Page 312 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
50% faster than 165U in timespy at 17W roughly makes it 3000 points, I've heard 5000 points at 30W. But how well does it in real games, 3dmark never was the problem for MTL or ALchemist. I hope Xe2 does better in real games.
Only 30% lower against 7840U certainly isn’t that impressive. Expected much more given it's a specialized part. But at least it's shaping up to be a good enough.
Only 50% faster than MTL-U7 165U is certainly a bit disappointing compared to the 2x expectations. Specially given it's a 1024 ALU part at >=1.5GHz.
MS Teams video conferencing is literally best case scenario for Phoenix, it's like the one workload where AMD had a solid lead in battery for a while. This is genuinely a really damn good result.
Yeah it's a pretty good BL part.
It doesn't compete with HPT tho.
Could the NPU played a part, since it was a AI focused Teams benchmark?
Explains then why Intel is not comparing Lunar Lake to MTL or RPL, at the same time as it is comparing with QCOM and AMD...
AMD stated that 7840 Pro gets 6:48 hours in MS Teams. If we go by Intel quoted figure, that means >8+ hours for Lunar Lake devices. Fairly impressive then.
It was an NPU based test. Qualcomm did the basically the same test with MTL with AI effects and the X Elite had a huge lead in Teams in regards to battery life.
At first I was very underwelmed with the 1.5× figure, but then I saw it was the 17W one. If intel can get their stuff together and launch a XeSS 2.0 with Frame Gen that is implemented in many games, it could be a good iGPU. It also has the XMX Units for the good Version of XeSS, which already got praised when the DP4a Version was criticised. And even the latter seems to be really good now. If 5000 Timespy at 30W is true, it may even come close to Strix in that department.
50% faster at 17W vs MTL-U at 15W still unfortunately puts it behind Phoenix at 15W in actual games, at that power config MTL was often only half as fast as Phoenix/Hawk Point. I'd seen performance estimations for LNL over MTL/ADL in a couple of (synthetic) workloads but they were very large ranges and 50% does end up on the lower end of the scale. I'm actually still holding out a little hope we see larger gains in real workloads.
But even assuming we're looking at 50% it's now close enough that if LNL scales down to lower power levels better than PHX/HPT (AKA doesn't completely fall apart below 12W) that still makes LNL a very viable part for gaming handhelds. Fingers crossed, I do want viable Intel parts for handhelds.
Robert Hallock says the LP Island has 2x the compute over MTL, which is kinda surprising to me considering LNL has 2x as many LP cores as MTL already. I was expecting more than 2x because the LP cores should be beefier on an individual basis due to them being Skymont. That is, unless LNL's LP cores are clocked lower than MTL's...
