-based Clearwater Forest on 18A with Foveros Direct sounds good to me.
Reactions: Henry swagger
DavidC1
2,178
3,328
At some point, diminishing returns will hit the E core like they do for every design. These huge gains are the product of 1) starting with a lower baseline, and 2) giving way more transistor budget to the design than before. It used to be ~4 E-cores equal the area of 1 P-core, and with Skymont it's closer to 2:1.
It's 3:1 not 2:1. It's a massacre.
Yeah.
I know what SKT is and isn't.
Why not just admit you were wrong? You were expecting 10-20% at best.
DavidC1
2,178
3,328
Israel Design Center, the guys who have been doing P-core design for many years. If Skymont is indeed +38% INT and +68% FP IPC, it's gonna end up within 10-20% IPC of Lion Cove, at less than half the area and power.
Are you sending us hints on how Lion Cove will perform? :)
Elfear
7,169
829
Okay, so you're saying the average IPC will be 18%/6% better. That makes sense. I was trying to wrap my mind around Arrow Lake e-cores being that much faster than Alder Lake P-cores.😯
I mean it does depend on Skymont clocks but I can't imagine they'll be that close to the P-cores.
DavidC1
2,178
3,328
Bonnell/Saltwell: 1x, 2-wide
Silvermont: 1.5x, 2-wide
Goldmont: 2x, 3-wide
Goldmont Plus: 2.7x, 3-wide
Tremont: 3.6x, 6-wide
Gracemont: 4.7x, 6-wide
Skymont: 6.5x, 9-wide
If this continues, the Arctic Wolf should be 8.5x, 12-wide. With another 30% gain they'll have to seriously think of doing a drastic change of the P cores.
Also: https://www.techpowerup.com/317317/...res-show-ipc-regression-over-raptor-lake?cp=3
With another 30%, Apple M3 is next. Considering where it started from, it's really good.
ondma
3,320
1,709
Keep in mind though, even if the IPC figures are correct (I still find them hard to believe), Skymont will have a lower frequency as well as lacking hyperthreading, so the performance will be quite a bit lower. If SKM really is as good as the rumors indicate though, that should help mitigate the lack of HT in the P cores.
