Page 288 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
coercitiv
7,474
17,861
But of course, if the main benefit is that the NEXT CPU is easier to make means the first CPU gets few of the benefits and all of the drawbacks.
The most import benefit of tiles is significant reduction in validation times. Allows them to iterate very rapidly.
We'll have to wait and see how their execution improves with the next few product launches. I would still have liked to see tiles delivered in desktop and HEDT first, as the mobile chips need to squeeze efficiency from every source possible. Also, let's hope they don't have a change of heart with regards to the optimal number of tiles in their mobile lineup, otherwise the first two generations will get the few benefit / all drawbacks treatment.
That being said, ANY tile approach is a welcome addition from Intel in my book, I said before they need experience with disaggregation before they learn how to make it work competitively. Like I said already, this experience will pay dividends in the future.
Hulk
4,062
It's 100% better than RPL without a doubt (I was just talking abt ST).
Almost everything in MTL is awesome. The tiles, GPU, NPU, new process, SoC, NoC Interconnect, Foveros, etc. Everything is perfect; except RWC. :(
And tbh, I'm not a big fan of RWC. It let me down. Thank god they're killing it sooner rather than later.
I believe that the minor changes to Rapter Cove to turn in into Redwood Cove were simply to offset the latency penalty in moving to the tile based format. I write this because the only evidence we have to any changes to Raptor Cove>Redwood Cove are the "larger L2 cache" as written about by Anandtech. This would be the obvious simple change to offset the tiled latency.
Raptor Cove and Redwood Cove in their respective parts have essentially the same IPC. The E's (Crestmont) in MTL do seem to show some minor but measurable IPC improvement. It was reported in Anandtech to be 4-6%.
As someone else noted the MTL will be the baseline for ARL, which is good for Intel. While MTL is not a bad part, and is exciting on paper, in execution there isn't much to be cheering about. It is however serving it's purpose of making the move to tiles from monolithic for Intel. For ARL they only need to work with the CPU tile since the rest of it is basically the same as MTL.
Reactions: spursindonesia
19,210
Ghostsonplanets
774
1,228
Chips 'N Cheese has been dropping some amazing content on MTL GFX IP. Intel really has a solid and very competitive part, if let down by still immature software.
FlameTail
4,384
2,762
Lunar Laks sounds like it will be perfect for gaming handhelds, but there is a potential issue:
The 8-core CPU: Well, what's the problem, you ask. Most games are optimized for 8-core CPUs, right?
But the caveat is that when people say that- they mean a CPU having 8 P-cores with SMT.
Lunar Lake has a 4P+4E CPU, meaning half of the cores are E-cores. And non of them have SMT!
dullard
26,192
4,859
Most games are optimized for 4-core or 6-core CPUs. This is because that is what was available for quite a few gaming systems for many years. But maybe you want to exclude the entire history of games and only focus on new games. Some new games do better with 8 cores and very, very few benefit from more than 8 cores.
I'll talk about AMD CPUs here since they make the core count easier to explain without complications of E cores. Compare the Ryzen 7700X (8 cores) vs 7600X (6 cores). Compare the Ryzen 7700 (8 cores) vs 7600 (6 cores). Notice that there is only a tiny difference in gaming performance.
https://www.techspot.com/review/2602-amd-ryzen-7600-7700-7900/
Reactions: Joe NYC and Hulk
Ghostsonplanets
774
1,228
Lunar Lake setup is more like Apple M series rather than current Intel hybrid. The E cores are more like LPE cores. They don't have L3 cache neither have access to the 4P L3 (They're "off-ring"). So the P core needs to do C2C with the LPE cores.
So I don't know how that would fare with gaming workloads. Lack of HT will hurt here as the P cores could provide some additional performance in gaming if they had it.
But I would actually like to see LNL on HH PCs because it would mean it's available at cheaper price points and I can have hope (inhales hopium) LNL will also appear on <$800 laptops.
A fanless, highly-efficient x86 laptop would be "chief kiss"
S'renne
151
109
86
Didn't some older games instead runs worse on cores with HT?
Ghostsonplanets
774
1,228
Yes in some games, no on others. Very game dependent.
Not only that, in power limited scenarios the number of cores is only part of the equation, perf/w within the limited power envelope is crucial.
True. LNL will have a limited power budget, specially in gaming scenarios where GPU and Memory subsystem are quintessential, so feeding less cores means more power can go towards the others components.
I was making my judgement based on the fact current gen consoles are/will all be 8C/8(16T) based. But Lion Cove should be >2x over Skylake PPC, so I guess it's fine.
Ghostsonplanets
774
1,228
And most of the games are GPU bound. The tGPU in LNL is just entry level when it comes to real gaming. While gaming, the LNL tCPU is more than sufficient to keep the tGPU fully saturated at all times.
If the LNL is matching or surpassing MTL 8 Xe iGPU performance, I wouldn't call it entry level. From what I gather in reviews, MTL tGPU can comfortably run modern AAA games at low-medium 1080p30 or above. And in the more demanding cases, there's XeSS or FSR.
In a world where Apple fanless laptops can run AAA games (That are ported to Mac) and there's a push towards PC Handhelds, GPU performance at low power is a very important aspect.
Lunar Lake can have an edge here at novel designs due to the scalability and SKUs optimized for fanless designs.
Gaming problem arises, when we try to couple LNL with a good dGPU. Then things'll surely go haywire. But that isn't LNL's use case.
Completely agree here.
uzzi38
2,747
6,657
Saw a leak a few days back (not sure where). Top LNL part is expected to roughly double the performance of top MTL part. This puts it roughly somewhere near RTX 3050 or AMD equivalent. It's very entry level (even with XeSS enabled).
I'm 100% certain whoever said that is wrong, sorry.
I'm sure Lunar Lake will be a huge step up over what Intel has now for 15W iGPU performance, but at this power level they're currently quite far behind the competition. Also 3050 performance tier is far, far, far too ambitious.
Gzxy
9
9
41
Is LNL's use case gaming? I would say ARL non U will be aimed for gaming. Intel wants the market share that Apple has gained just because of the battery life + AI capabilities. Cores play a big role especially when you are limited to 4C - 4T. I dont know if the 4E will have L3 or be outside the bus (stupid if that's the case) but Panther will retain the 4P and add +4E Skymont.
HoveringStyle
22
26
51
The only 2x articles I'm finding are about Sisoftware Sandra GPU processing scores being 2x MTL at the same number of "EUs" (64) and 26% faster than the top MTL part. Who knows how that'll translate into gaming.
