Page 313 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
poke01
4,836
6,163
So with Intel saying it’s faster in core performance than X Elite and AMD does that mean it will be in between M3 and X Elite in terms of ST?
That’s a good jump from MTL
SpudLobby
1,041
702
SpudLobby
1,041
702
A bit.
HPT isn't kilobuck+ le AIPC materiel.
X Plus starting at $999 even from MS? But yeah Hawk Point will get a bit lower.
Very much measurably so. Good effort on Intel part; perf's just unremarkable.
Better than MTL I believe - I might even buy one because of compatibility. Better than SDXE? Skeptical it’ll be enough to matter. But a good effort from Intel to improve? I believe that.
very well
Hope so!
Thunder 57
4,269
7,066
Looks interesting other than that silly slide that included "faster". My guess is that means the cores won't be all that much faster, but the perf/watt looks to be much better. I expect it to do well in low power/battery life areas.
It's also pretty crazy how quickly they are moving on this. It feels like we just got MTL, and now we are looking at LNL in time for back to school season perhaps? Not quite as fast as Broadwell to Skylake IIRC, but still impressive. Now if Intel could just give us some fresh news on ARL, that's be super nice. It seems its been awhile since both Intel and AMD have kept things quiet so close to launch.
Thunder 57
4,269
7,066
perf is meh.
BL good.
Because it got like a year worth of delays.
It was a late Q1'23 part, remember?
I was just making a statement. I know it was delayed. So was Broadwell. What kind of performance? Somewhere between "meh" and "faster"? Closer to which one?
AMDK11
496
441
Saying FP/ALU portion increased by 100% is misleading. If anything they put FP in separate ports from the ALUs. However the gain is likely small, because they typically aren't utilized full all the time thus sharing ports reduces transistor count thus die and power. Since CPUs have been forever limited by power, it further reduces the impact. Of course analysis is likely redone every generation.
Also specifically about the Lion Cove+ as some calls it for Lunarlake, some were talking about an extra cache level called L0. So that might be the extra block rather than separated L2 blocks.
I think you're also missing something on the uop width portion with the drastic increase to 14, understandable since Intel said nothing about Lion Cove. It would be nice to see a 30% uarch gain to counter rumored 10% clock loss but many reputable leakers and insiders did not seem to be positive in terms of Lion Cove for performance so the typical 20% figure is likely.
So I'd temper the expectations down a bit. But the Zen 5 guys are also prepared to be disappointed with the latest rumored performance gains lower than high level architectural gains. Maybe both are sandbagging, or maybe both will disappoint.
@Henry swagger Gracemont already beats Skylake in Integer, and it would be a disappointment to see only 16-18% gain since Crestmont is already 4-6% faster. In fact to live up to previous gains, Skymont should be 30% on TOP of Crestmont, and that'll get us to roughly Golden Cove, beating it noticeably in Integer and losing significantly in FP.
I understand what you are saying that going from 3x FP-ALU and 2x ALU to 4x FPU and 6x ALU, i.e. + 2x more, is misleading. I am aware of this. What I mean is that in LionCove there will be 2x more ALU + FPU execution ports, so a total of 10 instead of 5, which does not necessarily mean a greater increase in IPC than ~20%.
It would be surprising if these additional 4 FP ports turned out to be separately scheduled FP-ALUs, resulting in as many as 10 ALUs. But this is more wishful thinking than reality.
As for the split L2, there have been rumors that the L2 in LionCove is 512KB + 2.5MB, so it would fit this theory.
L0 is rather close to the Front-End.
As for the 24 uops from the decoder and cache (L0), it is an increase of 71% compared to 14 in GoldenCove, but at the moment it is difficult to say clearly how much of it falls on the decoder.
the rumors talked about Dispatch wide 8 but did not directly refer to the width of the decoder.
TESKATLIPOKA
2,696
3,260
I hope they are sandbagging GPU perf or Timespy is a worst case scenario for BMG (as it was a best case scenario for ACM), because 1.5x with double Xe Cores/ALUs is a bigger disaster than even RDNA3.
780M is barely better than 680M, so 50% increase for BMG and that at 17W TDP can't be called as a bigger disaster than RDNA3.
But what's important is performance in games as we all know Intel's IGPs were always performing above their actual gaming performance in TimeSpy.
Kepler_L2
1,081
4,674
No, this would be the equivalent of 12 CU Phoenix vs 6 CU Rembrandt.
