Page 286 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
Yes, we're supposed to believe Intel will have capacity and manufacturing volume to do a vast amount of SKUs in the next 1- 2 years. But suddenly they'll lack it for NVL🤔.
Or perhaps i18A doesn't bring "unquestioned leadership".
AFAIK they never claimed that they would ship most, but just that their process would be the best...eventually.
@jur
Keep in mind that ASML isn't exactly a supermarket where you go in and the machines are lined up on the shelf for you to take home.
Even installing and dialing in these machines is a very lengthy process.
I wonder what's preventing Intel from expanding their capacity. Is there some other bottleneck besides EUV tools? They ordered 6 high NA tools and each of these costs twice as much as latest low NA tool. This seems very irrational decision. Wouldn't it make much more sense to ramp 18A as fast as possible,
1) There is one and only one EUV supplier, with a massive backlog of orders. https://www.tomshardware.com/news/a...-hits-record-backlog-exceeds-dollar38-billion
2) There has been a massive chip demand boom. Covid shortages, crypto, and now AI. This makes the backlog for equipment even larger.
3) Intel didn't buy enough EUV machines and then didn't get in line for the machines early enough. Intel had bad management that made bad decisions. They totally missed the ball for this chip demand boom.
Combine the three and Intel is bottlenecked. There is no possible way to ramp 18A much faster without the equipment to do so.
Not really, not anymore. The AI stuff is all packaging limited. Even N5, TSMC is in the process of retooling some of it for N3 and friends.
Intel doesn't have much capacity because they were hedging on whether to spin off the fabs... and whether they can actually afford to continue without putting the company at risk.
The technology bill passed by Biden provides tens of billions to Intel and other companies to build and expand their fabs. Even TSMC got several billion for their Arizona operations.
To add to what others have said, keep in mind that Intel has abandoned plans to make 20a and/or 18a High NA EUV processes. The acquisition of advanced equipment has no bearing on their processes through the entirety of 2025.
Pitches have been misleading for a long time and are becoming even more misleading. Intel is increasing its pitch from 30 to 36nm with 18A because BSPDN/PowerVia allows a larger M0 pitch without compromising density which helps in multiple ways.
What's the source for that? As far as I know there's nothing public on the features of 18A.
Thoughts on skymont?
Should be a really good core. Kepler recently said that SKT has around SNC/Z3 performance. So you're basically getting an extra 5950X, alongside 8 Lion Cores, if you buy Core Ultra 9 2990K.
Should help ARL be a MT monster. On LNL, it will act more as a LPE core because it will lack L3 cache and is "off-ring" (iirc).
Gracemont in Alder Lake already is ~95% of the per-clock integer performance of Cypress Cove. In Raptor Lake, it should surpass the PPC of Cypress Cove. Skymont should at minimum be Golden Cove level of PPC.
All this is based on the SPECint_rate 2017 1T numbers from past Anandtech reviews.
It's not clear if they refer to performance from IPC and clock speed combined. If it's IPC then I would agree SNC level isn't great when Gracemont already was basically on par with Skylake, at least on integer workloads. And seems like the Skymont cluster in Lunar Lake is quite a bit bigger now compared to Lion Cove big core.
It's fake. Huge Intel fanboy that doesn't know anything and he's usually all the time around tech twitter trying to get leaks.
Anyway, you can spot on that it's fake due to him claiming CPU tile and SoC tile are separated tiles fabricated on different nodes. While, from what we know, CPU and SoC tile are merged on PTL. The CPU core configuration is also straight out of MLID videos.
Yeah, that guy isn't worth the attention.
Too bad Ghostsonplanets is wrong with his tile prediction. Just because LNL integrate Soc into the compute tile doesn't mean Intel will do the same with their regular mobile lineup after Arrow Lake. Why should they do this if they are 18A volume limited. Panther Lake is not a MX chip, it's UPH. There is no On-package memory either based on the Intel slide.
